richardt
Posts posted by richardt
  1. A problem that often arises with cast metal adhesion is that the parts are coated with wax-like substances that are used as release agents from the mould. This presents problems with any adhesive. I suggest that the parts are soaked briefly in acetone and scrubbed lightly to remove these first and then allow them to dry before mounting. I prefer to use thickened CA over epoxy.
    Richard
  2. Hi Pete,
    As others advised, assemble the model first. I prefer to use 100% PureTung Oil and not stuff that has been adulterated or otherwise processed in any way.
    The key to getting a good finish is to use as little as possible spread as far as possible. Once you have coated the model, wipe off any excess and remove as much as possible. Use Q-Tips etc. to remove excess oil that accumulates in corners. Only then allow the model to stand for a couple of days to allow the oil to penetrate the wood. It should be looking quite good at this stage but i find an improvement in applying a second coat working exactly as before. Further coats do not seem to enhance the finish and are more likely to just thicken the coating.
    Always experiment first to satisfy yourself beforehand.
    Richard
  3. Hi cabrapente,
    I think your troubles started when you glued your templates to the planks. If you rub your glue stick onto the paper template it can distort the  template and any distortion will be transferred to the part when you cut it out. What I do is rub the glue stick on the plank and then carefully place the template onto the glue. Then put a piece of scrap paper over the template and then gently press it down. When it is properly in place, carefully remove the scrap paper and your template will be perfect. Instead of sticking the template on the wood, you are rather sticking the wood on the template. Before gluing the futtocks together, first compare everything against the plans and make sure that the butt ends are square and the parts follow the hull curve properly.
    I'm sure that you will still end up with a nice hull with careful sanding but it can be done without sweat and tears.
    Cheers,
    Richard
  4. Hi Guys,
    As you well know, Larry and I are trying to develop some reference material on adhesives and you will be introduced to the result in due course. We will be calling on your knowledge and input in due course and I thank those who have already expressed some of their views in the meantime.
    However, I am concerned about the information requested pertaining to medical issues. We are not qualified to comment on this and it  will not form a part of our research. However I can provide some background on what I know and accept to be truthful:
    The substance emanates from research into low m.w. esterification conducted by the Eastman Chemical Co. about 80 years ago. An accident with one of the intermediate products landed in the eyes of a lab technician whose eyes were immediately glued closed from, as it was later discovered, the presence of water that activates the adhesive properties and even the minimal pressure exerted by the closing eyelids that set up sufficient pressure to promote adhesion. The only action that could be taken was to open the eyes by surgery. This story was told to me a long while back by a senior staff member of Eastman and I had no reason to disbelieve him.
    Alarmed as Eastman may have been, they immediately saw the potential value of the substance and it was put on the market soon afterwards and was called Eastman 910.
    More recently it would appear that patents expired and there was a prolification of new producers with similar products. These are what we call CA (cyanoacrylate) adhesives. Slight modifications by the new manufacturers led to the production of products with varying degrees of viscosity. Selective additives also produced substances with gap filling properties and other desireable properties that make them attractive to hobbyists.
    The thin very mobile product was the first and the initial application was, ironically, medically related because it was used to seal wounds instead of using sutures in certain instances. I am not aware of any specific toxicology studies and other than a temporary reaction to contact with the skin, it does not seem to have any lasting negative effects.  This is not the the case with inhalation of the fumes and I urge all to avoid this under all circumstances. There are many reports of allergies that should be brought to the attention of your doctor. I am also led to believe that fumes generated by burning CA are particularly dangerous. In this respect, many modellers make a small fork from grinding back the eye of a needle to produce two tines. This is useful to lift and transport a small droplet of the material. There is no harm in this but do not burn the excess off the needle and inhale the smoke. I urge you to use the substance in the smallest possible quantity of the material and never take the bottle to your model. Always use a suitable disposable surface from where you can lift the required quantiy.
    The fumes of the material are suffocating and reaction to the smallest trace in the atmosphere will alert you to its presence. Take due care.
    Richard
  5. Hi again Oli,
    I forgot to stress that you must be very careful that you don't misalign the squareness of the fit when you do the sanding.
    When I look at the pic of the pile of bulkheads it would seem that the slots tend to open slightly at the mouth. This could have been caused when you tried the dry fit. It could also be a shadow or just my imagination but it may indicate the cause of the problem.
    Richard
  6. Hi Oli,
    You don't want them so tight. Inspect the slots to see if they are correctly shaped and without projections that could be the problem. Otherwise you will have to sand them down a bit. They also must not be so loose as to wobble. You may find it easier to sand the keel below and the bulkheards above the slots on both sides rather than opening up the slots. It should end up with a nice comfortable sliding fit.
    Check the mast steps at the same time and make sure that they will accept the dowels nicely or adjust them accordingly.
    Cheers,
    Richard
  7. Hi Larry,
    Adhesives form a vital role in almost every aspect of our hobby yet we have no tutorial or standing guide for our members to refer to.
    You are obviously very interested in this topic and I would suggest that you do some research aimed at covering all aspects involved with this objective and to compile a good review for our Senior Officers approval who, I am sure will support and assist you.
    I am prepared to help you draw up a skeleton of what I think can or should be included in the work but I'm afraid that I can not be deeply involved in the actual project other than to provide my own knowledge.
