trippwj
Everything posted by trippwj
  1. So the big questions - will you will you build it bottom first with sewn planks (as built approach)?
  2. Rest in Peace, my friend.  We shall all miss you.
  3. Nice. Lavery is well researched and frequently cited in academic research. You have a very nice start to your library. What era and type of ships interest you? I may have a copy of the Bounty AoTS. Let me check - I doubt I shall ever get to where I would build her.
  4. The paperback versions of Steel are mostly "print on demand". The size is much reduced. Still useful, but not as legible as one might hope. The web version noted above is good, and I think there is a downloadable pdf out there somewhere. I use all the above (plus Lee's, Biddlecomb, Lever and others, depending on the subject and the issue).
  5. Back in the days of sail there were but 2 watch groups - port & starboard. The dinner watch was 2 hours to shift which group had the late watch (midnight to 4am). Of course if there was s need to take in sail overnight then both watches stood to (all hands on deck).
  6. Here is the info about the papers: https://www.nationalarchives.gov.uk/about/news/prize-papers-research-portal-launched/ I haven't found the specific event but the info on the project is interesting!
  7. As noted above the rake, while similar, was not identical. Nor, for that matter, was it fixed. The rake could be adjusted somewhat to improve sailing characteristics, and each captain had a certain leeway to adjust the masts to suit his preferences.
  8. This may be of some use - particularly the references. Twede, Diana, ‘The Cask Age: The Technology and History of Wooden Barrels’, Packaging Technology and Science, 18.5 (2005), 253–64 https://www.academia.edu/57917150/The_cask_age_the_technology_and_history_of_wooden_barrels
  9. Indeed, they might. THe challenge is that terminology, in this case, matters. A "Barrel" is a specific size of a cask. A cask could range from fairly small to fairly large, and there were names for different size casks such as "tun" "Firkin" "butt" etc. The following tables were shamelessly copied from the USS Constitution Museum website at https://ussconstitutionmuseum.org/2016/03/10/roll-out-the-barrel/ The number of staves varied by the diameter of the cask and were not flat on each edge but curved to accomodate the expanded diameter at the middle with narrower tops & bottoms. Since they were hand carved there was quite a bit of variability hence each cask of a given volume might have the same maximum diameter yet a varying number of staves. I believe he said that the standard whiskey barrel had around 33 staves of varying width. Larger casks (such as a tun of about 260 US gallons) had up to 100 staves. So, what do you want to put in the cask - that factors into the size?
  10. I had the opportunity to chat with the cooper at the Mystic Seaport museum (approx. 1840ish time period). He indicated that there was no fixed number as it depended on the cooper. If the staves were carved a bit wider then fewer were needed. A bit narrower than a few more. The goal was to make the staves as uniform as possible for a given cask. In fact, when the casks were shipped dis-assembled the staves were each given a letter to identify the cask and a roman numeral to identify the location on the cask The staves were not interchangeable if you wanted it liquid-tight. Bet that didn't help your research any! Good luck!
  11. You are a tad aggressive there, sir. You have not explained anything to me but rather argued why your view is correct. I am attempting to point out alternative explanations based on published works and theories which you disparage. I am fully aware of the use of bows and splines, for example, yet the shipwright would still need to define that arc. Just one example.
  12. One consistent challenge in utilizing modern methods to reimagine old drawings is the urge to ignore the technological capabilities of the time. A modern CAD program and basic calculator bring levels of precision and accuracy unattainable to the contemporary worker. Using Baker as an example, a large part of his manuscript us concerned with finding the best proportions to allow the scaling of the midship mould from one tunnage vessel to another. The math was teduous - logarithms were not available until after Wells had assumed responsibility for the manuscript around 1600ish. Interpreting this drawing as somehow flawed ignores the history of the item and the intended use. It is a scale representation, but not a construction drawing. It was most likely not intended to be 100% accurate but rather illustrative of the process. I think the important question is whether using the modern tools, one can create the shape by replicating the radii of the arcs as described by Baker, then if these arcs can be adjusted using the rising and narrowing lines to derive other frames fore and aft. Lastly, what where the proportions used in this specific drawing to establish the radii? As I recall, in some instances they were not mathematical but geometric points, unlike the 1620 MS where tge radii were a mathematical derivation of some dimension.
  13. Mark - By any chance do you have the source information on this document? I am searching on the site but haven't come up with ths one just yet. Many Thanks!
  14. In the contemporary records it is generally Mathew with one "t"
  15. What is the rough scale of the drawing? Is it possible that as a representative as opposed to true "scale" drawing the line of the wale lost fidelity due to the need to extend a greater distance to draw the line than was available on the wirk surface? If the intended arc was 263" actual scale of the drawing that would be some 22 feet to draw it accurately...
