NJQUACK
Everything posted by NJQUACK
  1. Very inspirational. Great work. Walter
  2. Hi, Just a quick update. The rigging is underway. And thank you everyone for all the likes. Walter
  3. Hi, I would like to thank everyone for all the likes. I’ve added the rails and looking forward to starting the rigging. Walter
  4. Hi, Just a quick update. The deck furniture is moving along with the mast and spars. Walter
  5. Hi, I would like to thank everyone for all the likes. I’ve completed the deck planking and some additional paint work. Walter
  6. Hi, It’s been a busy week. The deck is almost complete. The first color of paint has been applied to the hull and a mast has been test fitted. Walter
  7. Thank you Bensid54. Building with raw material at hand is quite an experience. In a Zen like way I think it gives me a better understanding of shipbuilding. Walter
  8. Hi, Just a quick update. The deck beams are now installed. Walter
  9. Elijah, A sandbar is a raised area of sand. At high tide around here they are under water. At low tide many of them are above water and appear as Islands or larger land masses. Walter
  10. Thank you Bob and Elijah. I sure did a happy dance. There were two small leaks which are now patched up and nothing fell apart in between soaking and drying. When she's complete I'm looking forward to taking her out to the bay at low tide and letting her sail between sandbars. Walter
  11. Hi, Got some work done on the rudder. I also had to see how it would float. I’m thinking of making this a very small pond yacht. Walter
  12. Hi, Just a quick update. The centerboard and case have been installed. I would also like to thank everyone for all the likes. Walter
  13. Hi, The planking is complete, and two frames have been cut to allow for the centerboard and case. Walter
  14. Hi, Yes the bamboo is cooperating so far. The planking is moving along. Walter
  15. Hi; Welcome aboard bensid54. Just a quick update, the planking continues. Walter
  16. Thank you Elijah and everyone for the likes. I’ve added the transom and started the planking. Walter
  17. Bensid54, Cutting the lengths are easy, I use a pair of wire cutters. A good crimp will cause a nice split down the length. Once the split has started just pull it apart. A finishing plane and sand paper are use to complete the plank. From my bamboo I can get 9 inch (230 mm) lengths. Walter
  18. Hi, Thank you Bensid54 and David. The type of Bamboo I'm using is Yellow Grove. So far so good. This type has a nice flat spot which is allowing me to make some nice wide planks which will come in handy for spiling. Walter
  19. Hi, I made a jig out of foam board to hold the frames and keel. I’ve begun gluing the frames to the keel. The frame making continues. Walter
