Does anyone have comments, techniques, or links on how to locate and install deck clamps. My specific interest is for a Hahn build Oliver Cromwell.
Thank you,
Pete
Pete,
Measure from the build board up is the easiest way.  Mark on the frame (I go between the frames) then work from the inside using our marks as a reference.  If you'll look at the plans, Hahn, shows the clamp as a line with the beams on it.  Use that line for your measurement to locate the top of the clamp.
I use a tool I copied from Ed T's Naiad log... here's my version:  http://modelshipworld.com/index.php/topic/5339-licorne-by-mtaylor-pof-316-french-frigate-hahn-version-20/?p=154262