  16. Teach me to do a quick search on my phone!
  17. https://www.rmg.co.uk/collections/objects/rmgc-object-79839
  18. There have been several mentions of available research literature and potentially relevant treatises contemporary to the Renaissance in northwest Europe. With appologies to some, following is a fairly lengthy set of resources (note there may be some duplication between the two lists - they are tagged for topic areas, and some or most fit multiple subjects). Again, this is a sample. I have not included my Naval Architecture and Shipbuilding collection, though some of these are in either or both of those subject collections. List the First is primarily related to the low countries, although some other regions may have snuck in. Adams, J., Holk, A.F. van and Maarleveld, T.J. (1990) Dredgers and archaeology: shipfinds from the Slufter. Alphen aan den Rijn (Archeologie onder water : onderzoeksrapport, 2). Available at: https://www.academia.edu/919874/Dredgers_and_Archaeology._Shipfinds_from_the_Slufter (Accessed: 13 May 2015). Bender, J. (2014) Dutch Warships in the Age of Sail, 1600-1714: Design, Construction, Careers, and Fates. Barnsley, SYorkshire: Naval Institute Press. Bruijn, J.R. (2017) The Dutch Navy of the Seventeenth and Eighteenth Centuries. Oxford: Liverpool University Press (Research in Maritime History, 45). Available at: http://liverpooluniversitypress.co.uk/books/isbn/9781786948908. van Duivenvoorde, W. van (2012) ‘Chapter 34: Use of Pine Sheathing on Dutch East India Company Ships’, in N. Günsenin (ed.) Between Continents: Proceedings of the twelfth International Symposium on Boat and Ship Archaeology, Istanbul 2009, ISBSA 12, pp. 241–251. Available at: https://www.academia.edu/2276273/Chapter_34_Use_of_Pine_Sheathing_on_Dutch_East_India_Company_Ships_in_N._G%C3%BCnsenin_ed._Between_Continents_Proceedings_of_the_twelfth_International_Symposium_on_Boat_and_Ship_Archaeology_Istanbul_2009_ISBSA_12_pp._241_251 (Accessed: 19 March 2015). van Duivenvoorde, W. van (2015) Dutch East India Company Shipbuilding: The Archaeological Study of Batavia and Other Seventeenth-Century VOC Ships. College Station: Texas A&M University Press. van Duivenvoorde, W. van (2017) ‘(2009). More Than Just Bits of Hull: Expensive oak, laminate construction, and goat hair: new insights on "Batavia"'s archaeological hull remains. Tijdschrift voor Zeegeschiedenis 28.2:59–68 and 72–73.’, Tijdschrift voor Zeegeschiedenis 28.2:59–68 and 72–73. [Preprint]. Available at: https://www.academia.edu/2280418/_2009_._More_Than_Just_Bits_of_Hull_Expensive_oak_laminate_construction_and_goat_hair_new_insights_on_Batavia_s_archaeological_hull_remains._Tijdschrift_voor_Zeegeschiedenis_28.2_59_68_and_72_73 (Accessed: 4 January 2017). Gardiner, R. and Unger, R.W. (eds) (1994) Cogs, caravels, and galleons: the sailing ship, 1000-1650. Annapolis, MD: Naval Institute Press (Conway’s history of the ship). Guy, R. (2012) First Spaces Of Colonialism: The Architecture Of Dutch East India Company Ships. PhD Dissertation. Cornell. Available at: https://ecommons.cornell.edu/handle/1813/29468 (Accessed: 15 August 2021). Hocker, F. (2013) ‘Review - Nicolaes Witsen and Shipbuilding in the Dutch Golden Age’, The Mariner’s Mirror, 99(3), pp. 359–361. Available at: https://doi.org/10.1080/00253359.2013.792595. Holk, A.F.L. van (2021) ‘Innovation, institutions and migration: transfer of technology in Dutch shipbuilding, 500-1700’, Archaeonautica. L’archéologie maritime et navale de la préhistoire à l’époque contemporaine, (21), pp. 33–40. Available at: https://doi.org/10.4000/archaeonautica.754. Hoving, A.J. (2012) Nicolaes Witsen and shipbuilding in the Dutch Golden Age. 1st ed. College Station: Texas A&M University Press (Ed Rachal Foundation nautical archaeology series). Hoving, A.J. (2014) 17th century Dutch merchant ships: text, photos and plans for the ship modeler. Florence, OR: SeaWatch Books. Available at: http://www.seawatchbooks.com/114003. Jaeger, W. (2001) Die niederländische Jacht im 17. Jahrhundert: eine technisch-historische Dokumentation. Bielefeld: Verlag für Regionalgeschichte. Jong, J. de (2010) Standvastigheid & verwachting : a historical and philosophical inquiry into standardization and innovation in design and production of the VOC retourschip during the 18th century. info:eu-repo/semantics/masterThesis. University of Twente. Available at: http://essay.utwente.nl/66547/ (Accessed: 24 April 2015). Koot, G.M. (2016) the Dutch Republic and Britain: The Making of a European World Economy: Home. Available at: http://www1.umassd.edu/euro/welcome.cfm (Accessed: 3 November 2016). Maarleveld, T.J. (2013) ‘Early Modern Merchant Ships, Nicolaes Witsen and a Dutch-Flush Index’, International Journal of Nautical Archaeology, 42(2), pp. 348–357. Available at: https://doi.org/10.1111/1095-9270.12022. Maarleveld, T.J. (2017) ‘The Aanloop Molengat site (Wadden Sea, the Netherlands) and Europe anno 1635.The historical interpretation of a strategic cargo.’, in J. Gawronski, A. van Holk, and J. Schokkenbroek (eds) Ships And Maritime Landscapes. Proceedings of the Thirteenth International Symposium on Boat and Ship Archaeology, Amsterdam 2012. Barkhuis, pp. 113–119. Available at: https://www.academia.edu/34251783/The_Aanloop_Molengat_site_Wadden_Sea_the_Netherlands_and_Europe_anno_1635_The_historical_interpretation_of_a_strategic_cargo (Accessed: 2 August 2022). O’Grada, C. and Kelly, M. (2014) Speed Under Sail, 1750-1850. SSRN Scholarly Paper. Rochester, NY: Social Science Research Network. Available at: http://papers.ssrn.com/abstract=2412955 (Accessed: 15 February 2015). Preston, R.A. (1950) ‘To Outsail the Dutch’, The Mariner’s Mirror, 36(4), pp. 322–336. Available at: https://doi.org/10.1080/00253359.1950.10657617. Rålamb, Å.C. (1691) Skeps Byggerij eller Adelig Öfnings Tionde Tom Stockholm 1691. Sjöhistoriska museet. Available at: http://www.bruzelius.info/Nautica/Shipbuilding/Ralamb(1691).html. Page images available at https://commons.wikimedia.org/w/index.php?search=Skeps+Byggerij&title=Special:MediaSearch&go=Go&type=image Reehorst, K.P. ter (1850) The mariner’s and merchant’s polyglot technical dictionary of upwards of five thousand nautical, steam, and ship-building terms, commercial and scientific, in ten different languages, ... with a precise explanatory key to the pronunciation of these languages, and a comparative table of the money, weights and measures of sea ports. London : Williams and Northgate ... Available at: http://archive.org/details/gri_33125012932121 (Accessed: 11 April 2015). Reinders, R. (1991) Carvel construction technique: skeleton-first, shell-first: fifth International Symposium on Boat and Ship Archaeology, Amsterdam 1988. Edited by P. Kees. Oxford: Oxbow Books (Oxbow monograph, 12). Available at: //catalog.hathitrust.org/Record/002647582. Roscam, H. (1603) Dutch ships ram galleys (Halve Maene overvaart een galei op 3 oktober 1602. Ook wel gezien als een afbeelding van de Slag bij Sluis van 26 mei 1603). Available at: https://en.wikipedia.org/wiki/File:Scheepsstrijd_op_de_Zeeuwse_stromen,_slag_bij_Sluis_26_mei_1603.jpg (Accessed: 7 October 2016). Sewel, W. (1699) A compendious guide to the Low-Dutch language : containing the most necessary and essential grammar-rules ... Korte wegwyzer der nederduytsche taal ... Printed for the widdow of S. Swart. Available at: http://brbl-dl.library.yale.edu/vufind/Record/3558608. May be useful in translating some of the older treatises. Stevin, S. (1586) De Beghinselen des Waterwichts. Inde druckerye van Christoffel Plantijn, by Françoys van Raphelinghen. Available at: https://books.google.com/books?id=r288AAAAcAAJ. Unger, R.W. (1973) ‘Dutch Ship Design in the Fifteenth and Sixteenth Centuries’, Viator, 4, pp. 387–412. Available at: https://doi.org/10.1484/J.VIATOR.2.301656. Unger, R.W. (1978) Dutch shipbuilding before 1800: ships and guilds. Assen: Van Gorcum (Aspects of economic history.2). Available at: http://catalog.hathitrust.org/Record/000736872 (Accessed: 13 March 2015). Unger, R.W. (2011) ‘Dutch nautical sciences in the golden age: the portuguese influence’, E-journal of Portuguese History, 9(2), pp. 68–83. Verweij, J., Waldus, W. and Holk, A.F.L.V. (2012) ‘Continuity and change in Dutch shipbuilding’, Journal