CaptJoe
Members-
Everything posted by CaptJoe
Have you looked at the USRC Harriett Lane (Model Ship MS2270 kit)? Sail/steam 1857. It's on my to-do list.
Checked the build logs, and a couple reported a similar problem, but no one mentioned any type of solution or recommendation. I'm surprised there aren't more articles on some of the basic metal fabrication processes. For the tiller arm, it would be easy to just cut the wire flush and glue it in on both sides. But the extension handle must rotate, so that's not an option.
Just started modeling. Got the three-vessel starter kit and finished the dory. Lot's of learning there, mostly, make sure the base is secure and properly positioned or EVERYTHING goes sideways. I'm just finishing the hull on the Norwegian Sailing Pram. The instructions for this boat seem to be much less comprehensive. The metal work (on the tiller assembly) is really making things difficult. Anyone have any pointers for hammering the end of a wire into a "mushroom" for a rivet? So far, I've bent one wire and split two pieces of wood. This is far more difficult than portrayed in the instructions. Thanks!!!
Any word of wisdom on the tiller metal work? The "gentle tap" required to create a mushroom on the end of the wire is extremely oversimplified. So far, I've split the wood on both tiller extensions (easy enough to make more) and bent the wire on the main tiller. I think simply gluing heads on the ends might be far easier.
- 23 replies
- Norwegian Sailing Pram
- Model Shipways
I couldn't understand how to place the supports without shaping and fitting the thwarts at the same time. Very difficult to get the supports "level" for mounting the thwarts. Also, the stern sheets are to be "connected by two cleats", but no source for the cleat material or placement is noted (sigh!!).
- 45 replies
- norwegian sailing pram
- Model Shipways
An errata sheet is definitely needed. Several mistakes and MANY omissions are making this project more difficult than it should be.
- 45 replies
- Model Shipways
