Ian_Grant
Everything posted by Ian_Grant
  1. Just recently started this kit after finally finishing Heller 1/100 Victory. What a change from 18th century rig and cannons. Long narrow all iron hull with midship bridge. Five iron masts. The decks are crammed with machinery such as manual brace & halyard winches and several capstans.. Kit Summary: Hull halves were crammed across the kit box diagonal; I think they must have wanted to use the same box size as the Passat kit. The stem and lowermost rudder mount were bent because the diagonal really is slightly too small. Kit includes thermoplastic sails. Kit does not include blocks, or any representation of turnbuckles for shrouds and backstays. Aside from sprues holding the 5 decks (foc'sle deck, fwd well deck, bridge deck, aft well deck, poop deck) and some hatch covers, there are only six parts sprues four of which are identical - a very tiny pile compared to the ~21 unique sprues for Victory. The instructions are good for assembly, with many fine diagrams showing what goes where, but rigging details are sparse. The good news is that Heller did not scatter the rigging instructions all through the assembly drawings but instead devote several drawings at the end to rigging: stays; shrouds and backstays; lifts and braces; buntlines and halyards. The bad news is that belaying points are in Heller's patented microprint. Also the proper connection of Jarvis brace winches is not shown i.e. leading blocks. At this point I must mention that Heller's engravers depicted the steel hull plates nicely, but they mysteriously disappear below the waterline. It bothered me enough that I bought Evergreen 0.005" sheet and cut it into plates which I glued on individually, in a double layer every 2nd row to simulate the riveting overlaps. It looked like hell at first, but after some caulking (acrylic painter's caulk squeezed out of the tube via a very small hole drilled in the cap end to provide a very small bead) and painting it actually turned out pretty well. I have joined the hull halves and painted the black/white/red colour scheme. I have painted and washed and varnished the decks and I am busy painting various bits of deck machinery and steel bulkheads. I need to attach it to a stand before gluing in the decks, though. One question for anyone who may have built this kit: there is a little auxiliary bridge on the after storm gangway with a second binnacle. Around two sides of this bridge there are rows of something similar to plant pots (?!) outside the railings. They are hollowed out. They do not appear to be for something to glue into as far as I can see in the instructions. Anyone know what they might be? The only thing I can think of is, possibly, fire buckets? I will try to figure out how to attach some pictures later; it's late now.
