Everything posted by giampieroricci
Thank you Joachim! For burnishing metals (I almost always use brass or, alternatively, copper) I use this product that I bought in the armoury. For the burnishing process, I prefer to burnish the metal parts after they are permanently attached to the model. First, however, it is necessary to treat the underlying wood with a coat of shellac to seal the pores of the wood and prevent the burnishing liquid from penetrating into the fibres and ruining their appearance with stains that are difficult to remove. Translated with DeepL.com (free version)
I am sharing a video I made for those interested in small metal welding. Following some tutorials and videos, I built myself a resistance welder; it is a type of welder that they use mainly in model railways, where it is necessary to make many close welds. This type of soldering iron uses a 10 Ah transformer with 3-6V outputs and has the advantage that it heats, by means of a small graphite electrode and a ground wire, exactly the spot where the soldering is to take place for just a few seconds; this means that you can also make close-set soldering joints without running the risk of desoldering those previously made. Various types of tips can be used, including a ‘clamp’ system, which is very useful when parts to be soldered must be held together. Everything else is self-made and I must say that I am very satisfied with the results! Translated with DeepL.com (free version) https://youtu.be/XRzU--9uhBA
You are making a beautiful model! I don't understand why you have to use those plastic moulded bottles which are an eyesore compared to the beautiful look of the rest! Your skill allows you to make them as they should be made! Sorry, but I had to tell you, although everyone is free to do as they please.....