of Archaeology in the Low Countries, 4(1), pp. 65–93. Witsen, N. (1671a) Aeloude en hedendaegsche scheeps-bouw en bestier. t’ Amsterdam : By Casparus Commelijn, Broer en Jan Appelaer, Boeck-verkoopers. Available at: http://archive.org/details/gri_33125008247716 (Accessed: 9 March 2015). Witsen, N. (1671b) Nicolaas Witsen, Aaloude en hedendaagsche scheeps-bouw en bestier · dbnl. Available at: http://www.dbnl.org/tekst/wits008arch01_01/ (Accessed: 9 March 2015). Witsen, N.C. (1690) Architectura navalis et reginem nauticum. [Amsterdam, Graphic]. Available at: http://archive.org/details/bub_gb_XfA3AQAAMAAJ (Accessed: 24 November 2016). Yk (Ijk), C. van (1697) De nederlandsche scheeps-bouw-konst open gestelt : vertoonende naar wat regel, of evenredenheyd, in Nederland meest alle scheepen werden gebouwd : mitsgaders masten, zeylen, ankers, en touwen, enz. daar aan gepast : soo suit de schriften van ouder, als jonger bouw-meesters, als ook by eygen ondervindinge, tot nut van alle jonge bouw-meesters en knechten, als ook uitreeders en liefhebbers van scheepen. Available at: https://archive.org/details/gri_33125012921124 (Accessed: 11 April 2015). List the Second is a broader survey of academic research related to the design of vessels or the reconstruction of wrecks. Adams, J. and Rönnby, J. (eds) (2013a) Interpreting shipwrecks: maritime archaeological approaches. Southampton: Highfield Press (Southampton Archaeology Monographs New Series, 4). Available at: https://www.academia.edu/31175211/Adams_J_and_R%C3%B6nnby_J_ed_Interpreting_Shipwrecks_Maritime_Archaeological_Approaches. Adams, J. and Rönnby, J. (2013b) ‘One of his Majesty’s “Beste Kraffwells”: the wreck of an early carvel-built ship at Franska Stenarna, Sweden’, International Journal of Nautical Archaeology, 42(1), pp. 103–117. Available at: https://doi.org/10.1111/j.1095-9270.2012.00355.x. Adams, J.R. (2013) A Maritime Archaeology of Ships: Innovation and Social Change in Late Medieval and Early Modern Europe. 2nd Revised ed. edition. Oxford, UK ; Oakville, CT: Oxbow Books. Alexiou, K. (2011) Two 16th century ships: their hull form and performance. Master’s Thesis. Maritime Archaeology Programme. Maritime Archaeology Programme University of Southern Denmark. Available at: http://www.maritimearchaeology.dk/downloads/MA%20Thesis_Alexiou.pdf (Accessed: 2 April 2015). Anderson, R.C. (1934) ‘The Bursledon Ship’, The Mariner’s Mirror, 20(2), pp. 158–170. Available at: https://doi.org/10.1080/00253359.1934.10655746. Barker, R. (1988) ‘“Many May Peruse Us”: Ribbands, Moulds and Models in the Dockyards’, Revista da Universidade de Coimbra, XXXIV, pp. 539–559. Bass, G.F. (ed.) (1974) A history of seafaring based on underwater archaeology. 1. Omega ed. London: Futura Publ (An Omega book). Bellabarba, S. (1993) ‘The Ancient Methods of Designing Hulls’, The Mariner’s Mirror, 79(3), pp. 274–292. Available at: https://doi.org/10.1080/00253359.1993.10656457. Bellabarba, S. (1996) ‘The Origins of the Ancient Methods of Designing Hulls: A Hypothesis’, The Mariner’s Mirror, 82(3), pp. 259–268. Available at: https://doi.org/10.1080/00253359.1996.10656602. Bellamy, M. (1997) Danish naval administration and shipbuilding in the reign of Christian IV (1596-1648). PhD Thesis. University of Glasgow. Available at: http://theses.gla.ac.uk/1383/1/1997bellamyphd.pdf (Accessed: 1 March 2015). Blue, L.K., Hocker, F.M. and Englert, A. (eds) (2006) Connected by the sea: proceedings of the Tenth International Symposium on Boat and Ship Archaeology, Roskilde 2003. International Symposium on Boat and Ship Archaeology, Oxford: Oxbow. Available at: https://books.google.com/books?id=kLzNDQAAQBAJ. Bondioli, M. (2003a) ‘The Arsenal of Venice and the Art of Building Ships’, in C. Beltrame (ed.) Boats, Ships and Shipyards. Atti del IX International Symposium on Boat and Ship Archaeology. Oxford: Oxbow, pp. 10–13. Available at: https://www.academia.edu/37935615/BONDIOLI_Mauro_The_Arsenal_of_Venice_and_the_Art_of_Building_Ships (Accessed: 14 July 2019). Bondioli, M. (2003b) ‘The Art of Designing and Building Venetian Galleys from the 15th to the 16th Century’, in