While doing some research on photo etching I ran across this item.  It is about making printed circuit boards but the etching part is what is most interesting.  The etchant is a mixture of plain white vinegar and 3% hydrogen peroxide with a little table salt.  Much less toxic/dangerous than the typical hydrochloric acid or ferric chloride etchant.  I have not tried this yet but it looks like a good method.
http://quinndunki.com/blondihacks/?p=835
My advice and comments are always worth what you paid for them.
Good morning G, thanks for the info.
I use straight white vinegar, but will try a little peroxide next time.  As a follow on experinent, will add a pinch of salt.
Happy modelling.
Duff
Vinegar does the trick and is relatively safe, but is very slow in acting. I'm not sure what good salt will do: vinegar is an acid, salt is a base. They will counteract each other.
