Everything posted by JSGerson
- 974 replies
- rattlesnake
- mamoli
The Parquet Floor The practicum states there is absolutely no historical documentation to show that Rattlesnake had a checkerboard floor. Probably it didn't. It goes on to explain that the captain’s cabin in the HMS Victory, had a parquet floor of black and white checkerboard. Technically this is a former American ship whose plans were drawn up by the British. Who is to say it didn’t have a parquet floor when the British re-fitted her? Not only that, it looks like fun thing to do. First a template was made by making a tracing from the Hahn deck plan of the captain’s quarter’s floor and transferring it to cardstock. The cardstock was fine-tuned by fitting to the model. Based on the template, a piece of 1/64” plywood was cut and matched to fit the model. A second piece of plywood was cut to 4” x4”. Strips of 3/16” x .020” holly and walnut to-be-stained-black (did not have ebony) were cut to 3” long.
- 974 replies
- rattlesnake
- mamoli
- 974 replies
- rattlesnake
- mamoli
The forecastle deck clamp has an extra added attraction – it’s curved due to shape of the bow. Using the Hahn plan, I bent the wood stock to conform to the shape of the bow. Also the notches have to be custom cut due to the curved shape.
- 974 replies
- rattlesnake
- mamoli
The reason for the “stop” was here was where the deck clamp was to be installed. By now, everything had been glued tight, sanded smooth, and coated with poly-wipe. Still not completely understand the complete consequences of my error I moved on and followed the practicum on how to make the deck clamp not realizing that it had to be modified due to the error. (There are those ripples moving out again!). I’ll get to that later. To make the deck clamp, I modified the side view template. The deck clamp is a 3/32” x 3/32” strip of boxwood with strategically placed and cut 1/16” x 1/16” x 1/16” notches. These will hold the cross beams for the deck above the stern and bow. I had a lot of difficulty placing the clamps on the model. As it turned out, I had the height almost right, but not the side to side position. It glued it directly on top of the bulwarks. In actuality, it should have been glued to the frames and bulkheads and the planking would have been around it. Visually it won’t be noticed by the novice viewer; but I know.
- 974 replies
- rattlesnake
- mamoli
Here is where I made a big mistake and did not discover it till later on, too late to redo over. The practicum says STOP when you reach the 5th row. In my enthusiasm I didn’t see the STOP sign and completed the planking.
- 974 replies
- rattlesnake
- mamoli
Bulwarks Planking and Deck Clamps Depending on what bulwark method used determined the thickness of the planking strips. In my case, it was 1/32” x 3/32” swiss pear. Staring from the stern and staggering the joints, the planking was installed.
- 974 replies
- rattlesnake
- mamoli
The Bulwarks The practicum stated that Mr. Hunt’s first inclination was the most obvious one; simply apply the planking to the framework. But because the practicum addressed two construction approaches, he thought there might be some who would like to use the wood supplied in the kit on their bulwarks. This wood is very thin and applying it straight to the bulwarks will make it very difficult to sand and keep the planking even between rows. He offered a non-standard solution that was to give a nice looking bulwark area. And since the model was not a plank on frame model he felt that the solution was a good one. The solution was to use a very 1/64” plywood veneer against the framework first and then apply a thinner plank on top of the plywood veneer. Alternatively, the kit instructs the builder to add additional false framework to support the planking. I elected to follow the plywood approach. Cardstock templates made from file folders and used to form the plywood pieces. Then they were glued in. Once the bulwarks were installed all of the openings for the gunports and windows were cut out.
- 974 replies
- rattlesnake
- mamoli
CHAPTER 3 – Internal Planking In this chapter I make mistakes, some big due to my inexperience. This after all, my first real POB model as I explained earlier. So forgive my inexact results. Usually I didn’t discover the errors until it was too late (for me at least) to go back and do over. The Waterway The Waterway is a thick plank that is beveled on its face in such a way that the bulwarks planking will meet the bevel on the top and the deck planking will meet the bevel on the bottom. The waterway also conforms to the angle of the framework. This is an angle that tilts slightly inward from the bottom to the top. Its cross section looks like a skewed pentagon. To install this I had to make sure all the false frames and cut down bulkheads were all even. Then they was installed in lengths of about 4” along the complete length of the deck on both sides
- 974 replies
- rattlesnake
- mamoli
Aft Side Windows Again the side view template was used to locate the aft windows on each side of the model. Small pilot holes were drilled and then expanded and finally cut and filed to shape. Four pieces of boxwood was used to create the window frame and glued on the inside wall. At this point they exactly like gunports. Bowsprit Hole It was at this point that the practicum instructed how to remove the keel extension in the bow that was done earlier. The one thing that hadn’t been done was to create the hole for the bowsprit. This was now done. Fine tuning this opening will be done latter. This ends Chapter 2
- 974 replies
- rattlesnake
- mamoli
Planking above the Main Rail One row of planking was added above the Main Rail aft of the center three gunports and also forward of them. Another railing was then installed aft over the last row but this time it’s made of swiss pearwood. Finally the last four rows of swiss pearwood planking were added aft; and it was time to treenail again.