Boats, Ships and Shipyards. Atti del IX International Symposium on Boat and Ship Archaeology. Oxford: Oxbow, pp. 222–227. Available at: https://www.academia.edu/37935593/BONDIOLI_Mauro_The_Art_of_Designing_and_Building_Venetian_Galleys_from_the_15th_to_the_16th_Century (Accessed: 14 July 2019). Breen, C. and Forsythe, W. (eds) (2013) ACUA Underwater Archaeology Proceedings 2013. Advisory Council on Underwater Archaeology. Available at: https://www.lulu.com/shop/advisory-council-for-underwater-archaeology/acua-underwater-archaeology-proceedings-2013/paperback/product-1wvq92rw.html (Accessed: 25 October 2022). Castro, F. (2008) ‘In Search of Unique Iberian Ship Design Concepts’, Historical Archaeology, 42(2), pp. 63–87. Cook, G.D., Horlings†, R. and Pietruszka, A. (2016) ‘Maritime Archaeology and the Early Atlantic Trade: research at Elmina, Ghana’, International Journal of Nautical Archaeology, 45(2), pp. 370–387. Available at: https://doi.org/10.1111/1095-9270.12180. Crumlin-Pedersen, O. (1998) ‘A new centre for maritime archaeology in Denmark.’, Archaeonautica, 14(1), pp. 327–332. Available at: https://doi.org/10.3406/nauti.1998.1226. Damianidis, K. (2018) ‘The Use of Ribbands in the Recent Shipbuilding Tradition’, Archaeonautica. L’archéologie maritime et navale de la préhistoire à l’époque contemporaine, (20), pp. 183–194. Available at: https://doi.org/10.4000/archaeonautica.571. Davis, J.S. (no date) The Problems Involved in Reconstruction of the Original Hull Shape of a 14 th Century Venetian Galley. Available at: https://www.academia.edu/36020087/The_Problems_Involved_in_Reconstruction_of_the_Original_Hull_Shape_of_a_14_th_Century_Venetian_Galley (Accessed: 20 August 2019). Duivenvoorde, W. van (2015) ‘The Use of Copper and Lead Sheathing in VOC Shipbuilding’, International Journal of Nautical Archaeology, 44(2), pp. 349–361. Available at: https://doi.org/10.1111/1095-9270.12118. Eriksson, N. (2010) ‘Between Clinker and Carvel : Aspects of hulls built with mixed planking in Scandinavia between 1550 and 1990’, Archaeologia Baltica, 14(2), pp. 77–84. Eriksson, N. (2017) ‘Eriksson, N. 2017. Riksäpplet (1676): resurrecting a neglected wreck’, Baltic and beyond Change and continuity in shipbuilding: Proceedings of the Fourteenth International Symposium on Boat and Ship Archaeology Gdańsk 2015, National Maritime Museum, pp. 39-48., pp. 39–48. Gawronski, J., Holk, A. van and Schokkenbroek, J. (2017) Ships and maritime landscapes: Proceedings of the Thirteenth International Symposium on Boat and Ship Archaeology, Amsterdam 2012. Barkhuis. Green, J. (2001) ‘The archaeological contribute to the knowledge of the extra-European shipbuilding at the time of the Medieval and Modern Iberian-Atlantic tradition’, in Proceedings. International Symposium on Archaeology of Medieval and Modern Ships, pp. 63–102. Available at: http://www.patrimoniocultural.pt/media/uploads/trabalhosdearqueologia/18/. Greenhill, B. (ed.) (1970) Aspects of the history of wooden shipbuilding. Greenwich, London: National Maritime Museum. Greenhill, B. and Morrison, J.S. (1995) The archaeology of boats & ships: an introduction. Annapolis, Md: Naval Institute Press. Helfman, N., Nishri, B. and Cvikel, D. (2018) ‘A Comparative Structural Analysis of Shell-first and Frame-based Ship Hulls of the 1st Millennium AD’, Naval Engineering Journal, 130(1), pp. 91–103. Hocker, F.M. (1991) The Development of a Bottom-based Shipbuilding Tradition in Northwestern Europe and the New World. Texas A & M University. Available at: http://anthropology.tamu.edu/papers/Hocker-PhD1991.pdf. Hocker, F.M. and Ward, C.A. (eds) (2004) The Philosophy of Shipbuilding: Conceptual Approaches to the Study of Wooden Ships. 