My quest for a new toy continues , after my recent query on the Jim saw i have been considering what might be most usefull at my present stage of build . I have come up with a Proxxon MF 70 mill , .My mind is made up(for a change) and the present low euro -pound means i can buy it for less than £200 + postage  My question now to anyone who has this is what accessiares i should order along with it . Don,t ask me exactly what i will be doing with it cause i don,t know yet but i have spent a lot of time reading reviews etc from other members and it seems to be a very usefull piece of kit . I started out looking for something to drill holes accurately ,and finished up thinking why not spend a few pounds more and have a multi task piece of kit  .I would just like to know which extras are the most usefull for general use , i have already added the percision steel vice but am unsure of what else i need . Thanks for all suggestions .
Boyd
Tks, Boccherini , that should cover the basics . Did i read somewhere that the collets hold better / more stable than the chuck ,so it should only be used for smaller bits i assume ??
Brian ,tks for the suggestion but i think i will consider adding the engraving unit later when i get a a bit more experience .
Another question , it does not mention which, if any bits are supplied with the unit ,any suggestions as to which i should order to begin with for general use ,again i have no idea exactly what i will be using it for so don,t want to buy specialised pieces as yet . I read that some people can make their own for paticuliar projects , is that an option ??
Boyd,
the collets are a better option, but they do not grip smaller sized drill bits, hence the chuck, unless you have a set of bits with shanks all the same size. My mill kit came with 1,2&3mm end mills. I purchased several other other sizes not long after out of necessity, they were Kyocera end mills with 3mm shanks.
Regards,
Grant.
The standard type of equipment was already mentioned.
Concerning tooling: If you are planning to mill wood, plastics or aluminium, carbide end-mill with 3 mm or 1/8" shaft come handy. They can be bought at a reasonable price e.g. at electronic bay and come from e.g. the aerospace or circuitboard industry, where they are replaced before they get dull - it is cheaper to replace them before they get dull than to throw away ruined work-pieces. For our purposes they are still good enough.
On a machine like the MF70 I would always use drills with thickened shaft, they run much more concentric. They come with 1 mm, 1.5 mm and 1/8" shaft, depending on the size. Again carbide drills down to very small sizes are available from the same source mentioned above, but beware they are very fragile.
If you have also a lathe, you will probably begin to make useful accessories for the mill. I could think, for instance, of a fly-cutter that allows you to mill flat larger work-pieces. Another useful piece would be an indexing block for the PROXXON-collets that can be held in the vice - great for quickly milling-on flats/squares.
Talking about vices: my favourite ones are the screwless ones that were originally designed for e.g. EDM-machining. They come in small sizes and the movable jaw is pulled towards the workpiece as well as down.
