Karkka
  1. Garboard plank, Can´t figure out how to do with it. How do I know how long it should be at bow.
  2. So. I did some planking- Did a slight curve to the top plank, I hope it turns out look good. How do I know in witch order to put the planks from here, and cut them. The middle plan that are alone I put it like the manual did.
  3. I have glued 3 planks. now the getting a "clink" because of the slight twist to glue them on the frame. Is this pdf good for every type of planking. I see that the are using paper with markings. Maybe my planks don't follow the natural curvature that's why the must bend strange. https://modelshipworldforum.com/resources/Framing_and_Planking/plankingprojectbeginners.pdf P.11
  4. I hope this new pic i better. I maybe misunderstand you. I thought you mean my pic, but now I understand you mean the pic i the manual. I still keep this post. I did some line on one of the pic, maybe I´m completely wrong about planking but I have no idea how do put this together. It´s not like the manual.
  5. It´s this kit https://www.occre.com/model-ship/bounty-boat.html?___store=en&___from_store=en It says easy kit for beginner. As far as I can see from the pic 11of the planking it seems like they are going in a straight line and the frame are in the same level.
  6. Hi. I´m trying to complete my build. But I ran into some problems. The bulk frame seems not to be in the same height, I have done after the manual when gluing them. Now when I´m about to start planking the hull I don't know what to do. I understand if it´s not going to look as the picture, but if someone have some idea how to make it look good it would be great. The manual says I should put one plank 3 mm down on every frame but it´s not going to work. and if I´m going to later put one plank above it´s not going to touch the frame. I had one idea to maybe saw of a little but i don't know if some frame are to high or to low.
  7. Hi. I´m trying to complete my build. But I ran into some problems. The bulk frame seems not to be in the same height, I have done after the manual when gluing them. Now when I´m about to start planking the hull I dont know what to do. I understand if it´s not going to look as the pitcture, but if someone have some idea how to make it look good it would be great. The manual says I should put one plank 3 mm down on every frame but it´s not going to work. and if I´m going to later put one plank above it´s not going to touch the frame. I had one idea to maybe saw of a little but i dont know if some frame are to high or to low.
  8. I could use some help, I´m going to sand down before planking, and it´s really difficult to know when it´s enough. I have tried with one of the plank but it´s still not easy to know. I don't want to sand to much and ruin the model. How do you guys do it.
  9. Got some stain on the ship, now it´s the planking. that´s one thing I fear.
  10. Hi First build. Going slowly and try to think thru all the steps.
  11. Hi. I just received my first boat. A Occre bounty boat. Going to start a build thread, to got some tips i hope. /Robert
