cabrapente
Everything posted by cabrapente
  1. thought had not put the candles. but the book of 74 guns, is very good. Now if I'm thinking ... I tried to make the sticks, hand brushing and not come out. on the lathe, I can not use guvias because the stick is too long. I found the solution. two pieces, with a hole to fit and glued with sandpaper. with this method, it bounces off the stick very right. at the ends, I put rubbers, very tight, so you do not split ends. gluing one day and in 15 minutes the stick is made. cabrapente
  2. fantastic. very good job. a greeting cabrapente
  3. always impress me with your work. thanks for sharing. cabrapente
  4. Today I received a book dedicated to the rigging of 74 guns. I have been a surprise, because it contains the plans for its construction.
  5. Spanish is written in "escuadra". but I think the best definition is carpenter's square. Is it true? cabrapente
  6. this is achieved, giving little by little and with some practice. the straight cut, only you can do it with the band saw. I had a small as PROXXON, and the blades cost money . now I have this red which is small, and very good. you can put different width blades
  7. I think the same. of all jobs, 1% use the jigsaw. everything else, I use the bandsaw.
  8. the name in English, not find it. Does anyone know her name?
  9. angle. is used to give rigidity to the union. I use google translator and does not always work
  10. no problem. still much work to FLEURON. thanks for sharing. a greeting cabrapente
  11. hello ed. I'd like to get your book. Is there a Spanish edition?. google translator is not effective with nautical words. a greeting cabrapente
  12. I modified the bandsaw again. Now I've put a "feeding hacksaw" much wider. the cut is perfect. not need sanding. tablitas sac less than 2 millimeters-
  13. thank you very much Giorgio. never quite understood the construction process. is the first time I see it so clear. you're still my teacher. cabrapente greetings.
  14. place the 12 bronze cannons. I lost the photo camera. these are with the phone, of poorer quality.
  15. give color to the strings, with turpentine and bitumen. coloco las bombas.
  16. splendid wonderful. Thanks for demonstrating that a good job, does not have to be expensive materials nor many tools ... good work is done with the heart. a greeting. cabrapente
  17. gary congratulations. I hope to learn to work as well as you someday. is an inspiration to all. a greeting. cabrapente
