Retiredpm
Members-
Everything posted by Retiredpm
Since I found the Alfred to be beyond my skills, I’ve decided to take a step back and start a build that is more to my skill set. I am enjoying this hobby but need to stay in my lane until I get more experience. Using the instructions and prints provided as well as studying the builds of others will help me in tackling this project.
I am open to suggestions on next build. I had picked up the Navy Frigate Alfred through FB marketplace on the cheap. So I will tackle that since, at the worst, it will be good practice as I am showing a lot of patience while working on these models.
- 24 replies
- Model Shipways
- Norwegian Sailing Pram
I picked up this model from Facebook marketplace. This one was produced in 1974. There is one other example of this model on this forum and the modeler (Schooner) did a great job. I will be utilizing his pictures and advise as I attempt to tackle this project. I know it is a bit over my head, but I am patient in learning and working on my skills. I picked up an updated instruction manual from Blue Jacket. The first glaring issue I noticed is the difference in the hull. Schooner’s hull came mostly chiseled out. See the second picture. Question number 1, should I chisel out the hull so that it resembles the other modelers hull or work with the hull as is?
Well. It is far from perfect, but I am still happy with the outcome and can’t wait to start my next build. Not sure if I want to do the third suggested model, Muscongus Bay Lobster Smack or tackle something else. I would love some suggestions.
- 24 replies
- Model Shipways
I had an issue with the tiller assembly. Both pieces split as I tried to drill a hole through them. So I took a piece of scrap and a fixed that to the assembly.
- 24 replies
- Model Shipways
- 24 replies
- Model Shipways
It’s been a while since my last post. Life gets in the way sometimes. I started the sail. Any trick to getting the creases out of it? I’ve put 2 coats of paint on the inside and 5 coats on the outside. I think it is coming along nicely.
- 24 replies
- Model Shipways
I used a grey primer spray followed by some light sanding. Will start painting when I return from a convention.
- 24 replies
- Model Shipways
Board cleats and mast step installed. Made the cuts for the chain plate slots. A little confused with what the length of the cut is supposed to be, so I have small slits in place and figure I can go bigger it needed.
- 24 replies
- Model Shipways
I did some additional sanding after adding a little wood filler. Looks much cleaner.
- 24 replies
- Model Shipways
Is a regular wood filler good or is there something better for models?
- 24 replies
- Model Shipways
I took a couple weeks off helping in-laws pack for their move to Florida. I have completed the bottom of the boat aside from a little more sanding. Should I be using some kind of filler for the bow and stern or is it okay like this?
- 24 replies
- Model Shipways
This step looks much easier on paper than in reality. Note to self, make sure one end is dry before gluing other end.
- 24 replies
- Model Shipways
- 24 replies
- Model Shipways
I initially glued the aft transom pieces incorrectly but got the pieces separated before the glue held. I think I have the pieces beveled correctly. There is so much trial and error in this hobby that I feel like I am guessing at times, but relying on what I think look good.
- 24 replies
- Model Shipways
I am beginning my second build and plan on going slow to hone my skills. I see from the initial instructions that I will be buying a couple more tools.
- 24 replies
- Model Shipways
I’m a retired Postmaster
- 160 replies
- Model Shipways
- norwegian sailing pram
Looks great, can’t wait to start on mine
- 50 replies
- model shipways
I ordered the Pram. Hope it comes out as well as yours.
- 45 replies
- Model Shipways
The complements are encouraging. My next model has been ordered. Going to check out more building logs. They are very helpful in learning this hobby.
- 12 replies
- Model Shipways
- Lowell Grand Banks Dory
I just completed the Dory and have ordered the Norwegian Prim. Great reading your log and can’t wait to start mine.
- 160 replies
- Model Shipways
My completed dory! I think I may still stain the base but otherwise I’m done with this one. Next up will be the sailing Norwegian pram. I am getting hooked into this hobby.
- 12 replies
- Model Shipways
Boat is painted. Next part is to paint, then install the cap rails. Not sure if I want to stain the presentation board or leave it natural.
- 12 replies
- Model Shipways
I need to do some light sanding and then apply a primer coat. I’m finding this project to be enjoyable as well as mildly challenging. It is not perfect, but I am happy with my results.
- 12 replies
- Model Shipways