1st ed. College Station: Texas A&M University Press (Ed Rachal Foundation nautical archaeology series). Hornell, J. (1935) ‘CONSTRUCTIONAL PARALLELS in SCANDINAVIAN and OCEANIC BOAT CONSTRUCTION’, The Mariner’s Mirror, 21(4), pp. 411–427. Available at: https://doi.org/10.1080/00253359.1935.10658736. Hornell, J. (1948) ‘The Sources of the Clinker and Carvel Systems in British Boat Construction’, The Mariner’s Mirror, 34(4), pp. 238–254. Available at: https://doi.org/10.1080/00253359.1948.10655783. Loewen, B. (1997a) ‘Bayonne 1419. Lapstraking and moulded frames in the same hull?’, The Mariner’s Mirror, 83(3), pp. 328–331. Available at: https://doi.org/10.1080/00253359.1997.10656652. Loewen, B. (1997b) ‘The Master-mould-shipbuilding tool of the Renaissance’, International Journal of Nautical Archaeology, 26(2), pp. 169–172. Loewen, B. (1998) ‘Recent Advances in Ship History and Archaeology, 1450-1650: Hull Design, Regional Typologies and Wood Studies’, Material Culture Review / Revue de la culture matérielle, 48(1), pp. 45–55. Loewen, B. (2001) ‘The structures of Atlantic shipbuilding in the 16th century. An archaeological perspective’, in F. Alves (ed.) Proceedings of the International Symposium on Archaeology of Medieval and Modern Ships of Iberian-Atlantic Tradition. Lisbon: Instituto Português de Arqueologia, pp. 241–258. Available at: https://www.academia.edu/5767340/The_structures_of_Atlantic_shipbuilding_in_the_16th_century._An_archaeological_perspective (Accessed: 2 March 2015). Logan, M. (2013) A study of a 16th-century wooden vessel from the Netherlands. Master’s Thesis. Maritime Archaeology Programme. Maritime Archaeology Programme University of Southern Denmark. Available at: http://www.maritimearchaeology.dk/downloads/Logan%202013.pdf (Accessed: 2 April 2015). McCarthy, M. (1983) ‘Ships fastenings (A preliminary study)’, Bulletin of the Australian Institute for Maritime Archaeology, The, 7(1), p. 1. McCarthy, M. (1996) ‘Ships fastenings: a preliminary study revisited’, International Journal of Nautical Archaeology, 25(3–4), pp. 177–206. Available at: https://doi.org/10.1111/j.1095-9270.1996.tb00770.x. McGrail, S. (2015) ‘Hornell, Hasslöf and Boatbuilding Sequences’, International Journal of Nautical Archaeology, 44(2), pp. 382–387. Available at: https://doi.org/10.1111/1095-9270.12116. Mitchell, A.M. (1994) A Comparison of Wood use in Eighteenth-Century Vessels. Thesis. East Carolina Univeristy. Available at: https://thescholarship.ecu.edu/handle/10342/6639 (Accessed: 8 December 2020). Moser, Jason D. (2011) ‘The Art and Mystery of Shipbuilding’: An Archaeological Study of Shipyards, Shipwrights and Shipbuilding in Somerset County, Maryland 1660-1900. Electronic Theses, Treatises and Dissertations. Florida State University. Available at: http://diginole.lib.fsu.edu/etd/index.64.html#year_2011 (Accessed: 15 February 2015). Murray, C. and Manders, M. (2007) ‘The interpretation of the Anglo-Dutch East-Indiaman Avondster ship’s construction’, in Excavation Report of the VOC-ship Avondster (1659). Centre for International Heritage Activities, Special Publication No. 1, pp. 131–153. Available at: https://www.academia.edu/21298400/The_interpretation_of_the_Anglo-Dutch_East-Indiaman_Avondster_ship_s_construction (Accessed: 2 December 2019). Myers, M. (1987) The Evolution of Hull Design in Sixteenth-Century English Ships of War. Thesis: MA. Texas A&M University. Available at: http://nautarch.tamu.edu/Theses/pdf-files/Myers-MA%201987.pdf (Accessed: 18 March 2015). Nowacki, H. and Valleriani, M. (eds) (2003) Shipbuilding practice and ship design methods from the Renaissance to the 18th century: a workshop report. Preprint 245. [Berlin]: Max-Planck-Institut für Wissenschaftsgeschichte. Available at: https://www.mpiwg-berlin.mpg.de/Preprints/P245.PDF. Oertling, T. (2001) ‘The concept of the Atlantic vessel’, in Proceedings. International Symposium on Archaeology of Medieval and Modern Ships, pp. 233–240. Available at: http://www.patrimoniocultural.pt/media/uploads/trabalhosdearqueologia/18/. Olaberria, J.P. (2013) Hull-shape design in antiquity: how do archaeological ship remains enhance our understanding of hull-shape design in antiquity? A dissertation submitted in partial fulfilment of the degree of Master of Arts in Maritime Archaeology by taught course. University of Southampton. Available at: https://www.academia.edu/9533850/Hull_Design_in_Antiquity._Masters_Dissertation (Accessed: 28 February 2015). Olaberria, J.