Jackson7
Everything posted by Jackson7
  1. Also, I found a picture of a model of the Greyhound made at the time of its actual existence. While it looks somewhat like the Corel kit, there are several big differences. For a start, the foremost aperture in the hull doesn't have a cannon in it, and it has an additional stern gunport with a cannon extremely near the cabin window. You can clearly see the oar ports above the gunwale. There aren't any roped-off walkways on deck. I'm sure you guys can spot more. https://live.staticflickr.com/65535/50950227046_c02a816bd9_b.jpg
  2. I ran into a bit of trouble. The good news is I was able to put the wheel on and add in all the belaying pins. I accidentally broke off the mast base near the wheel, and it's such a bother than I plan to put it onwhile it's around the mast. I'd recommend doing this step (or at least drilling the holes for it) before putting the quarter deck on. I had to use a thumb tack to press holes in the hull where a drill couldn't reach. The bad news is that I kinda damaged my work on the top deck trying to put in railings. And then I discovered that there's no way they are comfortably at 1/100 scale. I've calculated that they would be nearly 5 feet high. Rope railings at neck level are uncomfortable at best. At worst, they're a way to combine strangulation with falling down the stairs. Given that I doubt my ability to drill holes to contain them and that they are too big, I'm just going to eschew railings. Safety regulations were probably not high on the priority list in 1720 anyway.
  3. Sometimes it's the little things that make a ship come together. I bought some 3 mm high letters from Walmart to put the name on the stern. After some cleaning, sanding and painting, they were ready to place on. They give the stern that last little spark of color it needs to work. I've discovered that the bow might be too crowded to fit the front two guns. I might be able to work around it, but it's likely I'm making an 18-gun ship. No big deal though.
  4. Why work from a kit when you can take four times as long doing it yourself? Slowly, carefully, I have carved wooden deck pieces for every parrt I've felt capable of carving. It's worked great. They look way better. Putting into the deck was frightening. I drilled hoes in the deck where they attached, then carved the ends of the square pegs into circular shapes. They went into the holes fairly easily. It was much better than trying to carve square holes to put them into. Now, I have just the back rail and the little railings for the stairs.
  5. When the metal bannister provided by the kit didn't fit, I built my own. It may be the best bit of carving I've done yet on this insane project. It looks far more natural than the original. Now, I just have the other railing and all the wood knighthead things in the center. We'll see just how they go.
  6. I settled on carving the knightheads myself. Now, 22 tiny carved knightheads later, I'm done with all the ones that attach to the rail. Of course, the metal front railing doesn't fit, so I'm carving that too. And I'm probably going to carve the 8 additional knightheads that go near the masts. They're simple to do. All you need is a sharp X-Acto knife and a lot of persistence. I also put a thin veneer over the false deck at the bow and the stern. It looks much better. Hopefully this phase will go much more quickly after I'm done with the ridiculous amounts of tiny carvings. At least I've preemptively assembled the gun carriages. Also, if anyone can provide photos of where all the cleat hitches attach, I would be very grateful. I don't trust the kit drawings at this point.
  7. I've passed a milestone. Every piece of wood that remains to be glued onto the ship is either a deck furnishing or part of the masts. I have realized that for the deck furnishings, I'm better off carving my own knight heads from 2mm by 2mm than using the kit's metal ones. It will be just as much trouble to cut metal to shape as to cut wood to shape. Before I begin that arduous task, I'm gluing the gun carriages together. So far, they're looking great. Blackened brass was the way to go.
  8. Good to know. You're right, there's really nothing for it now. There's so much to learn on this ship.
  9. I've successfully attached the chainwales and deadeyes to the ship. After coating them in some protective metal wax, they look almost exactly as I hoped. To avoid splitting the gunwale wood, I drilled tiny holes for the nails to enter. Right now, I still need to put on the wood that holds them in place. I think they're going to be the last wood I need to glue onto the outside hull.
  10. Hey y'all, I've returned at last. I didn't like the brightness of the brass on many of the ship's pieces, so I blackened them all with Birchwood Casey Brass Black. It generated a cleaner result than painting them. The process was arduous. I cleaned them off with steel wool and denatured alcohol, soaked them briefly in brass black, let them dry, then coated them all with Birchwood Casey gun stock wax. The resulting color is impressively solid, and it's not worth going back to fix the few small problems. If someone else chooses to use this method, they should blacken the brass in small batches. I think that gives a better result.
  11. I finished cutting out new bow pieces. They only have one hole, but that's because they broke while I was drilling the hole out. They were so much work and so risky to createthat it wasn't worth it to take another attempt.
  12. I'm working on the task of cutting out two new bow pieces. With a great degree of effort, I've succeeded in carving a piece of wood from my cutting board to the right shape. With two more cuts, I'll have the shape correct.
