moreplovac
Everything posted by moreplovac
  1. The model will be planked above the wales and on deck. This will make significant change in appearance of model so lets get started. This will require some carving on the hull and preparing deck for extra planking. Plank size will be 3mm wide and 1.5mm thick. For this stage i decided to use basswood which i purchased some time ago but strips have to be cut to correct size. I cut it on my Proxxon table saw very easily and precise. Using references marked as W on templates i mark down location of wales which will also be where i will start carving the hull. Carving process will remove app 1.5mm of hull, just above the W mark and all the way to the deck level. First i made a reference line using some flexible wooden plank and running the line with pencil. Rough line is on and we can start carving to the depth of 1.5mm using Xacto blades or any other favourite tool you prefer. I mostly used flat blade #17 for all carving work at this stage and standard #11 blade. I used #17 to score along the reference line marking 1.5mm on the blade so i don’t get to deep. Then start removing small amount of woods, basically shaving it in controlled manner. Started from a mid ship towards the bow, then turned the hull around and shaved to the stern. Just make sure you measure it often, making the grove very close to 1.5mm. Then smooth the surface with sanding. Do spend some time on this process, it is worth the effort. The end results are fairly nice. Then i drew some reference lines i will use to simulate individual plank length. Lines are separated 10mm apart. Each plank should be 6 ref lines in length. You can also cut planks to the size but one long plank will assist in making bulwarks. First one, along the ledge... I also used a jig to curve the planks as at the bow the curve is fairly extreme. 15 minutes in water bath and then slowly put them into jig. Here is my very sophisticated plank bath setup. I am sure that anyone here has its own preferred method to bend planks... Planking jig.. Planking on the way. The idea is to lay planks all the way up to the deck and start another layer of planking from the deck, overlapping them and making a bulwarks. On my way up to the desk, i marked each plank to simulate individual plank length... Tomorrow will cut the bulwarks in correct hight and drill holes to simulate trunnels. The hole will be filled with some wood putty and, as suggested in Practicum, the putty will be thinned with water. Happy modelling.
  2. It is time to start a new build; actually it is time to continue with existing build i started some time ago while still residing in my rented apartment. No room to do much but eager to get back to favourite hobby, i opened a box and started building it. Unfortunately at some point i realized that it is better to drop it back in the box and wait for better times, actually to get to the new place... After some time, my new shipyard was ready and it is time to start it again. So back to the shipyard after completion of Greek Birema, opened already opened box and started new ship building journey. I will be following Chuck Passaro's building practicum for Sultana. I think it is covering very interesting approach to build and very useful for people wishing to get back to this hobby. So lets start... This is a solid hull model, that need some adjustment during building process. First is to remove existing bulwarks that will be replaced with double planking. In the box we have some amount of planking material i will be replacing with basswood that i have in my shop. I will be cutting it on my mini table saw. Here is hull with removed bulwarks, at the deck level hull was sanded and some wood filler added to correct the hull shape. Ok, that is for now; see you all soon.. Happy modelling..
  3. Have not done much these days; still looking for a display case as a permanent destination for Birema. Wondering f you guys have any suggestion about glass thickens for display case? I would need to have, with app measurements: 24"x13"x5mm = for sides; 14"x13x5mm = for other sides and for top 24x14"x5mm Do yo think thickness of 5mm is too much? Can i get a thinner glass like 3mm? I will have a wooden frame to hold all together. On the other token i am still wrapping up shields for mighty hoplites...
  4. So, that would be it for this build. It is done, finished. The only one thing left, which i think is the most important is to build a cover to protect it from dust, fingers, 'let me see how it feels on touch', 'oh Henry, looks at those cute little warriors', etc... For now build sits in my dinning room, waiting for better place and cover. Final thoughts: is there anything i would do differently or what would my project manager at work prefer to say.. "lesson learned", meaning i scr.w it up, how to make sure it will not happen again. The planking material is very good but to be precise and history correct, i would be very surprised to have ancient Greeks making planks in the length of the ship. For next time i would definitely make it more realistic and have planks in correct length, using some of techniques tested on this forum. The shape of the hull is very nice and to make it more desirable i would be doing double-planking, shape the hull with some putty if needed and start second planking. Forgot to varnish the inside of the ship during build process when it was very easy to reach. Ended up twisting the brush to reach some of hard reachable spots, particularly where oarsman should be sitting. Kit plan does not cover all details, particularly of keel ornament position. Turned out it has to go all the way to the main deck, where captain's enjoying the view but i was under impression it has to stop just shortly passing those two dolphin fins. Suggestion to kit manufacturer - spend a bit more time to make plan more detailed. Not that is a big deal but it would be worth effort. There are some small items i already covered in the log so no repetition necessary. I am still working on hoplites, painting the shields and marking them. Was not too happy with my first attempt so will be completing it today or tomorrow. Once Greeks are on board will snap few more pictures but for now, here are final pictures of the build.
