slackwater
717 profile views
  1. Should have re-read before I posted. Bad typos. I can spell
  2. OK, for frame 1 pattern you show that the floor is sided at 14", then the 2nd futtock at sided at 13" and so forth. So I have the the thickness for each piece cut at that thickness. Now, when I go to glue each section down on the plan the varying thickness of forward and aft pieces they are not flat. Their is a gap between the aft and forward pieces because of the varying thicknesses. I would think that the aft and forward sections of the frames should lay flat on each other? I'm I missing something? Or do I have this done correctly? Thanks! Big time.
  3. Ed, I bought your book and have started the build. I'm now constructing the square frames, would you be available for contact to answer some questions?
  4. Hi Ed, I love the flexible screw clamps and would like to create them myself. I can't find a source for the .112" brass rods. I searched online many places and coming up with blanks. Have any suggestions for sources? Thanks!
  5. I just bought your book and it's fantastic. I'm strongly considering it for my next build. I saw the mini wood hand screw clamps throughout the book and wondering where you got them? Mark
