HIPEXEC
Everything posted by HIPEXEC
  1. Building the upper deck so it starting to look like The Spray
  2. The semi-finished deck has been placed but not glued down. I've rough cut the viewing holes so the entire below decks areas will be visible to see exactly how Slocum lived, ate, slept, and subsisted during his epic voyage.
  3. I've drawn the cut lines on the real deck using the template I created. I'll carefully cut out the open areas next.
  4. I'm making a template for all the holes in the deck I'll need to show Slocum's cabin, galley, and storage
  5. The USMC build this fabulous display case for my Argus! It'll be on display in Quantico VA . (See pics below)
  6. Still trying to clean up the poor planking job I did. I need a lot of filler and sanding. Oh well? Old age creeping up on me.
  7. I found that planking over frames instead of bulkheads is very different. The hollow frames tend to break or crush if too much pressure is applied when bending planks. I had to repair broken frames several times. I had to do a lot more pre-soaking and pre-bending to get this model planked. 🤪
  8. I'm still planking but I didn't want to bore you with the glacial progress of the planking process. I'll take a photo when I'm finished.
  9. Scratch building is great! I didn't like what the gunwals looked like from the deck up, so I sawed, cut and ground all of it off! I'll redesign it after I finished planking the hull which I have started.
  10. I've finished rough decking the inside of the hull. Aft cabin dry fitted only
  11. I'm close to finishing the internal decking. Then I have to design and install deck framing to keep the inside open for viewing.
