Everything posted by matiz
HMS EURYALUS by Matiz - FINISHED - scale 1:56
matiz replied to matiz's topic in - Build logs for subjects built 1801 - 1850
Thanks to all .... Allan, I try to combine wood with different shades, but I also darken the part to be glued with a pencil -
Thanks to all ☺️, the hinges are soldered with tin, therefore, soft soldering, I found a suitable tube, but I think I will redo them, as they are a bit big, the doors I made them as in reality, with uprights in which I practiced the mortises, the crossbars in which I made the tenons, the lower drafts, which fit into a groove, and the irons, wedged between the crossbars -
Hi, Allan, for the lower deck I use the usual type of pear tree, only for the frames of the openings and trees I use a pear of a different color, I try to play on the tone to show the composition of the various pieces -
Thanks to all ❤️ -
I reduced the plans myself -
Hello Many years ago I built Boudriot's 74 guns, and, due to space and transport problems, I chose the 1:56 scale, building the Euryalus, I wanted to keep the usual scale 😊 -
HMS VICTORY 1765 by albert - 1/48
matiz replied to albert's topic in - Build logs for subjects built 1751 - 1800
Bravissimo Alberto -
Hi, Albert, beautiful work🙂 -
Hello, and thank you, the plans are those of the monograph published by Sea Watch -
Tanks Alberto, and tanks to all