-P. (2014) ‘The Conception of Hull Shape by Shell-builders in the Ancient Mediterranean’, International Journal of Nautical Archaeology, 43(2), pp. 351–368. Available at: https://doi.org/10.1111/1095-9270.12068. Ossowski, W. (2008) ‘The ship’s construction and equipment’, in The Shipwreck General Carleton, 1785. Gdansk: Badania Archeologiczne Centralnego Muzeum, pp. 131–150. Available at: https://www.academia.edu/2324215/The_ship_s_construction_and_equipment_In_W_Ossowski_Ed_The_Shipwreck_General_Carleton_1785_Badania_Archeologiczne_Centralnego_Muzeum_Morskiego_t_I_p_131_150 (Accessed: 30 September 2022). Pevny, T. (2011) ‘Historic Naval Architecture Practices as a Guide to Shipwreck Reconstruction: The La Belle Example’, in A. Catsambis, B. Ford, and D.L. Hamilton (eds) The Oxford Handbook of Maritime Archaeology (Chapter 12) edited by Alexis Catsambis, Ben Ford & Donny L. Hamilton, pp. 267–285. Available at: https://www.academia.edu/42997341/Historic_Naval_Architecture_Practices_as_a_Guide_to_Shipwreck_Reconstruction_The_La_Belle_Example (Accessed: 25 July 2020). Pomey, P. (2004) ‘Principles and Methods of Construction in Ancient Naval Architecture’, in F.M. Hocker and C.A. Ward (eds) The philosophy of shipbuilding: conceptual approaches to the study of wooden ships. 1st ed. College Station: Texas A&M University Press (Ed Rachal Foundation nautical archaeology series), pp. 25-. Available at: https://www.academia.edu/20268228/Principles_and_Methods_of_Construction_in_Ancient_Naval_Architecture_full_version_replacing_and_cancelling_the_previous_one_. Riess, W. (1987) The Ronson ship: The study of an eighteenth-century merchantman excavated in Manhattan, New York in 1982. PhD Dissertation. University of New Hampshire. Available at: https://scholars.unh.edu/dissertation/1527. Rose, S. (2011) ‘Digs and Documents: Gaps in our knowledge of medieval shipping’, The Mariner’s Mirror, 97(1), pp. 63–76. Available at: https://doi.org/10.1080/00253359.2011.10709032. Steffy, J.R. (1975) ‘Nautical Archeology: Construction Techniques of Ancient Ships’, Naval Engineers Journal, 87(5), pp. 85–91. Available at: https://doi.org/10.1111/j.1559-3584.1975.tb03773.x. Steffy, R. (1995) ‘Ancient Scantlings: The Projection and Control of Ancient Hull Shapes’, in H. Tzalas (ed.) Tropis III (Proceedings of the 3rd International Symposium on Ship Construction in Antiquity). Hellenic Institute for the Preservation of Nautical Tradition, pp. 417–428. Available at: https://www.academia.edu/12867722/1995._Ancient_Scantlings_The_Projection_and_Control_of_Ancient_Hull_Shapes._Tropis_III_Proceedings_of_the_3rd_International_Symposium_on_Ship_Construction_in_Antiquity_H._Tzalas_ed._Athens_417-428 (Accessed: 4 January 2017). Steffy, R. (2001) ‘The development of Ancient and Medieval Shipbuilding Techniques’, in Proceedings. International Symposium on Archaeology of Medieval and Modern Ships, pp. 49–62. Available at: http://www.patrimoniocultural.pt/media/uploads/trabalhosdearqueologia/18/. Unger, R.W. (1973) ‘Dutch Ship Design in the Fifteenth and Sixteenth Centuries’, Viator, 4, pp. 387–412. Available at: https://doi.org/10.1484/J.VIATOR.2.301656. Unger, R.W. (2011) ‘Dutch nautical sciences in the golden age: the portuguese influence’, E-journal of Portuguese History, 9(2), pp. 68–83. Unger, R.W. (2018) ‘Shipbuilding, Knowledge, Technology And Heritage Portuguese Shipbuilding & Low Countries : Practices. Iberian Influences In The Dutch Golden Age’, in A. Polónia and F.C. Domingues (eds) Shipbuilding. Knowledge and Heritage. CITCEM, pp. 159–176. Available at: https://ler.letras.up.pt/site/default.aspx?qry=id024id1648&sum=sim (Accessed: 26 October 2022). Verweij, J., Waldus, W. and Holk, A.F.L.V. (2012) ‘Continuity and change in Dutch shipbuilding’, Journal of Archaeology in the Low Countries, 4(1), pp. 65–93. Zwick, D. (2014) ‘Conceptual Evolution in Ancient Shipbuilding: An Attempt to Reinvigorate a Shunned Theoretical Framework’, in J. Adams and J. Rönnby (eds) Interpreting Shipwrecks — Maritime Archaeological Approaches, pp. 46–71. Available at: https://www.academia.edu/6640960/Conceptual_Evolution_in_Ancient_Shipbuilding_An_Attempt_to_Reinvigorate_a_Shunned_Theoretical_Framework (Accessed: 8 March 2015).