  13. I couldn't resist; I started another step. I've put on the figurehead and a bit of the bow ornamentation. Unfortunately, one of the two big pieces broke. It wasn't the right shape, and trying to bend it and file it into submission went wrong. I'm now thinking of replacing it with carved wood. I'll keep you all posted on how it goes.
  14. I bit the bullet. I bought 40 chain plates from Agesofsail.com. Now, all I have to do is wait until they arrive.
  15. Thanks to @harlequin, I got advice that the ship instruction manual wouldn't give. I drilled the holes for the little copper pieces to go through. Frustratingly, one of them was just above my stern windows, so I had to make some adjustments and sand them down until there was room to put in the metal. The end result is hardly noticeable. In the end, it all worked out. Now I just have to do the chain plates. I'm out of 1x2 mm wood, so I had to cut and sand my 2x2mm wood down to size. Thankfully, that particular job is now done. It's boring enough that it doesn't merit a photo. Just cutting it to shape with an x-acto knife, then putting sandpaper over a metal ruler and sliding the wood along this flat surface to file down the bumps. Of course, the chain plates present their own trouble. I think the metal plates that come with the kit are bad enough that I don't want to use them. It doesn't make sense to work for so long on something, then put on a bunch of parts that threaten to snap, and look like badly-cast metal. I'm not sure if I'll buy them online, or make them out of rope instead. @Srenner and @Gregory have pointed out to me that metal is likely more historical, which pushes me toward reaching for the Internet. Also, I need to buy more wood for a different project. A dear friend is getting married soon, and I need to build him a wooden chessboard. Given these difficulties and the impracticality of solving them with a knife, sandpaper and Hobby Lobby alone, It might take a while until I can execute the next few steps.
  16. Fascinating! I'm fairly sure now that I don't want to use the chain plates from Corel, simply for the reason that they are fairly terrible. Glad to hear the history seems to bear it out too.
  17. Hey Srenner, I'm curious about your build. Are you saying that in 1720, ship chainplates were usually rope, not metal? Or is it more a question of the Greyhound kit chainplates being poorly made? I'm working on the Greyhound, and am very discontent with the kit-issued metal. I'm thinking of doing them with rope instead.
  18. The next few steps have required much thought, and advice from @harlequin. I'm grateful for his help, and plan to start them later, when I'm less tired. For now, I've amused myself with painting the figuredhead. A 3D print from my friend has far exceeded the original in quality. And some paint has put it to a whole different level. I thought that for a ship that sailed the coast of Africa, an African lady would prove lovely. For contrast, the original is below.
  19. I attached the rudder at long last. Supergluing metal to wood isn't something I recommend, but it's something that sometimes proves necessary. With enough sanding, cutting and gentle persuasion, I think it ended up working. I'm playing with the idea of using thread to hold the deadeyes in place. The metal loops need so much painting, and I'm not sure it's even plausible to paint something so small without loads of trouble with chipping, even if I plan to paint hardcoat over them.
  20. I just finished putting on the chain-wales. I supported them underneath with two small pieces of 2x2mm wood each. It was difficult to sand them to fit the curve of the hull, but the end product works well enough. I drilled holes in them where the pictures of the Greyhound show they need them. The instruction booklet should mention this part and advise builders to do it before putting them on the hull.
  21. Done with the transom's structural parts at least. I'll have to contemplate what to do with any potential decorations. I used the trusty boil and bend technique to put the cap piece in place. 2 hours in a thermos of boiling water, 24 hours being bent to shape between nails, and then 15 minutes or so of pressure to glue to the hull. Unfortunately, the 1x3mm cap piece was too short by a tiny bit, so I had to patch it over on the side. It's hardly noticeable though. My final verdict is that it looks far better than the original metal kit part. Far more natural, and definitely a better fit.
  22. The transom windows are now complete. Given that the 3d printing is just too big, I've settled for a simple framing design reminescent of the HMS Surprise. I'm not sure if I want to paint the window pillars or the wood pieces above or below the windows.
  23. One tiny piece at a time, I advance. Four left. Cutting 20 miniscule window bars to shape has been stressful and somewhat tedious. But I think the results justify themselves.
  24. The last few days have been productive. Before I put on the last two planks, I put the window pillars in place, aligned with the wood above the hull. Everything I've glued to the window was done using superglue. After the 2mm by 2mm pillars, I put on the 1mm by 1mm vertical window bars. I'm going to work on putting on the 20 horizonal bars over the next few days. After these steps, I put on the last two pieces of transom wood. Gluing them on was simple. I sanded them until they looked like a relatively smooth arch. I'll bend a cap piece over them after I finish the last few details.
