mathewp
Posts posted by mathewp
  1.    G'day Sam, thanks for dropping in. The kit's OK, but there are a few issues to work through due to poor quality of some of the parts. I've noticed a difference in paint scheme compared to other kits as well, which is no big deal, because you can follow the plans like I have (almost) or change it to whatever you want to do. Theres no flag locker on these plans, so if I put one on I'll have to put one together on the fly. This one isn't one of the more expensive kits, so I guess I shouldn't expect it to be as good as some of the others I've seen here. I picked this as a second build, and I'd say to anyone who wants to do this Ship to buy a higher quality kit if you can. I've seen part of your refit, and it looks good, I'd reccomend you get the best quality parts you can. You'll end up with a very nice result I think Sam, she looks pretty solid.
  2.    This post is a fairly short one, mainly because of the repetitive nature of working on deadeyes and ratlines. Still I've managed to get them done . I've also added the anchors and once the ratlines were finished, I put thebackstays on, so that they didn't get in the way while doing the ratlines. That completed the standing rigging. The 10 half pounder Carronades?, I yhink thats what they are callled, they're on too. Next it will be the stern decoration and the side windows. The final stage of running rigging is not far away.
  3. I haven't posted for a while, I just didn't feel like it. Lots to post so I'll try and be brief. The masts and bowsprit are on. The supplied trestles needed some packing as the holes were way too big. I'm not sure what happened there, it seems like theyput the wrong sized ones in the kit.The mastcaps are on, no real problems there, apart from not having enough tanganika to plank them. I decided to rig as much of the bowsprits standing gear off the model, that made llife a little easier. Then came the mainstay, and the other preventer stays. The Shrouds went on easy, and the deadeyes.  I added some fids to the masttops. The chains that hold the deadeyes in the channels are of a very sof metalthat snaps easily, so I ended up replacing a few of them while I was threading the deadeyes. I've put on the futtocks, they should be called something they rhyme with, because that's where they were a pain. Upper shrouds are on and the deadeyes. A couple of repairs and I'll thread them and move on to the top shrouds and then the ratlines.
  4. I still have my gravers from when I did a bit of silver work. I find them very useful. They are very easy to mess up, and I wouldnt reccomend anyone buy, grind and add your own handles, it's quite difficult and easy to mess up. If anyone is thinking of getting some, pay the extra for a set ready for use. I ground and added my own handles, because I wanted mine to fit my hand comfortably, which was essential for carving metals. These tools are expensive. I paid $30 for mine, and they weren't ready to use. The good thing about these is you can use them on a variety of materials. On wood, a little extra care is needed so they dont dig in too deep. When I was using them on metal, they were used to remove very small bits of material at a time, and usually on a very shallow angle, until you got to the depth you wanted. Ceramic hones are as good as any to keep a fine edge. I use this hone to sharpen razor knife blades when needed.
  5. Damn computers, it took nearly a week to fix, so theres lots to post.The ladder on the starboard side is on , and I finished the Cannons and installed them. Then the longboat was finished, with a pair of oars. I ended up very short of materials for the mast tops, so I ordered some extra tanganika, and walnut planks. I also got some extra 1x1 walnut so I can add traction boards to each Mast top. The kit doesn't supply lanterns, so I got me some of them as well.If you want to do the stanging rigging in black then you'll need to order some as all the cord is in fawn, and yep, I got me some of that too. I fitted the helm, and the anchor rope on the windlass. I painted the chains so they're ready to go on. I made the three lower masts, so they're ready for the mast cheeks, and wooldings. I've planked both sides of the Mast tops with Tanganika, Now it's on to the dry fitting of the top masts, and replacing the too small trestles supplied in the kit. That  will take a little while.  Will post again soon,
    Matt
  6. Thanks for all the suggestions.I don't think I"ll burn it. My first model was second planked in Mahogany, which seems very similar to Cedar to me. I was thinking of doing the Wyoming for a first scratch build, so a larger model about 3 foot long should be ok to plank with this wood then???. I'm a bit like you Tarbrush, because I visit my pile of wood regularly. I draw the line at talking to it though. Thanks for the offer Darren, but I'm north of Brisbane.
  7. Have most of the deck furniture sorted out. The rest of the pinrails and last fyfe rail. I fixed the Capstan, with the little tiny pieces I almost couldn't see in the box. I won't rig the helm just yet as I want to give everything a last sand and varnish. Next I guess is the longboat and the bits and pieces that go in it.Maybe I'll add a few extras to it. soon will be the decorations on the bow.They look a little tricky, and then the mounts for the half pounders and the four Cannons. Even though I feel like I got a fair bit done, there's still heaps to do. I also found a couple of small spots on the deck planking to fix.
