Amedeo Riga
Everything posted by Amedeo Riga
  1. Mouldings mounted and ready to proceed with the coloring. I had to make from scratch the rudder as it went lost years ago when I abandoned the project. Happy with the result so far.
  2. Coloring the hull in progress….the kit suggests a white color for the bottom part…but I decided to make it black.
  3. Planking of decks completed. now started with the hull coloring. 1st layer of white done.
  4. Few imperfections on the hull covered before the coloring. Started the re-planking of the decks. Fwd deck done.
  5. After 15 years since I abandoned this project , today this is back on the table.
  6. Doing some progress with sails bending , mounting the yards and running riggings. Unfortunately run out of 4mm blocks. Just ordered and waiting for them to arrive. During this fase I learned a lot about sails and for the next project I will have a different approach. I will sew the bolt rope and the clew patches onto the sails, and I will use a different method for the bending.
  7. Hi Roland….is a nice kit…you will enjoy building it…for any inquiring along the way I will be happy to share my expirience. those are the stones included in the kit.
  8. Ratlines completed…treated the sails with the dark tea…now all ready for bending the sails to the yards.
  9. Thank you for the message..I m currently working on the Santissima Trinidad , Spanish vessel from 1769 , flag ship of the Armada spagnola.
  10. Hi Paul …thank you for your message .. yes I m refering how to tie the sails to the yards…many tutorial show using a single ropes and sewing with a needle, but I think this is not the most accurate technic ..right?
  11. Hello modelers , I was looking for some tips for the ropes to attach the sails to the yards. Interested in learning technics.
  12. Great model....can i ask you something about this model as i m thinking to start this same project soon. This is the Artesania Latina kit right? there is only 1 planking for the external hull (like in the original bounty) or there is a second planking? thank you
  13. Yards completed. The mode has his own spot. Now I have to put the modeling in pause for the next 3 months due to the job. See you in December…
  14. Not happy how the ratlines were looking…so cut down everything and started again…what to do…that s part of the ship modeling…mistake ?? If you can , do it again till it looks how you want.
  15. 1st yard completed . Unfortunately for some reason didn t find enough 6mm wooden stick in the occre kit to work on the second one. I will need to get some from the ship modeling store. In the mean while started with the riggings.
  16. Main mast completed and installed. All blocks in place. Now starting the construction of the yards.
  17. Good evening, I'm currently in process to make the mast for the model Santissima Trinidad cross section , but I have a question: how to make the rope 154 listed in the scheme 1:1 ? anyone working or worked at the same model that can help? thank you
  18. Started the mast construction. Platform done and lower mast has been shaped and varnished.
