Madin
  1. Hi guys. im totally new here and wanted to ask you about this particular model. I’ve started plunking the hull, but im a bit confused. I have two kinds of wooden sticks (not sure how you call them), the super thin one and the thicker ones. I’m not sure which one I should use for the hull and which one for the deck. Also; I’m reading that the hull needs a cover up? Are you using the thin ones for the first and the second layer? many thanks!
  2. Hi guys. im totally new here and wanted to ask you about this particular model. I’ve started plunking the hull, but im a bit confused. I have two kinds of wooden sticks (not sure how you call them), the super thin one and the thicker ones. I’m not sure which one I should use for the hull and which one for the deck. Also; I’m reading that the hull needs a cover up? Are you using the thin ones for the first and the second layer? many thanks!
