sziggy8
Members-
Everything posted by sziggy8
It's been awhile, but here is an update on my HMS Ballahoo build. A couple of major mistakes to be sure, however I am fairly satisfied with the result so far. I installed the main Wale to low on the Hull, so I will have to glue channels to the hull instead on pinning because they are above the decking. I alos made the center hatch to large, and not sure how I did it, but it is slightly off of center. Ugh. You might wonder where the pump assemblies are, join the club, lol. I believe an overzealous cleaning person accidentally may have thrown them out. Still trying to figure out rudder assembly, and am planning on putting black straps on Anchors. Even with these shortcomings I am fairly happy with the result to date. Now onto my first adventure in rigging!
- 27 replies
- Ballahoo
- Caldercraft
Getting ready to put in the Masts. I have made a couple of blunders for sure. I guess the best way to learn. Overall still pretty happy with first effort. I will post pics soon, right before I begin my first rigging odyssey!
- 27 replies
- Ballahoo
- Caldercraft
Hi Johnny, Thanks for the compliment. I took a bit of a break myself. We have had some beautiful weather my area this fall, so not inside as much as usual. Getting ready to get back on the horse now that winter is here. I'll post more pics when I make progress. I'll check your out as well!
- 27 replies
- Ballahoo
- Caldercraft
Once paint and oiling is complete, I was planning on putting a coating of enamel on ENTIRE surface. Please offer your thoughts and advice as to whether this is the correct way to go.
- 27 replies
- Ballahoo
- Caldercraft
Build is progressing. Still trying to figure out Rudder. Need to re-check Eamon's Log for guidance. Don't hate me for the Blue Bulkhead. I know it is not period correct. I am doing this (my first) build to display in my beach house and the Blue matches the interior. Lame, I know, plus I actually like it!
- 27 replies
- Ballahoo
- Caldercraft
- 27 replies
- Ballahoo
- Caldercraft
Okay, so I tried an experiment. Looking to paint inside of Bulkhead and trying to not have any "Bleed" onto deck planking. I had read that it if you apply some enamel to the masking tape that it will help eliminate this problem. Being inpatient and not having any clear enamel on hand I decide to try a can of sealant that I had on hand to a piece of tape and with another piece of tape with no additional applications. Image 1230 is the piece with the sealant and image 1229 is with piece with nothing added. and there was no bleeding with the piece with nothing added vs. a good bit with the sealant. I thought this was interesting. I realize the sealant is not the same as enamel, but interesting nonetheless. The question is should I forge ahead without the enamel, or wait and do another test with enamel to try and create the best results.
- 27 replies
- Ballahoo
- Caldercraft
Hi Eamonn, Once again LOVE your work. I am progressing on my Ballahoo build. Getting ready to paint inside Bulwark, I should have taken your lead and painted BEFORE deck planking. I hope my 3M tape does the trick in preventing "bleed" onto deck. My question is what color did you paint first, Black or white to create this beautiful waterline? Regards, SZiggy8
- 1,039 replies
- ballahoo
- caldercraft
Ahh! Thanks so much George, you are a lifesaver!!
- 27 replies
- Ballahoo
- Caldercraft
Bulwark capping rail-I am confused by instructions..."Dry fit the capping rail before gluing using brass pins to hold them in position. Once you are happy with the positioning, glue the rails in place using PVA wood glue and pins to secure the rails until the glue dries". Do they mead to hammer pins in the top of rail to bulwark top edge? THis seems like it would split the wood, and top bulwark edge does not seem designed to be nailed into. Can someone please clarify? I researched on this site and cant find an answer. Thanks
- 27 replies
- Ballahoo
- Caldercraft
Wow! Amazing build! Your craftmanship is incredible. My Ballahoo build is looking "not worthy" compared to your incredible work! Thank you for sharing and I hope to learn from your experience.
- 1,039 replies
- ballahoo
- caldercraft
Thanks George, Unfortunately the issue with the Pintles fitting into the eyelets is that the wire is too thick. I actually did a good job of lining them up! Lol. I wish the kits provided proper materials that fit together! The hole I drilled for the Eyelets is a slight bit bigger than the Eyelet, so I will need to ty and comeup with a work around.
