t_corret
Members-
FriedClams reacted to a post in a topic:
Soleil Royal by Hubac's Historian - Heller - An Extensive Modification and Partial Scratch-Build
Hubac's Historian reacted to a post in a topic:
Based on absolutely no knowledge, I think slow match was stored in the barrel with the linstock upside down. During action, the linstock was pulled out, reversed, and the length of slow match was lit. I seriously doubt the butt of the linstock with lit match affixed was slid back into the barrel. When empty, it may have been filled with water for the sponge. Don't quote me on this!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
mtaylor reacted to a post in a topic:
Have you looked at Dafi's 1/100 Heller Victory build? He has photos-etched chains that he sells. It may work for your build. Wonderful to see what you are working on.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
EricWilliamMarshall reacted to a post in a topic:
I forget how many "hobbies" there are! I mostly build and paint toy soldiers. One of the first series of fine model kits of tiny men was French, from a company called Historex. The soldiers are 56mm tall when built from a bag of a hundred parts or more, not all of which are used. Historex used white styrene and modelers began making truly expressive and dynamic figures and dioramas. Shep Paine was an American painter and model maker who used Historex as the basis of little gems of model-making. Google should give great images. The liquid sprue super detailing may not represent the wood carving you are so adept at recreating, since most modelers use it for hair and fur. All the best, sir.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Shep Paine and the Historex catalogue recommended making a liquid sprue from plastic shavings and glue. After painting it on and drying, a hot needle or blade could super--detail textures of hair or other finicky effects. Congrats on a wonderful masterpiece!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
You may be able to buy it in your favorite fine woodworking shop in the stains and finishes area.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Ditto on the hot water, works a treat on Historex parts.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Tamiya makes a thin flexible masking tape that might be more trouble than it's worth. As long as you continue to paint only one fine edge of color at a time, your results speak for themselves. Wonderful!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
When you drop out the color, the precision and delicacy of your painting really shines forth. Bravo!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
I doubt my ability to understand what the main issue is, but that has never stopped me yet from talking! Are we seeing a left/right angle deviation on the sides from a dead level waterline base to a centerline perpendicular as you look down the length of the hull from the rear? I would be tempted to use a hairdryer to soften the inside of the sides and clamp them with felt padded clamps (to protect the wonderful paint) to a carefully cut wood block fixed to the deck that would support and allow them to mold to the proper angle. It's tricky but can be done with minimal risk to your work so far. If we are looking at a deviation of port and starboard length from a dead level waterline running longways to a free floating perpendicular at the stern, well you are a master of adding and subtracting small amounts of plastic to this model. A little bit done to each side may be an answer. I will be quiet now.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
An English carpenter threatened to sell a t-shirt that said, "I'm doing a Dutchman in the shed."
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Even in French Napoleonic uniforms, there was so much variation so rapidly, you can paint what you think is correct, spit in a critic's eye and ask them to prove you wrong. (Though you are too much a gentleman to do so.) Wonderful progress in both life and art!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
