Everything posted by moreplovac
Yeah, i am leaning towards that as well... Thanks
- 360 replies
- sultana
- model shipways
Spent some time building a ladder. Copied ladder template from Chuck's practicum, and cut pieces. With the help of hobby saw and tiny file i created mortises for each step. And these are really tiny, compare it with a #10 blade.. Cut all steps and used super glue to put them all together. Completed... A little bit of sanding and at the end the layer of stain. All ready for assembly.. Still thinking should i use red paint for hatches (as done in other build logs) or leave it with stain only as it it on the kit box... Will see..
- 360 replies
- sultana
- model shipways
More work on gratings.. Must say those are very tiny parts and fingers are not useful tool to work with them. While assembling, i dropped a tiny amount of super-glue to keep them in tact. Cut gratings to a bit more length than needed as i will sand them down to correct size. I took a bit different approach today. First i would cut the gratings, assemble them to approximate dimension of the opening, mark down the correct opening size, sand them, and then assemble planks for hatch opening. For main hatch i did other way around - first made a hatch box and then gratings. Gratings sanded to the correct size and first plank glued on. Second hatch plank.. Third plank.. Compare with hatch box i assembled, before deciding to use other approach. Last plank and start sending. And on the ship.. Looks very nice i must say.. Happy modeling.
- 360 replies
- sultana
- model shipways
I have ordered few table saw blades for my mini table saw; they have not arrived yet but gratings from Model Shipways have. Oh well, will make my own gratings some times in the near future. For Sultana will use these ones... They will be covering main hatch. Assembly process, cannot wait to get them all together.. Then i marked the main hatch opening that will host gratings and cut them one at a time.. Here they are, ready for assembly. Assembled and ready for sanding for fitting. I put tiny amount of super glue on gratings to keep them together. They fit well on its own but small drop of glue will make my life easier... Sanding is next ... and test fitting... On Sultana and ready for stain. More to come soon.
- 360 replies
- sultana
- model shipways
While waiting for gratings to arrive, painting of cap rail was chosen as a next action. I will also work on building other deck furniture since i will be replacing all kit provided deck pieces. Painting was done with a small brush and flat black acrylic paint. Happy modeling.
- 360 replies
- sultana
- model shipways
Gratings, all about gratings. Made nice strip of it; expected to be a bit out of scales since i dont have smaller than 1.5mm blades for my table saw. Gave it a try, spent few hours making a cutting template, gratings, finding correct wood size... And yes, they are out of scale for this implementation. I believe whole sailor' leg can go thru opening :-) I think they will be perfect for ships in bigger scale but for Sultana they just don't fit. Following Chuck' suggestion, ordered gratings from ModelExpo... Unless someone has a better suggestions how to make gratings in a smaller size (i was even thinking to put two blades together to simulate finger joint set but decided not to as it did not look like a safe move) i will wait for shipment to arrive... Happy modeling.
- 360 replies
- sultana
- model shipways
Eye bolts and rings attached and planks mounted on the ship. Very interesting and realistic results.. Making coamings for other hatchets are on the go. Kit supplied metal casting hatchets will be discarded. I cut the planks to correct length, glue them over the block anvil to get perfect 90 degrees angle. Once all is assembled, sanded all sides on the piece of sand paper temporary fixed on an old ceramic tile. That would be all for today..
- 360 replies
- sultana
- model shipways
Thanks Lou for your reply, i just used the same technique as you described and they are much nicer.. They are very, very tiny....
