giampieroricci
Everything posted by giampieroricci
  1. Thank you, friends! the belts are made ​​of ebony, a wood so hard, so delicate and so mangy to work but so beautiful to see!
  2. I placed the planking of the bottom of the transom, must, I think, before tightening the belts.
  3. Thank you!!!....... In order to block the stern oar in a more stable manner, on the excesses of the oarlocks I have tentatively set a provisional "crowning glory" that I will take away when I have completed the transom
  4. Thank you, friends! Slowly the work going on, I started the construction of the transom: of course is yet to block and finish, especially the two stern oar that for security (or insecurity) I made them abundant
  5. I read all your topic, Sherry... I really like your very precise and clean work!! :)
  6. This is the eighth wonder of the world......! Simply fantastic!!
  7. Thank you friends! I purchased the plans at the author's site: http://gerard.delacroix.pagesperso-orange.fr/monographies/monos.htm I don't know if I can post links: if this is not allowed please moderators delete it
  8. Thank you, Daniel! this monograph is done really well, with excellent plans and details. It does not seem to be a ship hard to do, but it's my first job in admiralty construction.......
  9. Thank you for your appreciation, I'm very glad for it! its measures I don't remember perfectly but it is about 1,20 m.
  10. more..... I have finished with these images: the ship is currently at this point in the construction...
  11. After breathing a sigh of relief noting that the keel has remained perfectly straight, I started the hard work of balancing the exterior of the structure; to do this I'm using the scrapers that, once sharp, working a beauty! Throughout the morning for half of the hull and is not finished yet, in return, my left arm began to creak ..........
  12. more images Laying of fills. After attaching all the fills of the upper parts, I had to remove the template of the site in order to place some fills even deeper arriving well beyond the waterline
  13. I then embarked on a jogger on the shores of the bow: I must say that I was quite surprised because there is not much to equalize! I used some self-built tools but the work is much better with the scraper, in particular, I used the curvilinear; In the picture you can see the treated part, darker; the test with a strip has confirmed that so far seems to have done a good job! I started to enclose the ship in the upper part of the oarlocks. Perhaps the method I used is not exactly orthodox, but it is really effective and clean and the whole thing is tight.
  14. more images I glued the series of spacers in the middle between the butts of the floor frame and the floor frame means
  15. I started to fix the double ribs to the keel permanently. I wanted, for convenience, to starting with the masters quarters and then join with those already established at bow and stern. For greater security gluing I used the double coasts of steel nails nailing the madiere the keel after having done a 1mm hole in the center. After checking the squareness of the coasts, I fixed the spacers on the size of mesh on the template of the site helping with rubber bands (made ​​from under the template) to adhere the coasts of the template itself. I have to say that already so the coasts do not move except in the upper parts of the oarlocks, but this will solve when I put the studs. For the moment I want to fix all the coasts, then I will proceed with the keys at the heads of the floor plates.
