Everything posted by StuartC
Hi all, thanks to everyone for the kind comments and likes. I thought that this was a suitable time to post a latest progress shot as tomorrow is the third anniversary for this build. As you can see I've made some inroads into the standing rigging and I'm currently working on the dead eyes. A tip for anybody doing this one in future would be to leave the gun port covers until the rigging is complete as I've managed to knock about 50% of them off so far. Finally a Happy New Year to you all
Hi, As always thank you for the comments and support. Latest update is the Bowsprit is now rigged as far as I can at present, so I'm now well under way with the Fore mast, and the spars are drying in their new colours. I find this part of the build one of the most rewarding, as you complete each stage you can see a significant change.
Hi all, Thanks to the usual people for the comments, they are always appreciated. With reference to my last post and the "Only the anchors to go comment", I missed two little things ( ships boats). As per usual I completely underestimated how long these were going to take, after all they are only small... what a mug they are taking for ever, anyway here's the progress
I've been out of the country a fair bit recently, but I have finally got the final parts of the stern decoration in place. There is still quite a bit of tidying up to do, but while I have been waiting for the filler to set I started on the upper deck cannons. A belated Merry Christmas and Happy New year to all.
Hi matey, Sad to say "been there, done that" which is why I ended up pinning them. If I remember correctly I used a 0.8mm drill, in a pin vice ( I think that is the correct name), which if you are very careful (and lucky) just fits. I will admit with a few of the plates, I did break out through the side, but you can carefully bend the plate back into shape. I also ordered brass pins (nails) from Cornwall model ships. Finally when I pinned them I also re-glued them with super glue, which got them to stay in place. The advantage of the hull being black is that it hides an awful lot of sins once it is touched up. Unfortunately I did not find a quick way of doing this task, but as I keep on discovering, be patient, if you try to rush you muck it up. Hope this is of some use. Good luck and stick with it.
Hi All, Final installment of the guardrail saga. As you can see I've finally put the rails in place, a tip if your heading for this bit, do as the instructions say and do the guardrails in two parts. Making it would have been easier, and installation a breeze. Having said that if it was easy it would be boring
