firdajan
Everything posted by firdajan
  1. Thanks friends for your replies ! Louie da fly: All my ships are with sails. Maybe there´s some kind of magic for me And, yes, you´re right. flying dutchman2: thank you Yes, fluyts were unique vessels , I think I did a good choice. Sails are made. I used a piece of silk shirt. At first I impregnated the cloth using the mix of glue / water 1/20. After drying I flat it, and cut sails out. Then you can glue threads. Then I punctured sails for hanging, impregnated them once again and forming by fohn. That´s all. But it took a while. Jan
  2. Thank you friends for your replies. Louie da fly: I don´t think it´s close to complete - I have to make the most important equipment for the sailing ship - sails and do the second part of running rigging, that´s quite a lot. tkay 11: decks are made of strips of foils, and patinated with anilin water colors, then coated with matt colorless paint. see pics below. Bowsprit is finally finished and rigged, I hope I did it right. And now, as I mentioned, I can to start to make sails. Jan
  3. I finished the first part of running rigging for masts. Now I can finish the bowsprit and rig it too ☺️ Jan
  4. Almost all yards are on their places, just topsail spritsail yard is not. I´ll hang it at last ( I broke sprit topmast twice ). I´m still continuing with running rigging. Jan
  5. Work in progress. Completing parrals and hanging of yards. Jan
  6. Thank you, friends, for your replies. Louie da fly: probably yes, if you have as a cargo some logs or planks or boards, you need a place. But if you want to know more, please ask Abhovi. I completed all the yards 😊 and start to make ribs for parrals. I also ordered 1,4 mm beads for them. And I have to produce some blocks...a lot of blocks... Jan
  7. It took me a long time ( because of different reasons ) to continue, but I´m still working on the ship. Masts and standing rigging are completed. Jan
  8. Tops and stays fixed. Now I can continue to build the next level of masts. Jan
  9. My friends... I finally found a time for continuing...and made some deadeyes and tops, so I could start with standing rigging. I hope to have more time now. Jan
  10. yancovitch: no... just masts, yards and sails....thank you. Jan
  11. michael mott: Thank you, Mike. Dear friends, the hull is finished. Now I can continue with propulsion ( it means, btw, to produce a lot of my lovely deadeyes ) Jan
  12. Thank you, friends. Chuck Seiler: the lenght of the wreck is 38,1 m. The lenght overall incude the bowsprit based on the plans is cca 47 m. Jan
  13. Thank you, friends, for your comments. Daniel Caramango: some carvings are cutted from paper, then hardened by superglue, figures are made from modurit - it is the plastic modeling mass hardening by boiling or baking. I made some parts of decoration - roman soldiers ( I hope it looks like soldiers, I´m not very good sculptor and figures are just 25 mm long ), pedestals, molding on the stern and two little carvings on the bow, catheads, gun carriages ( simple ones I glued inside the ship ) and gun barrels. Just gunports lids and the lamp are missing. Jan
  14. Omega1234: Thank you, Patrick. Anna Maria and curtains on the stern, deck and lion on the bow are added. Jan
  15. Thank you, friends Matle: very interesting hypothesis.... I made windows and started with decoration on the aft. Jan
  16. Thank you, friends. dgbot: I´m using Revell colors for plastic models. Some details are added on the deck for the running rigging. I also made and glued channels. Jan
  17. Thank you very much for your kind words The handrail is finished. You can see the result on following pictures - I´m quite satisfied. Now I have to repaint the inner part of sides by matt uncolored paint to remove traces of glue and I can continue with the equipment of the maindeck. Jan
  18. Heloo my friends, Don´t be afraid, I´m working slowly, but I´m working still I made paper prisms 1 x 1,5 mm, impregned them by superglue and colored. Then I used them to make ribs - now I´m prepared to finish handrails. I also glued both sides of galion. Jan
  19. Thank you a lot Finally I made something on the ship. I started with the construction of the bow and cut out a piece of decoration. I also made the windlass. I´m working slowly, but still Jan
  20. Thank you a lot, my friends, for your replies.. Sorry for late answering, but I have a lot to do this year, but no ship models.....I finally created something ... wales and some parts on decks and hull. Please be patient, the next progress will follow Jan
  21. And... after several months I finally found a little time to continue on the model. I made some doors, keel and improved planking on the lower part of keel considering to plans and Ab´s instructions ( I´m consulting build with Ab Hoving ) . I believe I will have much more time next months. Next pictures shows the ship today. I will continue with wales and some parts on decks. Jan
  22. I continued with imitation of planking.I made it as always - using strips of foils ( after gluing of strips I´m using hairdryer to heat foil for better adherence ). The hull was " too shiny " , I patinated it to make a planking effect using aniline water colors. and colorless matt varnish. Then I painted bottom of the ship. It looks like gunports are too close to watreline - but it si exactly based on plans. Gratings you can see are laser cutted.
  23. I continued with clinker planking. I used 2,5 mm strips of 0,5 mm cartoon and glued them 0,5 mm each on another to make clinker effect. Then I colored it by red colour. Then I glued the 1 st wale and some planks.
  24. Then I continued with gunports and inner parts of planking - each side was made from three parts.
  25. The final layer of planking followed - I used 4 mm strips of 0,5 mm cartoon - you can see it on the 1 st picture. Then I sanded it, smoothly putted and sanded it again - the hull was extremely solid and smooth.
