I think your planking looks just fine, sir. Nice job.
After some effort, I successfully completed the deck planking for my ship model. However, I’ve run into a few issues and I’m hoping someone can suggest a solution. I decided to plank the false deck before attaching it to the hull, which made the process much smoother. This approach allowed me to easily trim the planks to size, sand them, and adjust the entire deck surface with precision. Pleased with how manageable it was, I then decided to weather the deck to enhance its realism. Instead of simulating nail heads by drawing them with a pencil or using the toothpick method, I opted to punch them into the wood using an old, darkened pinhead. My plan was that, after painting, the holes would fill with paint and create a rusted, distressed look that I thought could add character.
While I achieved the weathered effect I was aiming for and was initially happy with the result, I now realize I may have made a HUGE mistake by doing all of this before attaching the false deck to the hull. Some of the notches along the sides—those intended to align with the bulkheads —ended up too large, leaving noticeable gaps that detract from the finish.
As the saying goes, "live and learn." At this point, I’m unsure if there’s a viable fix that doesn’t involve redoing the entire deck. My original concern was that planking the deck after attaching it to the hull as it would need to follow the deck’s natural curve might complicate the alignment. I never imagined I’d end up with a problem this frustrating by working on it separately.
Edited by Digitalis
I have to admit, at arms length that looks damn good!
Well done.
Alan O'Neill
I’d greatly appreciate any advice or hacks you could share on fixing these larger gaps. I’m sure this wont by my last mistake and I’ll have more lessons to learn along the way!
While reflecting on this, I just thought of something... what if I craft some sort of trim or edging strip to fit snugly around each bulkhead column? It might not be entirely historically accurate, but it could neatly conceal the oversized notches. Is this an approach sometimes used in situations like this? or is starting over from scratch the usual fix? I’m trying to weigh my options and figure out the best path forward.
Edited by Digitalis
If I understand it, referencing your first post image of the box, some of the gaps will be under the aft upper deck yet to be installed... so they won't be seen.
The others are on the starboard side and may fall under the ladder... so they might not be seen.
If they still bother you mix up a drop of white PVA glue and sawdust (same wood as the deck planks making a wood putty) and fill the gaps and smooth them out flush to the deck. Then take a fine bladed tool and scrape away one edge ever so slightly to reveal the blackened joint a bit. Let it dry. Lightly sand it with extra fine sand paper and (hopefully) volia! There she be!
Try it on one gap furthest aft that will be covered by the upper deck first as a trial
Edited by AON
Alan O'Neill
@AON made a good call there. It will be a tedious process but will solve your problem. I am sorry I didn't see this before you planked the deck, the issue could have been pointed out. Lesson learned eh, we've all been there.
For now, I plan to patch it as best I can by backing the gap with a larger piece beneath the false deck to support two smaller strips, compensating for the thickness. Once I install the baseboard (as specified in the instructions), I’ll assess whether I have enough leftover material to extend it around each bulkhead column along the baseboard’s perimeter or if is unnecessary.
I've seen people remove planks by heating them with a low temperature set iron (or clean nib on a soldering iron or such) and carefully peeling them off.
When the wood and glue cools on the surrounding untouched pieces they stay in place as before, unscathed.
Then they replace the individual pieces with new undamaged pieces (normally the piece accidentally gets damaged).
I've also seen people carefully cut and chisel individual planks out.
I have never attempted either.
Alan O'Neill
With a fine, very sharp chisel that would work. If you work very carefully you should be able to do it.
I might end up making it worse, but honestly, I don’t mind the patch. After some sanding and distressing, it should turn out just fine. Plus, I think it adds character to the story—back in the day, they probably had to repair and patch things all the time, right? Being my first project, it’s like a badge of honor, a little scar to remind me of all the mistakes I made along the way, and I’m okay with that.
On another note, I’ve started adding the upper decks and noticed that the one in the front doesn’t lie flat. Is this intentional? Should I keep that angle or should I sand the nudges until it lays flat over the bulkhead? I wish the instructions weren’t so cryptic
I'll admit that I've got my fair share of badges of honour!
Most decks had a rise to them. The mid width (over the keel) being higher than the outboard sides for water run off... plus the deck would be higher at the stem and stern then midships, for the same reason.
Edited by AON
Alan O'Neill
In my opinion, in that image it looks like your forward bulkhead is sitting a little too high? I agree with @AON, decks did tend to have a slope to them but this one looks a little extreme.
That was my impression as well but wanted to check just in case before I make adjustments so it sits lower. Thanks!
I've watched several videos on planking wooden model ships, and I’ve noticed some builders swear by wood glue, while others recommend cyanoacrylate (superglue). Is there a general consensus on which is best for this purpose? The cyanoacrylate approach seems more convenient, especially for a beginner like me, but I’d love to hear your thoughts since I’m new to this.
Good morning Digitalis, I mostly use woodglue for planking, with a bottle of CA for stubborn pieces. I will start a plank, or end one  with CA, but mostly wood glue.
 This is one of those questions that it your preference on which one you like. I have had great luck with wood glue and clamps .Good luck.   :cheers:
Bob M.
        USCG Harriet Lane
I only use CA if I want to secure one end of a particularly difficult plank while I work along it and glue it with wood glue for the rest of the way. Like Bob just said (@Knocklouder), it's down to personal preference but I find CA glue dries too quickly and allows pretty much no readjustment of the plank. Like him I prefer wood glue and clamps - so much more forgiving :) One thing to think about, and this is only the way I approach planking right now (I am going to try out a new method using a small mini iron to bend the planks on my Lynx build), I soak the planks (first layer only) for about 15 minutes and then clamp/nail them in position (NO GLUE) overnight to let them take the required shape. When they are dry and shaped, it is a whole lot easier to have them lay correctly while you glue them, you are not fighting against the wood and they don't spring back once glued (you may still need to secure them while they dry, depending on the curve etc.).
I have been steaming or soaking in boiling water then clamping in place with shims for a slight over bend to allow for spring back. Once dried overnight I glue with wood glue and clamp until set.
Alan O'Neill
I have been using a mini iron to heat form planks directly on the hull and it works better than anything else I have tried. I clamp the plank in place in a few places, wet it with a brush, and apply the heat. This gives the planks the correct curvature and twist for fit the shape of the hull, and it only takes a couple of minutes.
https://modelshipworld.com/topic/37060-uss-cape-msi-2-by-dr-pr-148-inshore-minesweeper/?do=findComment&comment=1074225
https://modelshipworld.com/topic/37060-uss-cape-msi-2-by-dr-pr-148-inshore-minesweeper/?do=findComment&comment=1075263
Phil
Current build: USS Cape MSI-2