- 974 replies
- rattlesnake
- mamoli
The trick is to keep the razor blade 90º to the stock as it is repeatedly drawn the cut profile until the desired molding is complete. This is not easy. Once done, you can’t sand it smooth or you wipe out the molding. I was somewhat successful having never done it before. The molding wasn’t as sharp as I would have like it, but I was afraid I might break it if I continued. It was then installed. Sorry no pictures at this stage.
- 974 replies
- rattlesnake
- mamoli
The Main Rail The mail rail is a molded holly strip that is light in color and is added before the remaining planking is completed. Making the molded profile was a completely new technique to me. After purchasing some “super thin separating cutting discs” from a company called International Inc., a profile of the molding is cut into a razor blade The width of the profile must be the same as the stock piece of wood that is to be drawn through it.
- 974 replies
- rattlesnake
- mamoli
Stern Transom Planking Because the ends of the stern planking need to be covered by the side planning, the stern planking was started at this point. Once more I was reminded that something was amiss because in the practicum, only one row of planking was needed to reach the bottom of the window opening. In my model it required two. As the successive rows were added on, the window openings were carved out. The second picture was taken before I had sanded and cleaned up the flaws so it looks a bit rough.
- 974 replies
- rattlesnake
- mamoli
Following the instructions of the practicum, I installed the tree nails using Minwax Wipeon Poly as the adhesive. This is the same coating used to finish the wood surface of the boat. The excess bamboo is cut off and sanded flush leaving no glue marks. I prefer that the treenails have a low contrast rather high one as seen in some other models because I feel it looks more realistic. The picture below shows the bamboo “glued in” but not trimmed and sanded.
- 974 replies
- rattlesnake
- mamoli
I found that as I got down to the smaller sizes the holes were not consistently progressive in getter smaller. I had difficulty creating the tree nails. After struggling for a while I discovered that Byrnes Machines also sold draw plates and knowing there fine workmanship from previous purchases, I bought theirs. It worked like a charm as expected.
- 974 replies
- rattlesnake
- mamoli
I split the bamboo skewer into 4 pieces and then drew them through smaller and smaller holes to get to the called for .026” diameter
- 974 replies
- rattlesnake
- mamoli
Tree Nails The practicum gave the option of installing tree nails. Obviously these ships didn’t use nails because they would just rust away and the ship would fall apart in no time. They used wood plugs or tree nails. In for a penny, in for a pound, I didn’t hesitate to incorporate them into my model. The practicum stated that they could be made from bamboo (which I got at the grocery store as bamboo skewers) and a draw plate which could be purchase at either Model Expo or Micro Mark. I bought the one from Model Expo because it had more holes. Note the other plate in the picture is a drill sizer plate
- 974 replies
- rattlesnake
- mamoli
Oar Sweeps Once more the side view template comes into use to transfer the oar sweeps with pencil. Small holes were drilled, expanded, and filed to size. The oar sweep frame was then constructed off the model and installed The top sills of the gunports were installed next
- 974 replies
- rattlesnake
- mamoli
- 974 replies
- rattlesnake
- mamoli
In constructing the gunports it was necessary to remove part of the kit bulkheads. Eventually all expose kit bulkheads would be removed. Although the practicum did not call for it at this point (it would a few steps later), the keel extension in the bow was removed and replaced with other pieces as instructed by the practicum.
- 974 replies
- rattlesnake
- mamoli
In ensure that the bottom of the gunport was at the proper height off the deck, I made a template of the cannon and used it to measure the top of the sill.
- 974 replies
- rattlesnake
- mamoli
Because some of the gunports have lids and others don’t, a lip had to be constructed around the openings for those that did. Here is a picture from the practicum as I do not have a picture that depicts it.
- 974 replies
- rattlesnake
- mamoli
- 974 replies
- rattlesnake
- mamoli
The practicum implies that all of the gunport openings be cut out at this point. Then a sill added to the interior base of each opening. And finally false ribs are added to each side of the gunport. Not trusting myself, I did it this way but one opening was completed at a time. The false ribs templates are again created from the Hahn plans, but what I did not fully comprehend about the Hahn plans was that they were designed to used to build the model with the Mr. Hahn’s method of construction. Therefore the ribs shown in the plan have extension on them to fit onto a construction jig. Once removed from the jig, the frames are cut to size. The practicum instructs you to construct the false ribs by using portions of the full rib. If I were to do it over again, I would have left the extension on and used them for lining and adjusting of all the false ribs during installation. Then I would have cut them off.
- 974 replies
- rattlesnake
- mamoli
