David Chapman
Everything posted by David Chapman
  1. Thanks for the welcome and the great advice. Really appreciate it. This is my work space and where I'm at today. Long ways to go!
  2. Question, In the instructions it shows gluing the ship to the stand early in the build. I worry that might restrict flexibility in painting. Can/should I wait until closer to installing masts etc? David
  3. Kevin, Both your suggestions worked! Putting a subtle back bevel on the edges of the decks with a file really helped. Dry fitting the decks now look highly satisfactory. Also anticipating that these scraps of plastic for support will do the trick. Thanks again, David
  4. Kevin, Thank you so much. I'll give that bevel sanding a try but still pretty sure it won't hide the seems. Thankfully the cabins will cover most of it. Sanding off the positive plank lines and replacing with negative scribe lines I don't quite understand. Sounds very challenging. David
  5. I suspect this may not be the place for my question so I apologize. Just getting started on the Revel Cuddy Sark 1/96. I did not plan on overlaying a wood deck. My question is how do I hide the seams of the plastic deck. Also it appears to suggest the 3 deck pieces are butt jointed, painted and glued before installation. Having pre fit the 3 decks, I don't understand how that's possible without breaking the seal. Should I glue some pieces of plastic across the underside of the 2 joints to stabilize the deck or...? David
