KurtH
Everything posted by KurtH
  1. Lifts rigged. This completes the rigging of the fore yard except for the braces which will be added later. Loose ropes in the background are cast off backstays. Now to tackle the main yard. This should go a bit faster now that I have some idea of what to do, and what not to do. My plan is to do all the course yards, then the topsail yards, etc.
  2. Sling, lower jeer blocks, and standing end of the jeers installed on the yard. A view of the fore yard in place with sling installed and jeers rove. Before I reeve the lifts, I will replace one of the blocks so that they both hang down the same. My first attempt at rigging a truss. The tackles are at the mast cap instead of on deck because there was not enough room between the topsail sheet bitt knees to accommodate them. I ended up painting myself into a corner and having to improvise as best I could. The next one should be better. Practice makes perfect.
  3. I am back in the saddle. Here is my idea of how to hold a yard while working on it using Quad Hands and a couple of clamps: And here is my first attempt at foot ropes using .008" Syren rope: I did the starboard side first. I got better at making those tiny loops as I did the port side as you can see. I have the jeer blocks stropped, and the sling assembly ready to install. I still have to make up the blocks for lifts, and braces, and reeve the jeer fall. I will post the result.
  4. I found the size of the jeer falls. It is 4.5" in circumference. At scale, that would be .015" in diameter. I will use Syren's .018".
  5. Thanks for the info! I did consider .005", but chickened out and am proceeding with .008". I have done the footrope on the starboard half of the fore course yard, and am pleased with how it came out. I will post a photo when I have the truss, jeers, lifts, and sling in place. Speaking of which, the instructions give the size rope for the jeer pendants, but not the running component of the jeers. Do you know what that would be? I am guessing .025(?). I have to stop now, as I am preparing for a video job. Constitution will be in "ordinary" for a few weeks.
  6. Thanks! Dividing that by 96, I get .0078, so .008 size rope should be right. That's what I thought, but it is nice to be sure. Very nice job on the Alfred. It looks as challenging as the Connie.
  7. Can anyone out there tell me what diameter rope was typically used for footropes? My instructions do not have it. None of my books on ship model building have it. I cannot find it by Googling. I imagine it would be the same regardless of the size of the ship. Thanks!
  8. Another milestone reached. All standing rigging lines are in place. Backstays can still be cast off if they obstruct installation of running rigging. Yaay!
  9. Thanks so much Mort for your advice and encouragement! Thanks so much Bill for the info. I will check out that site.
  10. All main mast rigging in place. T'gallant and royal shrouds and stays are glued in place with a spot of CA, but can be unglued with debonder (acetone?) if need be. Tails left long for now. Fake eye splices and trimming to be done when I can be reasonably sure that no additional adjustments are necessary. Hard to know when that will be when I have no prior experience in this sort of thing. I am thinking that the tyes may affect the backstays, and the braces may affect the fore and aft stays. Lifts, jeers, and trusses would probably make no difference (?). Gluing in the fore and main fife rails permanently will make access to the top mast stays and the t'gallant preventer stay eye splices at the deck impossible, so I will need to be sure these stays are stable before beginning the running rigging.
  11. There. That's better. All foremast rigging in place. Tails are still left long and backstay seizings left undone to allow for future adjustments in the tensioning. Now that all the upper stays are in place, the final appearance of the bowsprit rigging can be seen. It more resembles the present configuration than it does the more complex rig shown in the BJ plans.
  12. Out of curiosity, I have looked at other builds using ready made sheathing plates and have found, in all fairness to BJ, that all the ones I have seen so far have nail heads that are out of scale. Of these, the Revell plastic model comes the closest to having the right size nail heads, but even they stick out more than these nails do: Incidentally, it seems to me that those of us who, like me, are distressed to see irregularities in their work when photographed super close up, can take some comfort in this photo.
