I’m currently building the Vanguard Adder and am scratching my head as to why the ropes from the ships wheel are not linked to the tiller as I have seen in other builds. The ropes from the wheel  go below deck and are,I assume, linked to the rudder by ropes and blocks/pulleys. Is the tiller there as a fail safe or am I missing something
Hornet
             Current build HMS Granado - Caldercraft
             Completed Ship Builds. - USRC Harriet Lane - Model Expo.
             Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
My fault, I really should have added an explanation in the manual.
The tiller that you see is auxiliary - there is another tiller arm a little further down the rudder. If you look at the rudder, you can see I simulated the start of the lower tiller arm (a little stub near the top, but lower than the deck tiller arm)
If you also showed a picture of the actual rudder, the lower tiller stub would be seen.
Vanguard Models on Facebook
Thanks Chris. I appreciate your explanation.  Love the detail in this kit!
Hornet
