MikeR
Members-
Everything posted by MikeR
I started to work on the skylights for the aft cabin. I was thinking how am I going to drill the 10 boards that hold the bars so that the holes all line up. So this is what I came up with. I glued 6 boards together and after they were dry, I used an indexing table to drill even spaced holes. I made a few extra in case of mistakes. They were then cut apart, sanded, and wire passed through the holes while the boards were still glued together. Then I soaked them in alcohol for 10 to 15 minutes. They came apart without much trouble. I inspected the boards and removed one since I only needed 5 boards per side for the skylight.
I am still working on the aft cabin and I finished planking the hull. I added a few rows of copper plates well copper tape really, until I ran out. I tried to find brass tape and the suppliers that handled it were out of stock, so I ordered copper. The Flying Fish had yellow metal plated instead of copper.
The planks I am using for the upper hull are dogwood. They started out as a 6" X 24" log cut many years ago. I cut the logs into 1" boards with a band saw, then ran them through a planer. Using a Byrnes table saw I cut the boards into slightly over sized planks and then ran them through a drum sander.
After the bulkheads, bracing and support pieces for the bits were installed I covered the deck area with a thin layer of wood, to make it a lot easier to install the deck planking. Then I added the waterways and planksheers. The types of wood that I will be using are cherry for the hull planking under the copper plates. Dogwood for the rest of the hull , deck planking, and the masts, from trees that died in my yard from a disease that went through our area years ago. Bloodwood for the structure trim and ebony for the timberheads and railings. For the yards I will be using cocobolo.
Hello all In the early 2000's, I got the model Flying Fish and last December 13, 2021 I started the build. I enlarged the plans 50% to 1:64 (3/16 scale ) to keep it the same scale as my other models. I used rubber cement to glue the patterns to 1/4" plywood. I then separated them with a scroll saw and proceeded to cut them out. I tapered the bulkheads and then attached them to the center keel piece.
Tally Ho by jwpage - Scale 1:16
MikeR replied to jwpage's topic in - Build logs for subjects built 1901 - Present Day
If you are still looking for a supplier for micro nut, screws, taps, and drills check out Tabco Optical. ( tabcooptical.com ) I purchased 100 M1.4/1.4mm nuts for $5.95 I made eye bolts out of 3/64 rod and used these nuts. I retapped these nuts with a 1.7mm tap for use with 1/16 rod. I enjoy following your build and the purple heart looks great. -
source for steel bar stock?
MikeR replied to Griphos's topic in Modeling tools and Workshop Equipment
Griphos I have been using these clamps and I have had no problems with them flexing. I tighten them as much as I can turn the knurled nut by hand and they hold the deck planks to the beams with no flex. Mike -