  5. Hi John this is very good advice. Thanks, much appreciated..
  6. Thanks Dan Vadas, i dont think you are cheap, i think it turns out to be like that when you spent too many hours into something you like to do. Just hard to find correct price.. Appreciate your response.
  7. Thanks Tom, all makes perfect sense; Yeah, once you start charging for a hobby it becomes work, work you like to do but it is still a work.. Appreciate prompt response.
  8. Thanks Kurt, appreciate your advice.
  9. Thanks John Allen, it appears that like in any other contract job you have to cover your self very good in case something goes southwards. Occasionally i get lucky and pick up some good wood for shipyard but far away from being able to make millions. I think better chances are with Lottery tickets :-) Thanks again, appreciate your response.
  10. Absolutely right; i do enjoy building models and have a real job so cannot spend full day in shipyard.. The threat i started is what bothered me in the past and just wanted other fellow builders opinion in case something cones along. Appreciate your response.
  11. Hello, hope this is correct forum for this type of question; if not pls direct me and i will repost the question. Wondering if any of you, experienced or less experienced builders, had opportunity to build or did a kit building for a small profit? Model building process takes time, resources, investment and would like to hear how did you present the final bill to your customer? What could be an average cost to build, lets say 1:72 scale size wooden ship model? If for example, kit cost is $700.00, some material (glue, wood, tools) is $300.00, the amount of time to build it is 900 hrs, what would be a decent, cannot say fair price, for final product? If you charge 3 dollars per hr, this gets to $2700.00 to the total of $3700.00. I understand this is a hobby but sometimes it is nice to blend hobby with some extra cash which can be used to buy more kits, tools., etc. Appreciate your comments.
  12. The hoplites finally got their weapons, still missing shields. That is next on to-do list. It is oars time. Oars supposed to be sticking out differently depending if the oarsman sits closer or further from the ship edge. Used very "sophisticated" template, marked length A on 20 and mark B on other 20 oars. Started to mount 40 oars. I had to come up with some sort of template so oars can be on, approximately same level. Happy modelling..
  13. Today i worked a bit on hoplites' spears; cut and sand them into correct diameter, "sharpened" spears' heads and paint heads in silver. I found out that doing this from toothpick is better that making them from some other scrap wood part; toothpicks appears to be fairly strong when sanded into less than 1mm diameter. No cracks or broken spear. I cut spear head in approximate size using razor blade and then sand it to correct shape. Then a tiny layer of silver was applied to simulate steel head; some weathering will be applied later. I applied a small layer of varnish on hoplites' new, wooden stands. Once heads are dried i will paint shafts in some wood-looking colour to simulate ash or other wood types used in making this weapon. I also need to mount all 48 oars and few other ship parts; this will most likely be done sometimes this week. Happy modelling.
  14. Not that complicated ship rigging is done. To make a rope a bit more straight to get the impression that rope is tight, i used white glue to stiff the rope a bit.. Then i start cutting warriors of the base so it can be replaced with a wooden base. Did not like base colour and the fact that is sticks out to much. So instead of painting it i decided to replace it. Out of some spare lumber i cut 8 new bases and sand them to shape. After that i started to work on spears i planned to replace. Here is first prototype, need to scale down the front end of it, looks a bit to big. Have few pictures from the net so i will scale it to size that fit better.. And the whole ship looks like this, oars are still to mount... And for some reason just cannot get those guys of the ship... Happy modelling.
  15. There is a time in building process when you need to attack rigging; regardless of its complexity it is always a fun process to go thru when you have tiny ropes and big fingers. So, here we are. The rigging for Greek birema starts with making eye splice for two ropes that hold the mast in vertical position.. These two ropes were completed and waiting for a next step. Then i mounted compete sail to the mast.. Here is the process of making a "fake" rope ends... Once completed it was mounted to the end of the rope and "casually' throw to the ship.. I did similar technique for other ropes... So here is end result.. Then the two ropes holding the mast... This spot for a rope was very tight but managed to get it thru.. Then the part on bow.. That was all work done today. The ship has few more ropes to be installed.. So this is how birema looks so far. And at some point friendly hoplites decided to jump on board too.. Happy modelling ..