  13. Thank you so much Allan. I really appreciate your kind words. Thanks for the photo. I will add it to my collection of ship photos. You are quite right about the nail detail. It is also true that the thickness of the BJ plates is well out of scale. I am thinking that if I do coppering on my next project, copper tape might be the way to go, now that I have seen the way it really is: At the time I did the coppering, I didn't know nuttin' about it. I am not even sure how I could go about making detail that small at 1/96. As you say, better to not have it than make a mess out of it. Thanks for the confirmation about the overlapping. I have seen sources and builds in which it is done the opposite way.
  14. Photo of the upper rigging of the foremast in progress to show that I have not abandoned the build. A photo of a more finalized version will follow. Tails to be left long until the very last stages of the rigging process. LInes that remained taut for months are now slack and have to be re-tensioned. Fortunately, I did not seize these, and debonder will allow me to loosen and redo the hitches.
  15. Yes. I laid the gun stripe planks first so I could sand them thinner without disturbing the planks which are above and below it. I get all my planking stock from BJ.
  16. I see the wales as being the thickest, the three strakes above that and those above the gunports as being thinner, and the strakes between the gun ports as being the thinnest. I used 3/32" thick planks sanded down to size for the wales, .020" BJ planks sanded down for the gun streak planks, and .020" BJ planks for the rest.
  17. This photo shows 3, as does the Revell model. The planks are just a bit thinner between gun ports. Hope this helps. Actually it really is your choice.
  18. I recently had visitors in, so I temporarily attached the yards to the model. It makes a nice preview of what the model will look like:
  19. The lower shroud ratlines This is the first new post of this log. In rigging these ratlines, I found that the topmast backstays became a serious obstacle, so I undid the lanyards and cast them off. Here are some shots of the ratlines rigged on the lower and futtock shrouds: Them's a lotta ratlines. As they say, onward and upward. T'gallant shrouds and stays to be rigged next.
  20. Topmast shroud ratlines I decided to rig the topmast ratlines first. I am not sure that I will do that in the future. I have seen builds in which all the details of the lower mast rigging is completed before the topmasts are even mounted. Apparently, it worked for them. Something to think about in future builds. The ratlines were rigged using BJ's .005 cotton line. It is a bit stiff, which means that the knots must be very tight so that they close properly, and do not show daylight with loops sticking out, but which also means that the ratlines have a stabilizing effect on the shrouds. I used cow hitches on the outer shrouds and clove hitches on the others. The cow hitch does not have an end sticking out sideways, but does not hold very well, requiring glue to secure it. Much has been said about how boring this process is, but I found that tedium was the least of my problems. For me, keeping the ratlines reasonably straight, and the shrouds perfectly straight was an immense challenge. I probably should not detail my ratline rigging technique, as it is unique, time consuming, and most likely not the best way. I did, however, adopt a widely used method for keeping the ratlines properly spaced and the shrouds straight - a cardboard pattern with the ratlines and shrouds drawn, inboard of the shrouds: Here is what I ended up with: This brings me to where I was when I deleted my entire log. I would like to thank those who encouraged me with their "likes", and especially Mort Stoll for his constant support throughout the process.
