Hi Troy, sorry that you are having issues with planking. It is a painstakingly slow and meticulous process. I use a combination of soaking in water, planking tool and a template to bend the planks to fit. I only do one plank each day. You can use the plywood deck to get the shape of the first plank. Soak it in water for an hour or so, then starting in the middle bend it to the shape of the curve of the deck and pin or clamp it in place for 24 hours. Take it off and give it a final adjustment using the planking tool, then glue and pin or clamp it in place for 24 hours. You now have the first plank on and it is the perfect template for the next plank. I shape, soak and clamp the next plank to the first and leave for a day, and the process rolls on. Just be particularly careful not to leave any glue on the surface of the first plank when you use this method as it would be easy to end up with the two planks glued together. Additionally the timber strips supplied are not all the same so make sure to select a timber strip with a nice straight grain if you are wanting to bend it around a curve by whatever method. From your photos some of the supplied strips are cut partly across the grain. That is OK just keep those particular strips for planks that don’t require as much curve. Planking takes me a long time but there are plenty of other parts to be working on while the planks are setting to shape. Just be patient, take your time and most importantly have fun.
