Ilhan Gokcay
Everything posted by Ilhan Gokcay
  1. Rigging of anchor davit and davit for accommodation ladder.
  2. Completed the rigging on the masts. I will not glue the masts. They will have a tight fit. I used diluted white glue for the rigging. Takes time but better than CA which is too stiff and probably not durable.
  3. Tent stanchions and flagstaff made of brass profiles, rods, tubes.
  4. All parts finished. Happily back to hull. I finished the rail at forecastle. I've cut the shape from 6 mm pear sheet, fitted, surfaced, outfitted and glued.
  5. Various parts -Belaying pins -Fairleads -Bilge pump -Ladder to the bridge -Ladder to the forecastle -Cradle for steam launch
  6. No Pat, sorry, my mistake. I did not have photo etching at this "Loreley" log, it was here. I shared here how I've done it.
  7. Hi Pat, they are photo etch parts. I did share previously how I do them. Blue transfer paper, Fe3CL,...
  8. Turnbuckle, cathead, bollard. Made of brass, acrylic, polystyrene.
  9. To get the keel (0,75x0,75mm plastic strip) straight I made a straight edge and glued the strip with polistyren glue. I have most problems with the frames and getting them aligned. After several failed attempts I made a plug/core of the boot and cut it at the intervals of the frames. So using these mould parts as a template I managed to fix the frames exactly aligned and square to the keel. I press the plastic strip (0.25x0.75mm) to the mould and let tiny drops of CA to penetrate at the side. One by one and step by step.
  10. Thanks shipman. It's polystyren sheet initially 0,75 mm thick. After forming it reduces appr. to 0,5 mm's.
  11. I've started to build the boats. There are 6 boats and they are all made of polystyren sheets with vacuum thermoforming.