- 27 replies
- Ballahoo
- Caldercraft
Sorry, I got my verbiage wrong. I have been using PVC glue to date. I had also ordered 3 viscosities of the CA glue. That is the one (medium) that dried up on me in a few days. Not sure what happened. Thanks for the info however. I just tried to put on my rudder and had 2 issues, #1 the PVC glue did not hold the Brass Eyelits into place, and #2 the Brass wire is too thick for the eyelits. Should I use a different glue and is it normal to have to sand down wire girth to fit into eyelits?
- 27 replies
- Ballahoo
- Caldercraft
Thanks George, Not too harsh. I cant be scared away that easily...lol. As you said, I used first planking to learn for second. Really took my time with the second, but still made many mistakes, but happy with the overall results. I have a Dremel, was probably a dumb question. never used it as a drill. I just did to put in the pins, it worked well. Thank you!!! I will send pics when I attach the rudder. Another probably dump question. Is there a way to avoid PVC Glue from drying out? I opened the medium viscosity a couple of days ago, put lid back on snuggly and quickly and it is dried out already. I also have thin and thick viscosity and am afraid to use now.
- 27 replies
- Ballahoo
- Caldercraft
After looking at pictures it appears that I have wood filler everywhere! Really not the case! Just need to clean up a few spots...lol.
- 27 replies
- Ballahoo
- Caldercraft
I have been steadily progressing with my first build. Obviously have made mistakes, but am learning much and am generally happy with progress albeit slower than I anticipated. I am finishing up planking and decking and am getting ready to install rudder. Does anyone have any tips on how to create holes and install copper eyelit? The hand drill is very slow going and just wanted to see if there is a better way to proceed.
- 27 replies
- Ballahoo
- Caldercraft
Thank you George! I appreciate your input. I am just now seeing your posts, I did not realize new comments came in. I could have used some of your advice..lol. I will use it for my next build for sure.
- 27 replies
- Ballahoo
- Caldercraft
Okay thanks. I wasn't sure about the filler.
- 27 replies
- Ballahoo
- Caldercraft
My first planking is done! Not as elegant as I would have liked, but serviceable I guess. For some reason the port side came out a little better than the starboard side. I welcome any constructive feedback. Getting ready to sand and begin final planking.
- 27 replies
- Ballahoo
- Caldercraft
04CFF571-BDFC-44D2-823B-DB660F2F8909.heic 41A8CE0C-AC32-4742-8857-2D733A7FCA1C.heic 45882EF2-021E-4659-8EDB-00164186E0B3.heic B7A03F39-92BD-4EA2-B958-F921C388AD45.heic 28260A7D-41C4-41AB-843C-9363EC8D2DCD.heic D2F7F62A-12F8-4279-8635-840ED50B940A.heic 0287F2AF-126E-40EF-8C86-1C3CCD503AA4.heic E673EA64-FA32-4F9B-A935-9835D62CE4D1.heic 9A94231F-3851-468F-84F2-5D21816D169B.heic 21A89AD0-744D-41AD-8411-5F59575E01BA.heic A7FC64D8-4E93-4FBC-B593-F4BD561BDAA5.heic
- 27 replies
- Ballahoo
- Caldercraft
As a new member and model ship building neophyte, I posted a couple of months ago, with the ambitious goal of having my first build be the Le Cerf. At the urging of others on this site, I took on a little less challenging project for my first build. So, I ordered HM Ballahoo, and after waiting a few weeks for it to arrive. I began the build and I am close to completing the first planking of my first planking. Will submit pictures in the next couple of days. Be gentle, LOL. Constructive criticism welcome.
- 27 replies
- Ballahoo
- Caldercraft
Thanks so much Matrim! "Official" modeling pins I ordered are on backorder. This method seems to work great! Still waiting on Ballahoo to arrive to start first full build. Couldn't help but try a bit of block modeling on Le Cerf in the interim.
