Lapinas
Members-
Everything posted by Lapinas
- 81 replies
- Lady Nelson
- Amati
I have tried using precut stairs from Amati too, but they I think also does not look according to scale 😬
- 81 replies
- Lady Nelson
- Amati
Hm this wooden pump was used in build that is advertised in their website, but I am not sure about the scale. This wooden pump is much bigger than the metal counterpart 🤔
- 81 replies
- Lady Nelson
- Amati
It looks like the consensus for this kit is that the windlass included - is not really suitable for this ship. I have noticed that a lot of people are repurposing this wooden windlass from amati: https://www.amatimodel.com/en/small-parts-and-accessories-for-model-making/product-wooden-windlass-type-h-mm55-b411505.html So I did that as well. Also I have noticed that the middle part of this windlass is replaced with ratchet gear. I could not find anything suitable in my stash, so I have designed one with Openscad and 3D printed it. After a few iterations I was satisfied and replaced the middle part of the windlass. Final result. You can also see that I have decided to use different kind of water pumps (https://www.amatimodel.com/en/small-parts-and-accessories-for-model-making/product-wooden-pumps-mm-15-b4356.html) instead of the metal ones that were included in the kit Windlass will be painted red together with "ratchet stopper". To help fellow modelers, I am also sharing an STL file so you can 3D print this gear at home. Additionally, I am including the SCAD code for the part in case any modifications are needed. windlass_gear.stl windlass_gear.scad
- 81 replies
- Lady Nelson
- Amati
I have finished drilling all holes for eyelets. Painted brass rudder holders black. I have also made a custom rudder part based on some other build logs. Custom one looks way way better.
- 81 replies
- Lady Nelson
- Amati
Hull was painted white. Base board was sanded and repainted in black I will eye into buying / making small drill press. It is very hard to manually drill straight holes with very high accuracy:
- 81 replies
- Lady Nelson
- Amati
I have drilled holes for M4 screws in the keel and in the base board. I have also sanded the base board. Will paint it the second time. One reason would be to try to get a nicer finish, another reason would be because I drilled the second hole in the wrong place 😆 to fix that I have filled the hole with a wood dowel, added some wood putty.
- 81 replies
- Lady Nelson
- Amati
I have drilled some holes on the deck and bulwarks. Scanned plans has really helped to mark the precise location of the holes with awl. Also I have painted some buckets. I think I will be staining these later to tone it down.
- 81 replies
- Lady Nelson
- Amati
Add some horizontal planks on the deck towards the stern. It will mask nicely a slightly chopped deck planks line where it meets the vertical surface painted red.
- 81 replies
- Lady Nelson
- Amati
- 81 replies
- Lady Nelson
- Amati
Had a little bit of time, so I have finished painting canon carriages. I also did some paint touch ups with brush on the ship itself to make it perfect
- 81 replies
- Lady Nelson
- Amati
I have finally found a color that I like for painting bulwarks it is revell aqua color 37. Paint job still requires some finishing touches, but it turned out extremely well! Really happy with it.
- 81 replies
- Lady Nelson
- Amati
Still trying to decide If I want to keep it that way 😅
- 81 replies
- Lady Nelson
- Amati
In the meantime I have airbrushed some small parts in black. Unfortunately I have some difficulties painting MDF in black. For some reason it is very hard for me to get the finish I desire with this mdf base plate. I will try sanding it and painting again, maybe will try some wood putty too. Just very hard to get even finish with it.
- 81 replies
- Lady Nelson
- Amati
I have prepared ship for bulwarks painting… but after testing the red that I have bought it turns out it is way too bright. I have ordered a new more suitable (hopefully) Revel aqua color 37 reddish brown. If this will not look good enough I will be mixing my own.
- 81 replies
- Lady Nelson
- Amati
Prepared my spray “booth” and started spraying. Revel aqual color looks really great on wood when sprayed through the airbrush. Wood texture remains very visible and no “plastic” effect. Also I love these black details on the ship!
- 81 replies
- Lady Nelson
- Amati
- 81 replies
- Lady Nelson
- Amati
- 81 replies
- Lady Nelson
- Amati
- 81 replies
- Lady Nelson
- Amati
- 81 replies
- Lady Nelson
- Amati
And made all the masts. I have used hand plane + drill to shape them. I definitely need to buy a set of small hand planes 😅
- 81 replies
- Lady Nelson
- Amati
- 81 replies
- Lady Nelson
- Amati
- 81 replies
- Lady Nelson
- Amati
- 81 replies
- Lady Nelson
- Amati