  16. Wrapping up this kit build slowly. Today i finished installation of captain's seat, decorations, mast and started to work on ship stand. For now i will be using stand that comes with the kit; later will come up with something else, a bit more eye catchy.. I also spent some time thinking about oars positioning and how to make sure, once installed oars will not move in and out, up and down. For now made two measure template i will use to position oars inside of the ship. Not to high-tech template, coffee stick from Starbucks, cut to length.. Then, it was time for captain's seat, decoration (Lion's head) and other. For lion's head i also use a small peace of balsa to get some good grip since the decorative head has no that many flat area. Seat and decoration installed. Happy modelling..
  17. Today i spent a bit more time with painting friendly hoplites. Some touch-ups, painting the swords, one dude' hair that was sticking out of helmet (i nicknamed him a Hairy Harry), etc. Hairy Harry is second from the left... While i was waiting for a paint to dry out, i was thinking about spears that come with the box. They do not look quite good; most of them are twisted and usable to some extend. Noticed few toothpicks laying around and some 80-size sand paper, i started to shape what turned out to be really decent looking spear. Did some google-ing and find out a painting of hoplite with a spear that looks very realistic. Spear is longer then ones included in the box so i decided to give it a try and see if i can get a decent-looking spear to replace plastic one... I did not use my mini lathe; rather just a sand paper and was able to make a spear that will work, i think much better on the warriors.. Like i dont have nothing else to do with this build, it is a go decision - i will make at least 6 new spears for my hoplites... I believe spears will be about 45-50mm long (that is kind of my rough estimate and measurement taken from the above internet picture) with 1mm of thickness.. I am expecting to have several broken ones as my fingers might be to big for such a delicate work... Unless i break several of them in my attempt, i think i can get there in a few hours. Happy modelling..
  18. Today i painted second coat on mighty warriors. Some touch ups and another layer of varnish on the ship. This painting/varnishing process is not very exiting. You can run another coat of varnish which takes about 5 min and spend 10 minutes cleaning brush... Oh well, more to come soon. Happy modelling...
  19. Warriors are getting some paint... They are very tinny for colouring, using lamp with magnifying glass to assist. I can also do some manicure in the same time.. Need to do few more layers of paint as the toys colour is dark grey and very hard to cover with either white or yellowish.. Was thinking to test different approach on few of them: to cover them all in white or skin colour, then to continue with other (red, gold, solver) or to cover them in flat black and then the same process. Will try it for sure. Happy modelling.
  20. Today i finished up the ram by adding few pins to simulate a way to fix ram to the ship. Not sure what techniques was used back in days but i think they had some sort of iron pins for this purpose. I painted the pin head black but during installation process some of the paint was removed. Not a big deal.. I also drilled a pilot hole for pins. Had to make particular attention to the top corner of ram since the pin will be visible after installation so i ended up cutting most of the pin and leaving only head with few extra mm in length. And installed. Then the Hoplite arrived.... Finally i received a box of Greek warriors (Hoplite) figures i planned to put on the ship. The reason for having them is to give a bit of a scale vision of ship size. The scale of warriors is not quite matching the scale of the ship but it is fairly close... They have made in China, sold by company in Austria via Amazon and shipped to North America. I was actually surprised with the level of details these small dudes have. It will be interesting process to paint them in the colour of ancient world. This friendly dude will definitely have a place on the ship; he is the leader and must be there.. Not sure how many warriors will be enjoying the mighty bireme but i am planning to have them 4 or 5. Will see.. They also need to have shields and spears so here they are. This part is not quite good but it is workable.. Then i decided to run a first layer of protective satin varnish on the hull. I used this product in the past with satisfactory results. Will need several layers of it. This complete the work for today. Will continue with varnish and painting warriors. Happy modelling.
  21. Thanks Don, i will definitely keep that on mind for future projects. I was actually contemplating of using markers but on test runs i was not getting quite satisfactory colour shades. To modern for Greek bireme..
  22. I finally finish painting ship eyes. They took me a while and two attempts as my hand was not steady enough and slightly stronger push on the brush resulted in wider line that expected. So remove all and start from scratch. I wanted to have a more mighty look particularly when you look from the enemy' perspective to the approaching ram. Later in painting process i came across one picture that really shows how mighty eyes should be looking but it was to late to start painting all over again. So it is what it is.. And from enemy's point of view: So, this activity completes this stage of the building process. Next is few layers of protective coating, mast, sail, captain's chair, oars and stand. More to come soon.
  23. Getting there, getting there. Started to work on eyes, painted them on both ends. Need to work on pupils today and some touch up since i painted it all by hand, directly on the ship. Very good brush is all what is required and some acrylic paint.. Need to fix that top of the ram, accidentally damaged it with flat strip decoration. More to come..
