Multi layers of thinned paint vs. 1 layer of thick paint and paint separate whenever possible before being assembled onto other parts. Water base acrylics will not adhere well to brass, I use testors oil base flat enamels. Make sure the brass is cleaned with alcohol before painting.
Current Build: Authentic Hannah Kit Bash
Pending Continuation: Sea of Galilee Boat
Completed Build:  MS AVS
On Shelf: AL Independence, Blue Jacket Alfred
I have painted brass before using acrylics.  The secret is the brass needs some teeth.  The good thing about the original Floquil was it adhered to brass once cleaned and primed.  The secret was that it actually was very mild etchant just below white vinegar.  What I did after cleaning a brass part was let it sit in some white vinegar for awhile to give it a little tooth after a thorugh rinse and cleaning I was able to use acrylics after using a primer.  You have to experiment it did not always work.  In my opinion brass was always difficult to paint.
David B
Just as David pointed out, cleaning the brass is important. But in my opinion, using a primer after cleaning is also necessary.
I have used some very fine wet&dry 1000 grid paper and then sprayed the parts with primer before the final paint.
Grant you, these were very flat pieces, but it worked well.
The primer I used was a standard, off the shelf, spray can.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
