cafmodel
Everything posted by cafmodel
  1. Yes, this is boxwood. After CNC processing, the material is very delicate. At present, only boxwood and pear wood are most suitable for CNC processing
  2. I'll make fly later, I have tested several kinds of wood before. I can use boxwood or pear wood
  3. I use rhino.This software is very easy to use
  4. Thank you. There are still some parts to be made. The hull will be finished
  5. Thank you very much. According to experience, the weight of this model is estimated to be 5kg
  6. Here are two plans, one is compass cabinet, the other is furnace. You can choose to make
  7. Thank you. My Fly kit has been postponed, but I will not give up on him.
  8. Thank you. I'll try my best to make it according to the content of the drawing, so there will be many wonderful details
  9. There is no new progress this week. We are moving to a new factory,I'm working as a hard Porter。 Can start work next week
  10. It needs to be removed from the block. The thickness of the bottom of the block is 0.1-0.2mm. It can be easily removed after grinding.I will take some photos to show how to remove the carving easily
  11. About postage: Due to the impact of the epidemic, the number of flights decreased, resulting in a doubling of postage.But I think by July, the postage will be back to normal.For the present order, we will return the difference of postage when we deliver the goods
  12. It's just that the packaging is divided into two parts
  13. The brick of the stove is red clay. I made a mold and pressed it into four bricks The cover of the stove is brass