  19. While this specific set of questions is worthy of discussion, your diatribe attacking Ab Hoving is lacking substance. His credentials are strong, with many published academic works in addition to his books. 29 years restoring museum models would involve broad familiarity with archival material. While you may disagree with his conclusions, that does not make them wrong. Could you build a boat based on Witsen? Yes, with some assumptions regarding missing or strange information. Does his treatise meet modern standards? Heck no - he could use a good editor!
  20. One must understand the era during which these treatises were prepared before passing judgement on the source. Witsen was documenting in a written form what was primarily institutional knowledge among the shipwrights of the time. Not so different from the Newton manuscript or, for that matter, the many 18th century works such as Steel or the various encyclopedia entries. Citing of references is a much more modern concept. Is Michael of Rhodes any less credible for not citing the more ancient sources?
  21. The Livro Primeiro de Arquitectura Naval (First Book of Naval Architecture) has been dated between 1608 and 1615, and is generally considered to have been written around 1600 by João Baptista Lavanha, the Chief Engineer and Chief Cosmographer of the kingdom of Portugal at that time. It is the theoretical work of a scholar, and not a practical text of a shipwright. It deals only with one type of vessel: the four decked nau for the India Route. It is clearly more modern than Oliveira’s Liuro da Fabrica das Naus, basing the construction of hulls on paper drawings. Nevertheless, Lavanha calls for the need to pre-design a central portion of the hull, although only for five frames forward and abaft the midship section. The importance of this treatise lies in its accurate description of construction techniques, and in its detailed illustrations. It is incomplete, ending abruptly in the beginning of a description of the drawing of plans. Both Lavanha's and Oliveira's works are availble from the Academia de Marinha, the cultural agency of the Portuguese Navy under the Chief of Naval Staff. Its purpose is to promote and to publish artistic, literary, historical, and scientific studies relating to the sea and maritime activities. For those that are able to read Portuguese, there are a number of other items also posted. I thought these two early manuscripts may be of interest. While Lavanha has been translated, Oliveira has not. Some sections of Oliveira have been transcribed while others are facsimile of the original handwritten treatise. Lavanha, J.B. (1610) ‘Livro Primeiro da Architectura Naval (First Book of Naval Architecture)’. Translated by R. A. Barker. Available at: https://academia.marinha.pt/pt/edicoes/Paginas/Reedições.aspx (Published by the Academia de Marinha, Lisbon, 1996, as a facsimile, transcript and translation; and including the 1965 commentary by Dr João da Gama Pimentel Barata, revised and updated from his notes on a draft translation in 1986; together with further annotation by the translator). (Accessed: 2 November 2022). Oliveira, F. (1580) ‘Livro da Fabrica das Naus’. Available at: https://academia.marinha.pt/pt/edicoes/Paginas/Reedições.aspx (Published by the Academia de Marinha, Lisbon, 1991, as a facsimile, partial transcript). (Accessed: 2 November 2022). Original images available at https://purl.pt/6744 where a 719MB PDF may also be downloaded. Barkers on-line translation of Lavanha (same as in the book) can be found on his website here (he has several very nice items there, including what appears to be a partial translation of Oliveira here....)
  22. I heartily recommend the book "Those Vulgar Tubes" for a tour of the various designs. Did they always use them? Probably not always, but who knows?
  23. The two pieces may or may not be related. The Mary Rose (1509) exhibits some unique components of the frames that seem to not represent the Mediterranean skeleton- first construction. Barker has some interesting, and well documented, analysis concerning design methods, as do Steffy and Unger which acknowledge the similarity between northern shipbuilding and Mediterranean, but also note the important differences. Being able to utilize mathematical and graphic methods to fit curves onto sections derived through other design systems is interesting, but coincidence does not equate to causality. I think there are some intriquing aspects to what you are doing, however discounting the work of previous researchers, some with hands-on experience with vessels such as the Mary Rose, presents challenges. The question becomes one of cart and horse, whether the design methods known to be in use at the time period in question or the building systems were the determinant of shape, since drawings were not known to be used.
  24. The detail on the midship mould addressing folio 35 that are more complete. I would love to see either a complete transcription or digital version of the full manuscript. Adams notes that after the early highly decorated folios the remainder reads more like a guide for an apprentice - more technical and mathematical. The later sections (probably added by Wells) incorporate logarithms, dating those parts as post 1610 or so.
