unixguy
  • Gender
  • Location
    Maryland
  1. Hello Strand! I just logged in after nearly two years away from model ship building. I have Model Shipways US Frigate Confederacy on my desk now and logged in to peruse some build logs. I never quite finished the cross section but surely have the scans somewhere. Give me a few days...
  2. Hello unixguy
    Greetings from Vienna.
    I'm new to this forum, but I'm an experienced model builder.
    At the moment, I'm researching the model that you've already built so beautifully (USS Constitution, cross section 1:76).
    I'm particularly interested in the interiors of the lowerdeck (orlopdeck) and the deck above it (berth deck).
    I keep seeing floor plans that I can't place.
    I have two questions about them. These floor plans with the cabins, which you have also built, what year and restoration do they correspond to?
    And my second question: where did you find these plans?
    A bold question: can you share them with me?
  3. I took a long break and caught up on other projects. Over the last few weeks I replaced the doors I made, worked on the hammock netting, and experimented with copper aging. I also managed to source a 1928 printing of Magoun's "The Frigate Constitution and Other Historic Ships." It contains a wealth of pictures and drawings, some of which I had not seen before elsewhere.
  4. Thanks @Tomculb. I tried doing the hammock netting and didn't like what I did. Taking a break from that and redoing some of the earlier work.
  5. HULL FITTINGS – Gun Port Lids I found this step to be one of the more challenging so far. Not so much difficult as tedious. The supplied upper lids are unusable due to the grossly oversized windows. They are so large that it is impossible to use hinges on them. This necessitated creating new parts from scrap. I based the window size on pictures of the current configuration. I believe they’re still too small on my model. The instructions have you gluing the top lid to the outside of the gunport frame. This put the lid perpendicular to the hull, but more importantly, it makes the lid look like it’s glued to the side of the ship rather than hinged to the frame. To avoid this, I cut small triangular pieces of wood the width of the lid and glued them to the lid. Then this triangle was glued to the inside top of the frame. Finished upper and lower lids with mounting pieces attached. I decided to use thread rather than wire. This worked fine giving the illusion that the upper lids were hinged to the upper frame, but I still was not pleased with the overall appearance of the perpendicular lids and knots at the ends of the thread started over. My kit did not include the port hinges, instead including a compass decal likely from a Model Airways kit. I ordered the missing hinges when I started the model (almost two years ago) with a note that I had received an aircraft decal. Instead of sending me the hinges, I received another decal! Reading Tom’s build I realized I was also missing another sheet of chain plates. Looking at a newer version of online parts list, I noticed the part number for the hinges had changed so I requested a sheet of chain plates and the hinges last month. This time I received the hinges! What is particularly nice about the hinges is that even though they are cosmetic in the instructions, they can be used as hinges if you leave the etched frame attached to the hinge. The next photo shows the hinges removed from the frame but using part of the frame as the hinge. Hinges attached to lower lids. With the hinges attached, I added small hooks to the inside of the upper lids to help secure the ropes to the lids. Although the hooks are oversized for this, it is like the present setup and appears more visually appealing than twisted wire. Here are the hinged lids attached to the gun port frames. I added small eyebolts to the lower lids. Inside of the lids are painted black. You’ll notice I did not paint the hinges white as they should be. I should, but I like the black hinges. The ropes for opening the upper lid pass through the hull and enter the gun deck above the gun port frame. I think there should be a cleat on the beam above the gun, but I could not easily get anything there at this point in the build. Instead, I added a small eyebolt to a diagonal knee, ran the rope through the bolt, tied a half-hitch, and cut off the excess. I like the realistic appearance, but it draws attention to my not having mated the hanging knees to the overhead. Things I like: The hinges! Things I did not like: Using 34 gauge wire in the instructions but not including any in the kit. The unusable upper gun port lids. Mounting method for the gun port lids. Things I would do differently if building again: Add a small cleat above the gun for the lid rope. Things I might still do later: Paint the hinges white.
  6. Thanks @Tomculb. I've been stuck on the hammock netting. I can't get it the way I like.
  7. HULL FITTINGS - Sea Steps The sea steps were constructed per the instructions, but I believe it would be better to increase the depth of all the pieces by at least 1/32” and then sand the step against the hull at the appropriate location until the top step piece or bottom step piece is the desired depth. Otherwise, some steps will have a shallower tread than desired, and some will have a bottom piece too shallow. Each step consists of three pieces and they were built on painter's tape to keep them in place. After gluing, the edges were softened and painted white. Because I was carelessly aggressive sanding the faces of the cross section, I made sure to continue using a large triangle to keep everything vertical rather than parallel with the fore or aft face. The error is less than a degree, but it might be apparent if I were to use the cross section face as a vertical reference rather than the triangle. Despite the camera not being positioned properly for this photo, the tape is indeed vertical. I had to cut a small notch in one step for the scupper. You can see that to keep the steps perpendicular with the vertical, either the bottom support or the tread is sanded too shallow. I did not add the opposing trail boards. I believe it might be more visually appealing to leave off those boards. Gangway ropes added and steps completed. Things I would do differently if building again: As mentioned, add depth to the step pieces so that neither the tread nor bottom support is unnecessarily shallow after sanding. Things I might still do later: Add a light wash to the steps to bring out the different depths of the layered materials. Apply a darker stain to portions of the trail boards to add visual depth.