- 360 replies
- sultana
- model shipways
Not being truly perfectionist but close enough (but no cigar) i decided to make another set of eye bolts. Did not like the shape of eye bolts i made yesterday and result flat black paint left on them. Also remembering that some time ago i purchased coper blackening kit so i decided to give it a try as well. Using a 1.4mm diameter nail as a template for an eye, i made about 16 new. Pour in a bit of a blackening fluid... and it starts the blackening process. Few minutes is all that it takes, and drop them into water bath.. Then they were dried out on the piece of paper. Rings are next. I built one test set to see how it will fit on the plank.. Then i made a bunch of rings using a nail (this time 3mm diameter) as a template. By cutting them i got 20 rings. Good thinking since in the process of cutting i lost 4 of them.. Then i put rings to eye bolts and drop all sets into another blackening bath.. After few minutes in water bath, i removed them and put on piece of paper for drying. So, here they are, planks and eye bolt/ring sets ready for tomorrow.. Happy modeling..
- 360 replies
- sultana
- model shipways
Thanks Imagna, there are few things i will do differently; one is eye bolts. They do not look perfect for my taste so will be redoing them today..
- 360 replies
- sultana
- model shipways
Cap rail was shaped and a bit of wood filler was applied. Ready for a layer of black paint. The kit supplied hatchets are made from metal and are very poor quality for my taste and decision was made to have them done from wood. All hatches frames were cut from basswood, 4mm wide and 0.8mm thick. First one to attack was a main hatch, which will have 5 planks representing cover boards. Each board will have two eye bolts and rings made from 28gauge copper wire. Did not have black wire so bolts and rings will be covered in flat black color. Once main hatch was assembled and glued, i added a ledge that will hold planks on top of it. Then a nice, light sanding was done. Planks were cut to the measurement, sanded them a bit so all 5 planks will fit correctly, the holes were drilled for bolts, and a matching layer of wood stain was applied. The hatch was mounted on the deck. Before mounting i sanded two sides so the hatch will match (such a rime) the curve of the deck. Cutting and gluing hatch Ledge was added.. 5 planks were cut and sanded so they can fit correctly. I did not make these planks perfectly; i wanted to look a bit used.. Then planks were put together with scotch tape so i can mark the holes for bolts. Then i started to work on bolts and eye ring. Had to make a sample of both so i can test the size.. 10 eye bolts were made. These are very tiny pieces, hard to keep them and work on them.. Need some jewellery's tools... Mount them temporary for painting.. and here they are, completed. Happy modeling.
- 360 replies
- sultana
- model shipways
Well, few things in the house that needed my attention and business trip set me away from Sultana.. But i am back, for short time, next business trip coming soon. So, here we are.. Sheet of boxwood that will be used for cap rail was cut and cap rail shape was curved by #11 knife. Once on the ship, the final size will be shaped. The Sultana was placed on sheet of boxwood and traced to mark the cap rail. A 2mm line was marked outside from the hull traced line, and second line was marked inside. These lines will be used to cut the shape.. Using #11 knife i cut the rail that will be sanded to correct size once mounted on the ship. Cap rail was mounted with carpenter's glue and cyano glue. Cyano to provide quick grip and carpenter' glue to bond it permanently. The cap rail was secured with rubber and two piece of wood (these are my home made sanding blocks). Then i was working on hinges, bend them to the shape and put a layer of black paint. And another layer of white paint was applied to rudder. That's all for today. Happy modeling.
- 360 replies
- sultana
- model shipways
Filling with wood filler and sanding volutes few times. Then wait and sand, and again... This i believe will be the last layer of wood filler on volutes. Then, some wood filler used on the hull to fill out holes left after removing the rudder. Not a big deal... New rudder built from piece of basswood, thicker that needed. An another exercise of sanding to bring it to the desired thickness. Marked outlines of the old rudder and cut as close as possible to the lines; less sanding is better. During the sanding process the top of the rudder broke and need a little fix. Another piece of boxwood and voila; all is good. But a bit of extra sanding will be required. Hinge parts are cut and need a bit of flattening... Flattened and ready for painting. Rudder completed and first layer of white paint applied. That is all for today..
- 360 replies
- sultana
- model shipways
Rudder removed and hull ready for wood filler and sanding... Then i cut cap rails, which were painted black on the bottom so i don't have to paint those tiny spots. With this attempt i tried to make a little grove on each side of the cap rails; this should made scrolls easier to mount. Then i started to mount scrolls, very tiny pieces... And all is done... Next step is to fill up all gaps between scrolls and cap rails and to paint all in black.. Well, that is for today...
