Time to plank the rest of the port side.
But before I started that, I connected the wiring for the LED. The picture below shows the location between the frames.
It also shows two strips of stiff paper at each end. I will use those to measure and mark the planking widths. Unlike cross sections taken midship, the hull here curves and the planking need to be tapered. Here is how I did the measuring and marking.
I measured the length of the two strips of paper and divided the longer one by the width of my planks (0.125 inches). I need 40 planks tapered to 0.121 inch at one end and 0.100 inch at the narrow or forward end. Then I divided the strips into segments of 10 planks each. That will be my guide. After I put on ten tapered planks I will repeat this and recalculate if my planks are going on as planned.
What I need to do now is rethink how I am going to taper forty planks.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
Dave, I don't know but keep a couple things in mind.
I am working only with pieces that are six inch long (or 38 feet full scale). Obviously there were a lot of joints that I don't worry about.
The width of 9.5 inch is not too bad.
And then there is the way I am now approaching my planking. I taper each plank to about the size shown above and then group three of those and edge bond them. Before the edge glue is completely set, I bond them to the frames. I find this work well and gives me better control. I simply clamp the ends and use some tapered nails to force them against the last set of planks. When necessary I use heavy weights in the center to force them against the frames.
Hence the drawing of ten planks should now read nine planks (thirteen groups of three plus a single plank to close the final gap).
Edited by Modeler12
Jay
