wallyh
Members-
Everything posted by wallyh
Hull Planking
wallyh posted a topic in Building, Framing, Planking and plating a ships hull and deck
Hi all, I'm about to start the second layer on my Fair American, I would like the planks to look scale. Can anyone point me to somewhere that talks about length and how they were staggered? Thanks again in advance, Wally -
I am planning to do a scratch build of the Rattlesnake using Harold Hahn's plans. My question is: can I use a 3/32" sheet plus a 1/8" sheet to make up the 7/32" thick frames? Thanks, Wally
Keel Question
I have a question concerning reinforcing the joint on a keel on a kit such as the Rattlesnake. Is this needed? Or is everything OK after bulkheads are installed? Thanks in advance Wally -
I've used an Olfa gridded cutting mat for years (same one). It's 12"x18", never needed a bigger one,I just looked this one up at Jo-Anns (a sewing and craft shop). It's $22.99 but Jo-Anns almost always has a 40% off coupon to use. Wally
I'm to the point in my Fair American build where I need some guidance on how to attach the spars to the mast. I've tried to find this on my own but I've come up empty handed. Is the spar simply glued or pinned to the mast ? Do you then "tie" this with rope? Any and all help will be appreciated. If I can be pointed to any instruction or pictures that would be good too. Wally
Treenails
wallyh replied to wallyh's topic in Planking Techniques's Click Here for Topics dedicated to planking!!!!
I'm back again with another question. I've got the tree nails down to the right size I think, took them down to 25 on the draw plate and the number 71 drill bit seems right - thanks for that tip. My question - what do you use for cutting and finishing (sanding ?) the bamboo tree nails? Wally -
Treenails
Well, back again, with all the help here I've managed to get a few pieces of bamboo down to 25 on the Byrnes drawplate. Next up up is a test on some planking, Would a size 75 drill be OK? Is there a depth for the treenails? Thanks again, Wally -
Treenails
Thanks for all the help and ideas for my treenail "problem". I managed to do about 4' of BBQ skewer today, so far I've passed them through the number 55 hole on the drawplate - is this OK for the 1:48 scale? What size drill should I be using? As always, thanks so much - I can't tell you how much I've learned on this site. Wally -
Treenails
Thanks to all for your replies. The scale of the ship is 1:48. And, I'm ashamed to say, I have a Byrnes drawplate that I can't seem to work! I was using bamboo skewers but not getting luck with drawing. I will try again this morning - what size should I be shooting for> Thanks again, Wally -
what is the ideal modelling table?
wallyh replied to AON's topic in Modeling tools and Workshop Equipment
Hi Everyone. When I built my bench (2'W x 5'L x 37" H) I put heavy duty casters on it. When needed I roll the bench out into the garage (normally it's against a wall), set the locks on the casters and then I can easily walk around the bench. I use a drafting stool with this bench and a mechanic's hydraulic roll around seat. Wally -
The Color Buff
wallyh replied to wallyh's topic in Painting, finishing and weathering products and techniques
Thanks for the replies. Russ - I was planning to use the Buff color on the bulwarks. Should I be considering other colors? Tom - thanks on the heads up on the RR colors. Wally -
Hi Everyone, I would like to use the color buff on my Fair American but I'm not sure exactly what shade this is - looks like it varies all over a range between a tan and a yellow color. Can anyone point me to the proper color? Thanks, Wally
I would like to replace the 3' (scale) door with a companionway. I believe the Syren has a companionway. Would this style be appropriate for the Fair American? If so could someone out there give me the dimensions? Also, it seems to me that there should be a longboat. Again, if this is correct, what would be it's length? Thanks in advance - hope this post is in the right place. Wally
Thank you so much for your detailed information on the skylight and companion way. I will try my best to incorporate this into my model. Wally
- 206 replies
- fair american
- model shipways
Hi, I just recently picked up on your post and I wish my progress was as good as yours. Where would I find a picture of a companion way - I agree with you on the size of the door. I also like the skylight idea - what size would that be? Thank you for any answers. Wally
- 206 replies
- fair american
- model shipways
Ropewalk links
wallyh replied to Q A's Revenge's topic in Rope Making/Ropewalks's Discussions about Rope Making
Here's another one http://www.shipmodelersassociation.org/research/tps9705c.htm Wally -
Ropewalk links
Another couple of questions, I see you have had about 122 views - has anyone built one of the ropewalks in those links? And if so what was their experience? Wally -
Ropewalk links
Which of the ropewalk links are you leaning towards? I agree with you, simpler is usually better. Wally -
Ropewalk links
Thank you for posting the links - are you planning on building a ropewalk? I'm thinking of building one for my brother in law and myself. Wally