  8. Thanks. Every time I look at the pictures I realize how amateurish it appears. I’m going to stick with some less expensive models until I feel ready to crack the wallet on the full Constitution model.
  9. HULL EXTERIOR I found the hull to be a pleasant change from the tediousness of the small details. The first step was creating the gun port inner and outer frames. The next picture shows the added bracing around the gun ports with the frames fitted into place. I tightly fit the frames against the gun deck ceiling planks but still had to add some thin wood slivers to fill the gaps. Looking closely, you can see a pin sticking out above the gun port for the gun lid rigging. Just to make sure everything is still square I placed the exterior walls upside down on the table and glued the model to it centering the gunports and ensuring the middle frame was truly vertical. Exterior walls in place illustrating the gaps in the gun port frames and wall. Note that the frames are not deep enough to be flush with the outer wall. Also installed are the airports. As mentioned earlier, I drilled through a knee when adding a brass tube for the second airport, fixed my mistake, and lost motivation to add the others, so only one is a working portlight. The remaining five are per the kit. I was not impressed with the pewter pieces that represented the scuppers. The scuppers are unique but looked too unrealistic. I fashioned some rounded rectangular brass sheet, drilled a hole in the center and used brass tube to create scuppers. Scupper tube drilled up at an angle to meet the waterway. Because the gun port frames did not meet the outer wall and there were gaps, I added frames to the outside ports. Note that when attempting to form the wales to the frame it started to separate at the seams across the middle. For once, planking was mostly stress free. Looking at the model upside-down, there are 15 full-width planks up from the wales and two full-width planks down from the keel. The planks in between have a 1/32” taper. I made sure to bevel the edges for a tight fit. Once the planking was completed, I sanded and applied wood conditioner a couple of times. Exterior walls and wales painted feathering the paint below the wales to not have a raised line under the copper plating. I found a set of ponce wheels in 1/4”, 5/16”, and 7/16” and used the small and medium wheels on the copper tape per the instructions. The copper plates are in place and a line parallel and 7/8” from the wales was cut and copper removed for the three belting rows. Belting rows completed port and starboard sides. And just to show the scuppers, you can see the light shining through from the gun deck. Eyebrows glued in place. The pins are placed so they exit inside the gun deck hole above the port. I may drill them out slightly larger and add lid rigging. Things I like: I was surprised with the ease and attractiveness of the copper plating. I honestly thought I’d make a mess of it. Things I didn’t particularly like: Scuppers. Things I would do differently if building again: Make all the airports and scuppers with brass tubing (requiring slight adjustment of the berthing knees). Next… HULL FITTINGS
  10. SPAR DECK The only change from the kit materials on this deck was the substitution of 2 mm bearings for the 2.42 mm gold beads. A rather trivial substitution but you can see in the picture that 2mm is more representative of a 6” diameter shot for a 32 pounder. Unfortunately, I failed to take a lot of photos during the construction of this deck. Carronades and hatches in place. 2 mm steel bearings glued in place. Bearings painted black. I need to paint the rail holding them in place a glossier black. Bitt posts in place with copper tops. The sheave axles are test fit in place, but I haven’t decided whether to add sheaves before trimming the axles flush. The fife rail sheave slots are too small to be laser cut. This would probably have been better to let the modeler cut the slots manually or just laser etch the openings rather than cut through. I took five pins and pushed each pin from the bottom of the post until the tip was just protruding from the top. I then clipped the excess pin head from the bottom and used the protruding point to help mate the post to the rail. I also had to re-drill the fife rail stanchion mounting holes about 1/16” closer to the bitt posts for a proper fit. Here the carronades are rigged but again I did not yet add the coiled excess rope. I was also unable to get the breeching line through the cannon ring and had to cut the ring, twist it slightly open, insert the line, and close the ring. A rather noticeable problem is with the carronade elevation. As noted in Tomculb’s much more detailed build log, the carronades are unnaturally elevated. IT’s too late to correct, but it would be better to mount the carronades on the waterway as Tom did. Pic of spar deck looking aft with mast surrounds and eyebolts (haven’t added the ammo scuttles). Looking forward. Things I like: Carronade and carriage detail. Things I would do differently if building again: Modify the carronade mounting to lower the unnatural elevation of the carriage. Add the rope coils. Spend time prepping the blocks. Add sheaves to the fife rail stanchions. Add sheaves to the bitt posts.
