Laxet
Posts posted by Laxet
  1. [quote
    Are you going to paint the masts  cheeks and tops?
    Regards
    Ken
    Hi Ken,
    Yes. I will follow the painting suggestions provided, they say buff & black, so that's the next thing. I think I should probably wait until I build the rest of each mast & use an airbrush. That is why I didn't sand of the laser burn marks. I knew I would paint over them.
    Tim,
    Thanks. I appreciate it.
  2. After deepening the grooves for the cross trees, these things were a mess. I didn't know if ME compensated for the amount that needed to be sanded to make them square. Luckily, I had another set after ordering replacement parts for something else. I took them & sanded them on my bench sander to square them up, then refiled the grooves to make them fit. They look okay.
    The reason I had to file the grooves is because they are only 1/16" deep, & the plan calls for 3/32" thick crosstrees. You need that thickness to get the proper taper of the cross trees. Here is the result. I think they came out okay as well.
  3. I was able to get some boxwood. I bought two small sheets. I had a heck of a time cutting it on my little 4" Jim Byrnes table saw. The stuff is really hard. I can see why it was recommended. I will use it to carve cleats. I cut a bunch of 1/4" blanks that are 3/32" square. I have carved one so far. This will take a while. According to my count (& I may have missed some) I need 31 for the bulwarks & bitts, & another 14 for the masts. That comes to close to 50 of the little beasts. Boy will I have sore fingers when I'm done.
  4. So here is my bowsprit. The jibboom martingale turned out to be a non-issue after all. I didn't actually attach the hoop that joins the flying jibboom to the jibboom. I just slipped it off & made the line with sliding servings. Once I placed the line, I tightened everything up & added a touch of glue. I also added a few blocks on the spritsail yard. I think this is about all I can do. I guess I'm gonna have to actually install the bowsprit. Scary thought. I think I'll wait until I have all hull work completed.
  5. On sheet 5, upper right corner, there is a drawing of jibboom outhaul tackle. I can find no reference on this sheet that shows where this line is belayed. On the belaying plan, they show an outer jib downhaul. Is this the same thing? If not, where the heck does this line go? If it is, then for crying out loud, why change the terminology? This thing is tough enough without throwing riddles in.
  6. Got a package in the mail today from Model Expo. Once again they have come through. I was shorted some .028" black line. At the same time I requested a whole 'nother set of quarter boat lifts, since I had screwed up the originals so badly. They were there also. I really like dealing with Model Expo. They do stand behind their products 100%, no questions asked.
    However, and I don't want to sound ungrateful here, but the line they sent is nylon & it is so stiff I don't know if I can make it straight. I may just have to buy or make some other line.
