HIPEXEC
Everything posted by HIPEXEC
  1. I have all these rail supports and no rods that fit thru the holes. Thats why I need the thin rods. I have way more of the fat rods then needed. Hmmmmm
  2. I made a display base out of mahogany with the brass supports I bought with this kit. I’m having a brass plate made that says “F.D.N. Y. Fire Boat”
  3. Mr BlueJacket your kit didn’t provide enough grab rail rods F1159 to finish all grab rails. there is too much ladder rail rods. i need F1159 thanks
  4. In case you’re trying to figure out how the water cannons suddenly appeared, well, I built them during the weeks i had to wait for the kit to arrive.
  5. Adding more detail. Decals and running lights. the superstructure broke off the hull so i had to re-glue it?
  6. Adding details to superstructure and marking with tape to make sure superstructure is located correctly when glued
  7. i finally adjusted the base of the superstructure to sit level on the deck so when i glue it later it won’t wiggle loose
  8. No, you sent it to where i luve now 14810 N Fountain Hills Blvd Fountain Hills AZ 85268 thanks Rich Hippner
  9. Finishing up the superstructure. It’s not attached to the hull yet. a lot of little details yet to be installed
  10. Nic Thanks for the new Flat Red. Where did you ever dig up my old address? I haven't lived on Carol Ave for ten years!
  11. I finally finished the gunwales! Now i can move on the the superstructure more than met my eye!
