MikeR
Members-
Everything posted by MikeR
Thanks everyone, I appreciate all of the comments. On my wood lathe I turned 56 small stanchions plus a few extras for the taffrail, and installed them and the railing along with the steering box, binnacle and the storeroom hatch. On the aft cabin the iron railing was installed, well brass in this case. I did not like the way the plans show the aft pin rails in the actual taffrail. I added the pin rails to the sides of the taffrail. .
This is how I made the steering wheel. I do not have an index table, so this is what I came up with. I made a slide table for my Brynes table saw and mounted 2 wooden blocks 1 inch away from the center of the saw blade. I then made a drawing of the steering wheel and extended the centerline of each spoke, and used rubber cement to glue it to a block of wood. I then attached the wood and pattern to the slide table with double sided tape making sure the centerline was lined up to the edge of the ruler. With the blade set to the proper height I made the cut. I did this for the next 5 cuts. I then cut out the center hub and ring with my scroll saw. Then I added the spokes. Using an index table would have been a little more accurate but this worked all right for me.
Allan The head diameter of the screw is 1.75 mm, the threaded diameter is .95mm, and the diameter of the nut (flat to flat)is 2.4mm MikeR
Mark I recently purchased 1mm brass nuts, 50 for under $2.00 and 1mm machine screws, 50 for under $1.00 from AliExpress.com The only problem was the delivery time. It took about 8 or 9 weeks to arrive from China. MikeR
Keith I turned 5 mast and was satisfied with the last 2 which I used the chuck at the dead end. Of the 3 that were rejects one was ok but not great and the other 2 were bad. The mast core is 1/4" square, I used diagonal lines to find the center, then center punched it and fit the to the live center. after they were turned I noticed the center mark was enlarged and moved slightly off center. I do not have any problems like this when I turn larger stock. Keith I am following your Schooner Germania build and wish I had some of your talent in wood and metal work. Mike
DN Iceboat by MikeR - FINISHED
MikeR replied to MikeR's topic in - Build logs for subjects built 1901 - Present Day
Greg Thank you for the offer Greg, but I am not ready to sale any of my models just yet. Mike
