Posts posted by Boccherini
Olphart,
the colour of the walnut looks great. Re the spacers, I lined mine up by sight as the frames were glued together on the keel, keeping them clear of the future gunports. They were placed near the top of the frames to reinforce the structure whilst sanding. Worked out ok.
Regards,
Grant.
Marius,
welcome to the "bottom of the page". You're off to a good start.
Grant.
Dave,
thanks for the link.
Regards,
Grant.
Thanks for the interest and kind words guys.
42rocker, scale is 1:48 as per the plans. The cannons will eventually be chemically blackened. Regarding timber, the "orange" coloured timber is Fijian mahogany, dark red timber is jarrah, the deck and exterior hull planking is probably Tasmanian oak, though I'm not entirely sure. The jarrah and Tassie oak are recycled from old kitchen cabinet carcases. Old timber tends to be of a better quality. If you are going to all the trouble of framing the deck, might as well show it off.
Grant.
Rusty,
nice workmanship. How did you cut the mortices in the deck beams? They look really precise.
Grant.
Dave,
where did you get the gears from? I have been looking for reasonably priced gears for my future ropoewalk.
Thanks,
Grant.
Click on the "more reply options" box, this will open a different reply set up that allows you to add pictures. If you are still having problems working it out, I'll try to walk you through it. I only just figured it out myself.
Regards,
Grant.
Bob,
it's good to see you restarting your build log.
Regards,
Grant.
Ron,
good to see you finally got started. Nice to see someone else using recycled timber.
Grant
That is some good clean work.
Grant.
- sonicmcdude, coxswain, aykutansin and 1 other
- 4
Larry's Triton Cross Section
in Cross Section Build Logs for HMS TRITON
Larry,
the colour of the timber has come up beautifully. The beam arms are a real bugger to get right, yours look fine. Joss is right about getting the sealing done before building over, it might be good idea though, to not seal where the knees will be placed, your glue may not bond to the sealed surface properly leading to joint failure when you can no longer easily access the area for repairs. Hate to tell you this, from the pictures, it appears your knees are incorrectly sited, they should be alongside the deck beams, not underneath them. Check the drawings.
Regards,
Grant.