  11. I'm learning as I go, for sure. There are so many resources and build logs, but not enough hours in a day...
  12. GUN DECK The gun deck was built with minimal deviations from the instructions. Namely, I added brass scuppers from the waterway out of the hull (later after the Wales are in place) and two chain pipes. I decided not to remove any planks from this deck. I removed the pieces of the pump handles that represented wood and replaced them with bamboo. I made them too thick but decided to leave them. Most of the pewter pieces in the kit were blackened with Pewter Black or Black. I first painted the pumps using Model Shipways Metallic Copper, but I found the resulting pinkish-purple color to be very unrealistic. I removed the paint and brass plated them instead. The result is much nicer. I drilled out the discharge opening and washed the inside with thinned black paint to add some depth. You can see in the next photo just how oversized the pumps are. The stacked pump handles touch the overhead. Had I noticed this before adding the spar deck, I would have removed the bottom horizontal brace and shortened the pump rods, lowering the top part of the pump assembly. It wouldn’t change the scale of the pumps, but would look more realistic, I think. The cannons went together easily. I may add a diluted wash to add some depth to the red carriage and better detail the bolts. Cannons installed. I did not add line coils but may do that later. I painted diluted wood glue on the ropes and weighted them down with items while they dried. In the next picture, you can see that I did not do a very good job mating the knees to the overhead. Chain pipes, lids, stanchions, and ladders in place. Things I like: Cannon and carriage detail. Things I would do differently if building again: As with the berthing deck, do a much better job of mating the hanging and diagonal knees to the overhead. Add the rope coils. Spend time prepping the blocks. They need to be tumbled or otherwise rounded.
  13. Tom - I actually purchased the kit in May 2020 so I've been working at a snail's pace for two years. Once I get the pics of the gun deck, spar deck, and hull planking posted, the build log will be caught up with my actual build. I'm on page 45 getting ready to work on the hammock rail stanchions. - Phil
  14. BERTHING DECK MODIFICATIONS As with the orlop, I decided to add some items to berthing. I used 1/32 basswood to construct the Warrant Officer’s Mess, berthing compartments, and Purser’s Office. The bulkheads are painted white. I used gray for the hinges and knobs as it seemed to blend better without looking cartoonish. I bent the wood to create the rounded corners, but the radius is too large. I should have glued the bulkheads to a 1/8” square post and rounded the post corner. I did not enclose the forward pumps but did add the chain pipes. Note that the portlights/airports are installed later but the position of one on each side did not clear the hanging knee and I inadvertently drilled through a knee when installing the brass tube. The bulkhead additions hide four of the six airports, and I ended up only installing the one on the starboard aft section of the model. You can see a penlight shining through from the outside. One error I made is using the orlop door as a template for the berthing doors. I should have made them the full height of the bulkhead. This is where having an OO scale sailor would be a tremendous asset. I’m still debating whether to replace the doors or not. Another mistake though not as apparent is that I constructed the bulkhead assemblies on a flat tabletop. When they’re placed in the model the bulkheads then naturally lean outwards. Below is a view aft looking forward with the stanchions in place. I also placed the ladders incorrectly, inadvertently blocking the orlop ladder. I would change them, but I used CA at each end after breaking them off too many times already. Last photo is looking aft. You can see where I drilled a hole for the chain tube and used some spare brass tubing. The hardest part was fashioning a wooden ring around the tube. Finally, I added covers and a loop of wire. Things I would do differently if building again: Compare the berthing knee locations with the airport locations and adjust as necessary for the airports to clear the knees. Make the doors full height which works out to about 5’ 6” tall (rather than the 4’6” doors of the orlop. Add detail to the upper door panel showing ventilation. Use 1/8” or 1/4” square posts for smaller radius bulkhead corners. Things I may still do later: Correct the ladder orientation. Correct the doors.
  15. Thanks for the compliment Allan and for the suggested resources. I'll take a look at the RMG images online. As I mentioned, this is only my second model, the first being over 25 years ago. I wasn't going to post the build because I don't think I'll do a very good job, but decided it helped force me to better document for a subsequent build. I don't have a large collection of maritime books, but did a search for those you mentioned. I may try to pick up one or more this summer. HMS EURYALUS (36) 1803 A Plank on Frame Model, Volume I (out of print) HMS EURYALUS (36) 1803 A Plank on Frame Model, Volume II ($80) The Naiad Frigate: (38) 1797 Vol I ($75) The Naiad Frigate: (38) 1797 Vol II ($80) The Construction and Fitting of the Sailing Man of War 1650-1850 ($60 used)
