KORTES
Everything posted by KORTES
  1. Greeting my dear colleagues ! I'm very grateful for your high marks. I also have great respect for hand crafts, but when you need to cut several identical elements by hand, it's quite stressful.
  2. Dear Gery , all of your works are outstanding in their highest mastery and are a true delightful the eye. I'm very glad that we will have a chance to witness and see another great model from You. My very best regards.
  3. I have made two elements of the carving. Unfortunately I don't have a CNC. This is the result. For now everything is not yet fixed. . Assembly is yet to come.
  4. I have installed the beams and filled in the grate of the top flooring .
  5. Еvery craftsman will find it differently, for me making a latrine is the most difficult part of the model. The work will take a long time, so I will post the results by the way of proceeding. Have been working with the drawings , and made patterns. I decided not cut the elements out, but to bend in parts with the following gluing.
  6. I have made crambolas and boat davit. Fitting was without glue, I will install the boat davit later, so that they don't break off when i will working with the steering wheel.
  7. I have installed the gunwale. Now it is important to finally make the stern. Ahead is left the manufacture and installation of sloop beams and bollards
  8. I decided to change the covers of the ports .
  9. I've made nailing of the boards. And made the ports of the oar fairleads.
  10. Thank you my dear friends for the evaluation of my work.
  11. I was quite a challenge to make carved elements. Hornbeck is quite difficult to cut,it's quite strong and fragile , and the scale is a bit to small for me. The assembling is still to come and the fitting in place.
  12. I have prepared and adjusted the components of the stern shells in place.
  13. Thank you , my dear friends, for your support. My best regards
  14. I feel the inspiration has left me - I had so many unsuccessful tries.
  15. The result of the grinding is not yet very presentable. Beauty will appear only after coating with oil. I slightly moistened the hull to show the pins. It looks like this.
  16. I have finally finished the nailing of tge hull.One month of work , but almost nothing to show. Grinding is ahead.
