John Murray
Members-
Everything posted by John Murray
Today was spent getting things ready to cut the frames. I laminated the 7 sheets so I can assemble the wood pieces over the laminated frame with pins and glue. It won't stick to the plastic. I also planed down 5 planks of 10mm thick English Lime to the five thicknesses I require for the two dead flat frames. The five vary in thickness from 5.5mm to 4.2mm
Last yr I made a trial keel of the HMS Echo cross section available at http://www.admiraltymodels.com/Tips.html I had life intervene but I want to start building the cross section. The last few days I have spent building another copy of the keel. It came out ok. Thinking about the completed keel I realise a few ways I could speed up the process as well as make it a bit more accurate in cutting the slots of the rising keel. Last yrs keel on the left, the new keel on the right. I have a question now that I am ready to start on the frames. The instructions call for starting on the dead flat available at http://www.admiraltymodels.com/Echo_frame__dead_flat__1.pdf My reading is that each frame comprises two sections, a fore and aft frame. All of the frame numbers have fore and aft indicated on the pdf except the Dead Flat. Yet, It seems that there are two distinct sets of futtocks for the 2 dead flats as shown in http://www.admiraltymodels.com/Sided_frame_dimensions.pdf I am not understanding this obviously so can someone point me in the right direction thanks?
After putting it off, I tried debonding the stems broadstrake planks. I used my electric plank bender to heat it up and I was surprised how it came apart. I have now left it tonight and will clean it up tomorrow. I will also ensure the stem is properly braced so it cannot move next time I glue the broad strakes in position.
48th Scale imperial rulers. Where?
John Murray replied to John Murray's topic in Modeling tools and Workshop Equipment
Thank you very much for your kind offer. Unfortunately, I ordered one and then read your offer... Doh! -
I have just ordered one, not starret though. Couldn't find one anywhere then this forum turns up loads of responses. -
Just ordered it. -
That will be the 3rd ruler from BNA... 🤣 However, that does have the scale I am after on it. Strange thing is, when I searched BNAs website, I did not find that one. -
Thank you for that. I shall try that. 🙂 -
Morning All, I am in Australia. I have searched for 48th scale imperial rulers with no luck. I have bought two so far but whilst they both have 1:1 imperial scales, they both have the 48th scale reading metric as in the attached pic. I don't want to keep importing this sort of mistake. is anyone familiar with somewhere that does have this scale ruler?
I have the broad strakes on now. I am disappointed in the stem. I did not pick up the fact that the stem had twisted slightly when I was bracing it while it cured. There is a slight twist in it.🤬 I left it for tonight while I consider whether to plow on or try and debond it which may affect the other three ends in there as well.
Kevin, I have just found this build. I have only seen the 1st 5 videos so far but am thoroughly enjoying them. I too bought the set of books a few weeks ago. I have the plans for the Atalanta from the NMM. Cost a bit, but hey... I am only working on the Model Shipways Dory right now to get up to speed and have a couple of kits to do before I tackle this sort of project. A few yrs I suspect, but I will have everything hopefully that I need. I look forward to catching up the videos...
- 1,132 replies
I started my 1st model boat in decades. It is the Dory from the 3 kit kombo from Model Shipways. I got this kit not for the subject but to bring me up to speed hopefully as I progress through the 3 kits so I can tackle more advanced kits. The instructions are good, although there are minor things that took me a while to catch on to. I initially did not realise the garboard planks were not symmetrical. The tapers at each end are different lengths and I did not pick this up until after I had bent the planks and held in place to set the bends. I suspect that is for trimming to final size. Apart from that, there was no issue.
I have had a look at the NRG Saw jig. I will be looking at getting one. For a push stick, the Proxxon Planer I have comes with a plastic push stick. Seems fairly soft so if I touch the blade, It should just cut into the push stick. I recall my father using those terms and had forgotten what they referred to. He worked in shipyards for a long time. I cannot see myself getting to the stage of harvesting my own timber. I follow a few YT sites where they do that. To much investment of time, space, and money. Apple = Malus Sylvestris? Correct? I have a supplier of rare timbers in Australia down the road from me. The list of product is here. https://www.bukartilla.com.au/timber/2014/3/31/timber-list The only issue I have is telling Balsa from Plywood! Let alone any of the other species named...
I discovered the limitations of the disc sander fairly quick... I currently have a dremel with a drum sander set. I have yet to use it so will investigate. If no good, I shall try looking further into it. I have the Proxxon vax hooked up and wear a mask. As you say, an impressive amount of dust is generated. I live with my son. My wife died 13 yrs ago. He doesn't see mess so dust doesn't bother him... 🤣 I have all the tools in the garage though. I shall have a look at your build log. Thanks for that.
I understand what you are saying re the quilters pins. I have Lightroom and Photoshop, graphics programs I have no issue with. think I understand what you are referring to your jig. The penny dropped when I realised you were talking fonts! I do not currently have the skill set at lofting plans from lines plans. Hopefully one day. Your tip re the butt joint is appreciated.
Thank you for this. I am starting to understand what you are saying and can see the benefits. FP and AP? I have considered buying a bandsaw but am aware that there are things I don't know and will probably buy something not suitable. I have ordered the following to get me up to speed before starting the Pegasus. https://www.hobbytools.com.au/Model-Shipways-Shipwright-3-Kit-Combo-Series-1-24
I do have a set of digital calipers, they just aren't in the pics. NRG saw jig? I have a push stick that comes with the Proxxon planer. Is that what you are referring to? I am on two blood thinners and anti clot agents and am very careful around stuff that bites. This is why I never got into woodworking. Seeing the spinning blades was enough.
Cheers for that I do have digital calipers, they weren't shown in the pictures. Re the wood, I shall take onboard your suggestions. I am not a woodworker. Wood names mean nothing currently as I am not a woodworker> I understand on the leaving extra for final shaping. This was a once off to enjoy. I shall look into spoke shaves. I have ordered the following to get me up to speed before starting the Pegasus. https://www.hobbytools.com.au/Model-Shipways-Shipwright-3-Kit-Combo-Series-1-24
Cheers for that Jaager. I am still reading your further responses and will reply to those later today once I have absorbed them. POF and POB, yup, I got the difference now. I wasn't sure of the terms, so many to learn. A bit about me is probably in order. I have been interested in models my entire life. 63 now, I remember my first model back in the mid 60s. For me, the enjoyment comes from trying new things to learn. I am not interested necessarily in completing models, but learning new techniques and tips from each model. If I complete it, that's a bonus. I have done several wooden boats in my late teens and really enjoyed the experience. I understand that each genre of modelling has its own unique skillset to be learned. I am under no illusion as to what I am looking at. I recently found Ohla Batchvarovs Youtube channel and that rekindled my interest in wooden models. After I emptied her channel, I noticed her doing the Pegasus. That appealed to me. I recently was lucky to be able to indulge myself as a once off and buy the Pegasus as I had received a compensation payout. Many yrs ago, I bought The anatomy of Nelsons ship by C Nepean Longridge. I was fascinated by the subject. Looking further over the yrs I found myself drawn to the 74 gun ships over the 1st rates. Something about them appealed to me. The price of kits in Australia is very high. I had looked online and found a supplier in the UK and decided to buy the Vanguard as well since it saved me 50% of the price compared to buying in Australia. So, now I had 2 kits. Recalling my earlier model boat experiences, I wanted some machinery to assist me. I found the Byrnes saw and bought one. I bought some Proxxon tools as well. This was due to the fact that as a once off, the cash would not be there in the future if I wanted to indulge myself. So, 2 kits and some tools were arriving. I then stumbled upon the Seawatch books website. I saw there was a 4 book set of the Swan class as a scratch build. It seemed fate was talking so I bought them as well as the plans. Now, I have the gear I need and was facing the daunting task of actually doing something. I have just bought https://www.hobbytools.com.au/Model-Shipways-Shipwright-3-Kit-Combo-Series-1-24. I believe this is what you were referring to. I do think this will help me get up to speed to tackle the 1st of the kits. I shall reply to your other responses later as I read them and understand. I appreciate your detailed responses.
Cheers, My first test was a cant frame. This was frame K of the Pegasus. Re the Basswood, I bought that to act as a filler in between bulkheads on my two kits, especially near the bow and stern. That isn't for actual frames. So far that is the only wood I had available which is why I used that. Never heard of rubber cement, I will visit Hammer barn and see what they have. The PVA was at hand. I do take your point re the thickness. I would appreciate your thoughts on what you see. I am a complete beginner at woodworking. This is only done to familiarise myself and have a play. I have 2 plank on frame kits to do first before I consider a scratch build.:)