- 360 replies
- sultana
- model shipways
Yes, i would definitely see it every time i looked at the model so it is worth get it right...
- 360 replies
- sultana
- model shipways
So, decision have been made, i will re-do the work on rudder, it just does not fir right as it stands today... Also i have decided to re-do cap rails as well; i had to deviate slightly from practicum as it does not quite clearly provide process of installing scrolls in correct position when it comes to cap rails. I made cap rails narrowed than needed. Was able to locate another Sultana built log and fellow builder showed his method of completing this task (cap rails plus scrolls) with more info and pictures. And here we are. Making tiny scrolls with toothpicks was not a challenge after making 20+. I am sure i will find 6 that are similar in shape and size. Hull with removed cap rails;new rails will be 5.5 mm wide. Scrolls made out of sculpey and baked as per direction, ready for installation. Happy modeling...
- 360 replies
- sultana
- model shipways
Hi Denis, you are right. You made me look closer to rudder and now i have to make executive decision: tear it down and start again or hope that it will not be that visible :-) For now will just leave it there... Thanks for following...
- 360 replies
- sultana
- model shipways
Hi Imagna, i agree with you; will definitely use your suggestion in the future. Cheers.
- 360 replies
- sultana
- model shipways
Another layer of black paint was applied to wales, after masking the whole hull.. It took me more to mask the whole hull then to actually paint the wales. After paint was dried i applied a layer of varnish to wales - to protect it from my fingers and other dangerous material.. Happy modeling..
- 360 replies
- sultana
- model shipways
No much to report; i had an eye laser procedure so was not quite active in the shipyard. Today i just lay a layer of varnish to protest the hull from dirty hands and dust. Next will "attack" wales with another layer of black, golden oak on hull planking and finish up with protective layer of varnish. Happy modeling..
- 360 replies
- sultana
- model shipways
Another layer of white primer was applied. It looks very nice, not shiny, small imperfections and scratched were covered, and i would safely say that part of hull below wales is completed. Now i need to apply one more layer of flat black on wales and final coat of golden oak stain on hull planking. Then a coat of varnish over the whole hull will seal it all nicely.. Happy modeling.
- 360 replies
- sultana
- model shipways
I have worked on rudder; hinges were assembled with 22 gauge black wire connecting pintles and gundgeons. Then they were cut to the correct length as per plan and with a help of few cyano drops, they were mounted to the rudder. Next, all together (rudder and hinges) were pained with white primer. I am more and more satisfied with results when using primer, more to show. Mounting it on the hull.. Then i worked on wales; two wales were dip into water for about 15 minutes, then twisted to the approximate shape in home-made jig.. The i applied several drops of cyano gel to the hull, and few drops of carpenters glue between. The cyano gell with grab the wales amost instantly and carpenter's glue will help on log run. It takes more to cure but it supposed to be very sturdy. From the front.. In this process of wales mounting, the wales were pre-painted with modeler's black paint which was leaving a black mark on fingers and, which will in turn, leave marks on white hull. Noticing that i decided to re apply white primer on the hull. Using masking tape i covered all ship parts except hull and run another layer of white primer. This will cover dirty spots, rudder and rudder hinges, and small scratches hinges were leaving on the hull. Cap rails were mounted and sanded to the shape and dimension. They should be appr 4mm wide. Bellow pictures still do not show correct size.. In the meantime i painted hull again and it is drying as we speak (or as i type).. i also cover with flat black paint, the cap rail that will be mounted around transom.. Happy modeling.
- 360 replies
- sultana
- model shipways
Absolutely Lou. Now that i am a bit more comfortable and skilled in making those, i might even try to make few new, to have them more uniformed.. But, boy they are tiny..
- 360 replies
- sultana
- model shipways
