Michael Kelleher
  1. Adding the permanent struts between the bulkheads, which I am installing to align just inside the stanchions and flush with the top of the bulkheads...
  2. After gluing in the bulkheads to the keel, I added the stern block... and as luck would have it while sanding out the rough shape with a dremel, was distracted momentarily by my dogs barking and the dremel sanding drum skipped and gouged a nice little chunk out of the top of the stern block ☹️... patched it up with some wood filler and sanded it smooth... still requires some additional sanding to clean up the lines, which I will do after I add the struts to give it more strength, cause I do not want damage the keel which is fragile at the stern.
  3. Before cutting the rabbets I dry fitted the bulkheads, most fit snugly and were of the proper length, but i did need to cut back a few and in a couple of cases needed to glue and shape a shim (0.5mm x 5mm) to extend the bulkhead to the rabbet... this was all done after I beveled the bulkheads as per the instructions...
  4. Started out by reviewing the instructions, plans and getting familiar with all the parts... spent a considerable amount of time measuring, marking up the keel and bulkheads and then measuring again... once I was sure that I had everything marked up correctly, I glued the keel together and cut the rabbet into the keel...
  5. Hi... New to the board and looking forward to sharing this log of my first build... in all honesty this technically my second build. I had started my first build (HMS Bounty by Artesania Latina) some time ago and was almost to the point where I was ready to start the rigging, but did not get a chance to complete the model due to work, family and life in general. Unfortunately when we moved the model was damaged beyond repair, so I never got the opportunity to complete the kit when I finally did get some free time... major bummer. Anyway, this will hopefully be the first kit that I will get a chance to complete. I have been lurking around on this board for a bit and spent some time reading through the Bluenose build logs that others have posted on this board, and they have been a tremendous help in helping me to understand the amount of work and potential issues that would be involved in the build. I am definitely very happy that I found this board and wanted to send thanks to all who have shared their knowledge and experience by posting their work. I will consider it a success if my finished model is a fraction as good as the builds I have seen on this site. I will be updating this thread with updates and pictures of what I have done so far, since I had already started the build before I found this site... in the meantime all the best and see you soon... Michael
