Hi,
This is a very basic beginner's question. When I want to sand a narrow piece of wood (especially while making bevels) is there any technique (besides a steady hand) to maintain steady angle and flat surface on the sanded piece?
Thank you.
Edited by Joshua
Not sure quite what you mean Joshua, but clamping the wood in a vice then wrapping your sandpaper around a wood block should allow you, with slow and steady passes, to achieve the angle you require. You could also consider scribing a line and sanding to that to ensure you get the desired angle.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Hi Joshua.
When I have a LOT of bevels to do I make a jig out of some scrap softwood.
The scrap timber should be flat and wide.
Using a bench saw cut a slot in the scrap timber at the angle you want.
Then the timber you are sanding fits into the slot at the correct angle.
Now I pass it through my drum sander.
The result is perfect bevels on my timbers.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
