Everything posted by Oliver1973
ancre La Belle 1684 by Oliver1973 - 1/36
Oliver1973 replied to Oliver1973's topic in - Build logs for subjects built 1501 - 1750
Hi, No. 1, the keel, is reduced as well. No. 2, this area is as well reduced to the bottom to get the common line to the keel. No.3 is not reduced in my modell. I have there a constant thickness in the whole area in the sternpost. I´think the "line" of the rabbet should be constant if you have constant thickness from the planking. The sternpost can be reduced, but the optical benefit is to small for the work, because the gaps and angle are to small in this area. My rabbet on the Keel an the stem could be deeper and more sharper. First model and first try.... you learn a lot of things, but for the next project. -
@Kranck Thank you for your interest in my project. Maybe you can show picture of the problem. Its´more easier to locate it. I started as well some tests in Rhino but as a genetic Catia-User i choosed to use my skills in this program and to continue with it. I checked a lot of CAM-Programs, as well the products from Aspire. I can´t remember but there was some points contra and my desicion was for Deskproto. I think the fourth or fifth axis.... i dont know more. My wood i bought on ebay in Germany. The name of the seller is Holzkarle. Regards Oliver -
Yes, there a lot of tutorials on YT. I have done a course as well on Udemy. Its not hard to understand, but its hard to train to get the skill for this kind of work. My "poor" CNC-Skill is selfmade. You learn it when you do it. -
The 5th timelapse from the constrction of La Belle is now online. -
Space, space, space..... its good to have. The table is a very good idea and a nice built. 👍
29 Floréal CCXXX; The last frame is raised and I removed the support board. Now we see the beautiful lines of this ship. I started to sand the inside of the hull to get the smooth and correct shape. @garyshipwright Thank you very much. But with your project and your skill, you doesn´t need any inspirations from others.