    Would you like to take this on? I am making this suggestion as a junior member of our Group and have no influence in any decision-making.
    Richard
  8. Hi again figuerres,
    Sounds like a plan and that is better than nothing at all.
    The reason that I suggested the original casting be a regular square block or cube is that much of the work will need to be made while the part is mounted in a vice or similar. Once the innards are in place the final shape will be very much easier to achieve by filing and polishing.
    I expect that the finished lantern surfaces port and starboard should be mirror images but it is most unlikely that the fore/aft surfaces are. You will need to establish this for your particular need but it is very doubtful that you will be able to clamp the final shape while you work on it.
    I have not looked at Tom's link and there may be good ideas there.
    Richard
  9. Hi figuerres,
    I doubt that you will find anything available "off-the-shelf" that you could use and suggest that you try to scratch build your own. I have seen several examples of beautiful work so the idea is not inconceiveable. However, I have not seen a lantern with a led installed and this will be an added problem but I have no doubt that modellers have overcome this.
    Basically what I have seen is a solid cast block of polyester resin (the stuff that comes in liquid form and cosists of two parts that are mixed for encapsulation work) shaped according to the size and shape of the lantern. A suitable framework is then made to surround the shaped block according to the plan and support.
    The key would be to first cast a suitable size rectangular block and drill a hole through it to accomodate the led (with the wiring attached). The wire should then be drawn through a length of brass tubing bent according to the plan and the hole can then be plugged with a small quantity of resin that will support both the led and brass tube with wiring exposed at the end. Do not close the upper part of the hole that should remain open. The led does not create a great deal of heat but I don't know what will happen if it is entirely enclosed.
    Once this has been done, the block of resin can then be shaped according to your requirements and the framework assembled from wire or brass strips. An upper cap will be needed as part of the framework and this should have a small vent above the top of the led.
    I do believe that the work will be a challenge and I wish you success.
    Richard
  10. Hi Guys,
    I agree with Andy's sentiments.
    I used Zap-a-Gap to anchor my plates on my Aggy (see Avatar). What helped me greatly was that I noticed that if the bottle was lying on it's side, a small bead of glue would form at the tip of the nozzle. The development of this bead coincided very nicely with the rate that I could lift the plate in my tweezers, touch the reverse side of the plate on the nozzle and transfer it to the hull and press to secure. Once this operation was completed, sufficient adhesive had collected for immediate repetition of the cycle. Of course my system was slowed when I reached the gore lines and the boot topping and the plates needed to be "spiled" but the tedious work had been avoided. My kit came with 3000 plates and I had a reasonable number left over (perhaps some 200). Not a single plate came detached, then or since.
    Richard
  11. Hi Oli,
    I am familiar with the Jotika kits from Caldercraft but Kriek looks like a different stable in the Group and perhaps their raw materials are somewhat inferior. I have not had any experience with them. Don't be shy to replace anything that doesn't meet your expectations. (My avatar pic is a stern view of my last kit build that was the Agamemnon from Caldercraft - Nelson's Navy selection).)
    There is a technique followed by some modellers called "painting with wood" where the strategic selection of a various coloured wood is used to represent the original colours of the painted ship and some stunning results have been achieved. You will need a good source to satisfy this demand and an outfit called Constantines comes to mind. They were in NYC but moved out of town some years ago. Google will probably find them. They did have a very extensive colour guide of lots of wood species to select from but having decided on colour, you should research suitability for the intended application and local availability. You have the full resources at MSW to guide you on this.
    Cheers,
    Richard
  12. I bought my first tool when I built my first model in 1950. It is a fretsaw with a 290mm throat and is stamped "Made in England".It has literally been in constant use ever since. I can cut faster and more accurately with it than with a scroll saw and I have the economy of using the entire toothed area of the blade and not limited to the cam of a scroll saw. There is nothing, other than the blade that can break, It never needs servicing because it is reliant only on elbow grease. The shellac on the handle is a bit worn but otherwise it is as bright and shiny as the day that I bought it. I can't remember what I paid for it but in todays money it would probably have been less than 10c. I don't like it.... I love it.
    Richard
  13. Hi Oli. You made a good start! You got the box open! :)
    Mike has given you excellent advice on finishing wood with Tung oil but I haven't any idea where you can get it in Euroland. I'ts not something you will find in any paint store etc. but keep a lookout for it. The tree that produces the oil it's extracted from is indigenous to China who produce literally 100% of global demand. There is a smaller plantation in the US but they can't satisfy the local demand. It's mainly used to make high quality printing inks and if you've a contact in this industry he may be able to set you right. (Coates Inks etc. are big users.) Anyhow, it's early days yet and about 250ml will set you right for a few models. You can get as much as you will ever need in Canada.
    The important thing to remember is that it must be 100% pure Tung Oil. Not modified or adulterated in any way.
    Cheers,
    Richard
  14. Hi J. Pett,
    The fact that Clorox cleared it up indicates that the problem was most likely caused by mould. Oxalic Acid may have given similar results but I would always look for an alternative.
    I quote from the Merck Index 9th. edition: "Caustic and corrosive to skin, mucous membranes. Ingestion may cause severe gastroenteritis with vomitiong, diarrhea, melena. Renal damage can occur as a result of formation of excessive Calcium Oxalate. Severe poisoning can end fatally.
    Richard