  21. The topmast shrouds and backstays The topmast heads, like the mast heads, were rigged off model, using the same procedure as before: The blocks installed under the crosstrees are for jeers. The blocks installed on either side of the mast caps are for lifts. The block installed on the aft end of the mizzen mast cap is for the spanker gaff lifts and halyards, Eyes installed on the under side of the for and main mast caps will have the truss tackles hooked into them. Here is a shot of the topmast shrouds, fore and aft stays, and backstays in place: The following composites show the method used for completing the rigging of the topmast shrouds: 1. Shrouds glued to the deadeyes, the shroud crossing outboard over itself, and the short end on the left side as described in Ben Lankford's book "How to Build First-Rate Ship Models from Kits" published by Model Shipways - Model Expo. Throat seizings done. 2. Sheer poles installed with their lashings, allowing alignment of the deadeyes. 3. Remaining seizings done. 4. Method of doing the seizings using a clamp and the Quad Hands. 5. Closeup of the seizings and sheer pole. Sheer poles lashings just visible. 6. Thinking that the shrouds were stable, having flexed the mast in every direction without affecting them, I secured the lashings. Months later, when the weather is colder and dryer, they have gone slack. Hopefully, I can undo the lanyards using de-bonder and tighten them. Here is a shot of the main shrouds finalized in the same manner as above:
  22. Futtock and bentink shrouds Here is a shot of the bullseye-lanyard rig for the bentink shrouds: The following composite shows a closeup of the futtock shrouds, the hooks used to attach them to the top deadeye strops, and a view of the model with these all in place:
  23. Rigging the masts It makes sense to rig the mast heads off the model. First up were the Burton pendants. These were made from BJ rope and BJ metal bullseyes with their centers reamed out to make them look like thimbles as much as possible. I also installed blocks for topmast stays. Next came the shroud pairs beginning, as prescribed, with the forward starboard pair. Next up, the jeer pendants. The preparation of the lower mast stays involved making a mouse, which I did by winding .005 line around the stay until I had something that looked like a mouse, the loop which is essentially a fake eye splice, and the bullseye with its lanyard. Here the masts are glued in and the stays attached to their respective bullseyes. Ends are left long to allow for future tensioning: A closeup of the fore and mainstay bullseyes, open hearts and lanyards: The mizzen stay rig at the deck: Before attaching the shrouds to their deadeyes, I thought I should get the snaking done. Here is the method I used which is essentially the same as Xken's, with a few departures: 1. The design drawn out on a piece of foamcore. Outer lines represent the stays, the zig-zag line represents the snaking. 2. Masking tape cut to shape and laid down sticky side up, leaving the turns in the zig-zag which will be attached to the stays exposed. 3. T pins passed through metal bullseyes, then inserted into the foamcore at the turning points. Line (BJ .005") having been stretched and stiffened with diluted PVA threaded around the pins resting on the bullseyes which hold it off the ground so that additional stiffening using liquid CA may be applied without gluing it permanently to the tape. Gotta be careful not to allow any beading of the CA to occur on the line. 4. When set, the T pins are removed, the bullseyes are removed, then the T pins are reinserted. The line is then pressed down onto the sticky tape. 5. An additional identically shaped piece of masking tape laid over the line sticky side down and pressed against the lower tape capturing the line in between and stabilizing it ready for installation between the stays. This is tricky. if the adhesive on both pieces of tape is strong enough, removal of the tape in step in step 7 may be impossible. I laid the upper piece of tape down on a surface and peeled it back off a few times to reduce the strength of the adhesive. 6. Install the assembly between the stays. Most modelers like to tie the snaking to the stay. At this scale, I saw no way to do that neatly, so I used Elmer's CA. 7. Carefully and slowly peel off the tapes and voila. Actually I did the mainstay first, but decided to base my post on the forestay which came out better, Practice makes perfect: Shrouds attached, lanyards rove. Ends left long. I was flying blind as to when to finalize these lines, so I kept my options open as much as I could. Shrouds are glued to the upper deadeyes but not seized: Looking at the netting rails at the waist, the counter clockwise twist of the hull becomes evident. I chock the fact that I did not catch that at the beginning up to inexperience.
  24. Rigging the bowsprit This rigging looks more like the present ship, and is less complex than that described in the plans. I installed the open hearts for the forestay, and set up the bullseyes/lanyards, and deadeyes/lanyards for the bobstays, jib boom martingale guys, and bowsprit shrouds, then temporarily rove them through eyebolts installed on the hull and held them taut with suspended clamps to see how they would look: Casting all these lines off once more, I then crossed the sprits'l yard and rove the jib boom guys through the sprits'l yard fairleads: Bullseyes and blocks for the upper stays stropped and painted (left), then installed on the hull (right). Unlike the plans, these are oriented horizontally, so as to leave room for the seats of ease to be reinstalled when the time comes. Blocks installed on the catheads for jib boom guys: Gammoning and gammoning cleats installed: Another view of the gammoning: Rigging attached. Glued but not seized, so that if I need to retension them, I can use de-bonder to free them: Two more views:
