TJM
Members-
Everything posted by TJM
Log entry 21 It has been a few days since my last update while I have been working on the main and foremasts. It took quite a bit longer than expected! There really is a lot of components on them once you get down to it. And this was also a small start on the rigging, as there is quite a few blocks that need to go on. I decided that I would need a small break from masts and booms, so I started adding the shrouds. I am reasonably happy with the result so far. I made a small mistake and used the 0.25 mm natural thread to tie the shrouds around the upper dead eyes - it should be 0.1 mm. I will just go back and replace them before I continue. This is the 90 hour mark of the build. Either I am working very slow, or the 70-80 hours build time listed in the manuel is without rigging! 😅. But no worries, I keep having fun and are already planning future builds in my mind 🤪. Question: I have a question though: the manual says to use the tiny 0.1 mm natural thread for the ratlines (when I get to that), however, are they not too thin? That would correspond to a rope diameter of only 6.4 mm! It may just me ignorance on my part, but is that not too thin? Using 0.25 mm thread, would correspond to 1.6 cm rope - but is that way too thick? BR TJM
- 152 replies
- Flirt
- Vanguard Models
I would recommend attaching the keel now! I did not do that, and was left wit a gap that I had to fill! I guess the keel will be at risk, getting knocked off, but if I did it again, I would do it now. Or leave the garboard plank hanging over the edge, to enable trimming back to the 3 mm keel width later. But that could also be tough to get neat! Your capstan and anchors are looking really nice! And the hull is VERY neat and crisp 👍
Log entry 20 I have been working on all the deck fittings over the past few days, an I am very nearly there. Just missing the pumps and the anchors, thought the latter wont really be fitted until a bit later during the rigging. The manual would also have me assemble and attach the swivel guns now, but I will hold off on that, as I am sure I would bend and crunch them during the rigging! They will probably be some of the very last things to be added to the ship. This is the status now: I am very pleased with the look and relieved that the paint job turned out well as it did. And without any spills and drips on the deck! Phew! After I finish the two pumps, it is on with the masts - a very different part of the build. It will be interesting to work from the plans as opposed to the manual (though the manual still sets the order to progress and provides some helpfull images for reference!). Fortunately, I know where to ask if I have questions! TJM
- 152 replies
- Flirt
- Vanguard Models
Very interesting and I think I understand what you mean, but can't find anything that seems suitable - can you send image or a link for the type of heliostat pliers you use?
- 152 replies
- Flirt
- Vanguard Models
Thank you! But I really can't take any credit: I was inspired by the Sphinx build by @Blue Ensign, and basically copied his colour palette! It just looked so good to me! It was actually for a large part due to that log that I finally took the plunge and bought the Flirt kit, after having lurked here on MSW for a while.
- 152 replies
- Flirt
- Vanguard Models
That sounds smart! As a chemist, I approve! But that would entail making the eyelets yourself I guess. Also a fair bit of work! 😉
- 152 replies
- Flirt
- Vanguard Models
Thanks! I did prime them black with a rattle can primer. Normally it sticks pretty well to the metal, but it cant take the handling I give it with the pliers during application. But I agree, I want to avoid too much glue spillage. And there is no chance of me handling the small eyebolts without a tool!
- 152 replies
- Flirt
- Vanguard Models
Thank you all so much for the nice comments and likes recently 😊! This is such a great community! Log entry 19 Quite a bit of progress since the last update: I started by assembling the headworks - it went quite smoothly! Then I added the water level guage on the bow. I was worried about getting the alignment right and also about getting CA glue splotches on the wood that would be impossible to remove afterwards. My solution was to make a copy of the full size plan and cut out the relevant part AND the roman numerals. That made a nice template for positioning the small brass pieces: I held the small numerals with a toothpick with some wall gum (don't know the English term, in Danish it is unflatteringly called 'elephant snot'!). The result was neat and clean! Then I added the racks for the belaying pins and the pins themselves. This was frustrating work, as the racks repeatedly came off as I inserted the pins, no matter how gently I worked and even though I had used brass pins to strengthen the connection as per the manual. But I managed in the end. Then I added the channel parts, using some 0.8 mm copper wire to strengthen the connection with the hull and I have now managed to add all the deadeye strops and deadeyes for the starboard side. Port side will follow soon. I I am really liking how she looks now. There will be a bit of paint touch ups on the blue and on the wales where I have scratched the paintwork when pinning the deadeye strops, but nothing that won't be fixed easily. I actually also stated adding the tiny eyebolts around the gunports, but I am really struggling with the tiny parts and the paint is coming right off when I hold them with pliers. This is going to take a while and if anyone has any good tips for how to handle these tiny parts, it would be much appreciated! TJM
- 152 replies
- Flirt
- Vanguard Models
I should have done that as well on my Flirt! I noticed it a bit late and elected to add a bit at the ends to make them long enough. Your way is better! But interesting to see that others have found these pre-cut parts a bit on the short side! I thought it was just a mistake I had made (still may be, of course...!) Looking very nice!
- 144 replies
- HMS Speedy
- Vanguard Models
Thank you for the compliment, much appreciated!
- 152 replies
- Flirt
- Vanguard Models
Thank you so much for all the kind words and the encouragement! It is truly appreciated! I am kind of looking forward to the standing rigging but am still a bit worried about the running rigging. I know I could stop after the standing rigging but I suspect I will not be satisfied with that 😉.
- 152 replies
- Flirt
- Vanguard Models
There are other German or Czech sites that offer the original manual for Vanguard Model kits, but I am not sure about the policy concerning links to those here. But Google will provide the anwer!
- 152 replies
- Flirt
- Vanguard Models
Yes, the only reason I got German manual and plans is because i purchased the kit through a German retailer! I have printed the English manual, but I am still left with the German full size plans. This is obviously only my own fault and I am just very grateful that Chris has the manual available from his website!
- 152 replies
- Flirt
- Vanguard Models
Really!? Wow, that must have been tough with a 200 ton boat! Thanks for the compliment!
- 152 replies
- Flirt
- Vanguard Models
Log entry 18 A fair bit of progress. I have added the gunwales, painted the blue section and added the swivel gun post timbers. I also added the stern post and the rudder (not glued in yet). With the painting, I am trying to not use all flat colours, by adding a bit of shadows with washes or adding som edge highlights. As a long time miniature painter, I have a bit of an aversion to flat colours, especially on areas with surface detail (like hard edges). I think I may go over the blue and clean up a few things, but overall I like the look. I also went for a much lighter and less saturated blue than the manual, as well as a darker, more muted yellow. It is Vallejo blue gray and yellow occre respectively for the base colours. BR TJM
- 152 replies
- Flirt
- Vanguard Models
Log entry 17 Quite af few things have happened since the last update: I attached the keel and filled the gap between the keel and garboard plank with scrap strips af planking: Now that changes the profile! I then masked off around and painted the wales. To avoid paint running under the masking tape, i primed with varnish to seal the edges of the masking. Then I primed black, but inspired by the brilliant Sphinx build by @Blue Ensign, I decided to paint in a slightly lighter shade than all black. I tried with Vallejo black gray, but found it a tad too light. It looked a bit too gray instead of 'light black', if that makes sense! So I mixed it with black in a 2:1 ratio and liked the result better. The edges are highlighted with the neat black gray, though the effect is very subtle. The masking worked great and I had very few touch ups to do when I removed the tape. I got some nice, crisp lines which I was very relieved to see! Then a few details were added along with some paint touchup around the gunports and this is now the state of my Flirt: It is slowly starting to look like something! TJM
- 152 replies
- Flirt
- Vanguard Models
Regarding the bulwarks, I did something very similar on my Flirt, i just used an electric iron. Worked like a charm! A slight moistening of the plywood and ironing on low heat allowed be to shape the bulwarks to the bulkheads. I did not even have to use sny glue above the deck level. Yours are looking good!
Log entry 16 Gun ports have now been opened. Thanks @allanyed for the tips, it worked well, though I am happy that I only had 22 openings this time around. Doing this on a 74 would have been a chore! Now my lack of knowledge of ships shows itself: what is ther purpose of the small holes between the gun ports? I also added the wales, which went easily and sanded everything (though a bit of touch up may still be needed here). Oh, and as you can see, I couldn't resist lining up the 7 guns I have assembled while glue has dried in various steps of the build so far! I have the other 7 painted as well, just need the final glue up. Now for trimming the wales at the stern and adding the keel! BR TJM
- 152 replies
- Flirt
- Vanguard Models
Log entry 15 I have now added the last 5 planks on both sides. I first sanded with 120 grit and was very pleased with the result. There were, as expected small gaps between planks here and there, and I had gathered the sanding dust, so I mixed it with pva and filled the gaps. However, I discovered that the pva I use does not sand very well! It smears instead of being removed and it took quite an effort to remove the excess filler, even though I added very little and wiped it off the hull itself after application. But after a few hours, I had a nice hull sanded with 240 grit. While there are minor issues here and there, it turned out better than I had hoped! I think I will keep it unpainted - this looks good enough for me. The only really bad issue is at the stern, where I had to use a bit of filler. It does not look that nice. But I think I will have to live with it as it is. I will now open up the gun ports and then it is time for some varnish of some sort. I thought I had a satin polyurethane, but it is matte, and I think that will not be the best. I will find some satin polyurethane varnish and make som tests. But I found my airbrush, so I have the option to spray varnish, if I want to. TJM
- 152 replies
- Flirt
- Vanguard Models
Thanks! I do have the manual printed in english, so only my full size plans are left in German. But I will reach out if I run into trouble with them! BR TJM
- 152 replies
- Flirt
- Vanguard Models
Hi Allan, I have tried a few things, but not drilling out most of the lines before cutting. I will give it a try now with the ports in the outer bulwark planking.
- 152 replies
- Flirt
- Vanguard Models
Welcome! As a newcomer myself, I can already attest that this is a great and very helpful community! I am thoroughly enjoying my own first build, also of Flirt and based on the beautiful result you achieved with the small pinnace, I think you will have no trouble with Flirt! I look forward to following a fellow Flirt build! TJM
